[SCM] PostGIS branch master updated. 3.5.0-75-gd679fd060
Mon Nov 18 13:57:02 PST 2024
the project "PostGIS".
       via  d679fd0606c8f7f54f7e5b43cdf5c6ad77316693 (commit)
      from  f0d1ee2d6146286c450abb7d37074cd3eb45872d (commit)
revisions in full, below.
commit d679fd0606c8f7f54f7e5b43cdf5c6ad77316693
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Nov 18 16:56:57 2024 -0500
    Add images for 3d buffer
diff --git a/doc/html/images/static/cg_3dbuffer01-8.png b/doc/html/images/static/cg_3dbuffer01-8.png
new file mode 100644
index 000000000..2b46af497
Binary files /dev/null and b/doc/html/images/static/cg_3dbuffer01-8.png differ
diff --git a/doc/html/images/static/cg_3dbuffer01.png b/doc/html/images/static/cg_3dbuffer01.png
index 000000000..e681ad703
Binary files /dev/null and b/doc/html/images/static/cg_3dbuffer01.png differ
diff --git a/doc/html/images/static/cg_3dbuffer02.png b/doc/html/images/static/cg_3dbuffer02.png
index 000000000..6ac892f76
Binary files /dev/null and b/doc/html/images/static/cg_3dbuffer02.png differ
diff --git a/doc/html/images/static/cg_3dbuffer03.png b/doc/html/images/static/cg_3dbuffer03.png
index 000000000..0bdd24d27
Binary files /dev/null and b/doc/html/images/static/cg_3dbuffer03.png differ
diff --git a/doc/html/images/static/cg_3dbuffer04.png b/doc/html/images/static/cg_3dbuffer04.png
index 000000000..edb98b33a
Binary files /dev/null and b/doc/html/images/static/cg_3dbuffer04.png differ
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index 00a6e4698..2f7711621 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -3074,10 +3074,80 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
        <title>Examples</title>
        <programlisting>SELECT ST_AsText(CG_Buffer3D('POINT(0 0 0)', 1, 8, 0));
 -- Result: POLYHEDRALSURFACE Z (((0 0 1, 0.5 -0.5 0.71, 0 -0.71 0.71, 0 0 1)), ... )</programlisting>
+       <para>The following images were rendered pasting the output of the ST_AsX3D query into <link xlink:href="https://postgis.net/docs/support/viewers/x3d_viewer.htm">X3D Viewer</url>.</para>
+       <programlisting><![CDATA[SELECT string_agg('<Shape>' || ST_AsX3D(cgbuffer3d_output)  || '<Appearance>
+          <Material diffuseColor="0 0.8 0.2" specularColor="0 1 0"/>
+        </Appearance>
+    </Shape>', '');]]></programlisting>
+    <informaltable>
+                <tgroup cols="2">
+                <tbody>
+                    <row>
+                    <entry><para><informalfigure>
+                        <mediaobject>
+                            <imageobject>
+                            <imagedata fileref="images/cg_3dbuffer01.png"/>
+                            </imageobject>
+                            <caption><para>segments=32 (rounded buffer)</para></caption>
+                        </mediaobject>
+                        </informalfigure>
+            <programlisting>SELECT CG_Buffer3D(ST_GeomFromText('POINT(100 90)'), 50,32,0);</programlisting>
+                        </para></entry>
+                        <mediaobject>
+                            <imageobject>
+                            <imagedata fileref="images/cg_3dbuffer02.png"/>
+                            </imageobject>
+                            <caption><para>5 segments rounded</para></caption>
+                        </mediaobject>
+                        </informalfigure>
+ ST_GeomFromText('POINT(100 90)'),
+ 50,5,0);
+            </programlisting>
+                    </para></entry>
+                    </row>
+                    <row>
+                        <mediaobject>
+                            <imageobject>
+                            <imagedata fileref="images/cg_3dbuffer03.png"/>
+                            </imageobject>
+                            <caption><para>32 segments, round</para></caption>
+                        </mediaobject>
+                        </informalfigure>
+  ST_GeomFromText(
+    'LINESTRING(50 50,150 150,150 50)'
+ 10,32,0);
+            </programlisting>
+                        </para></entry>
+                        <mediaobject>
+                            <imageobject>
+                            <imagedata fileref="images/cg_3dbuffer04.png"/>
+                            </imageobject>
+                            <caption><para>32 segments, square</para></caption>
+                        </mediaobject>
+                        </informalfigure>
+  ST_GeomFromText(
+ 10,32,2);
+            </programlisting>
+                        </para></entry>
+    </row>
+    </tbody>
+    </tgroup>
+    </informaltable>
    </refsection>
    <refsection>
        <title>See Also</title>
-       <para><xref linkend="ST_Buffer"/>, <xref linkend="ST_3DConvexHull"/></para>
+       <para><xref linkend="ST_Buffer"/>, <xref linkend="ST_3DConvexHull"/>, <xref linkend="ST_AsX3D" /></para>
    </refsection>
 </refentry>
Summary of changes:
 doc/html/images/static/cg_3dbuffer01-8.png | Bin 0 -> 8023 bytes
 doc/html/images/static/cg_3dbuffer01.png   | Bin 0 -> 20902 bytes
 doc/html/images/static/cg_3dbuffer02.png   | Bin 0 -> 3925 bytes
 doc/html/images/static/cg_3dbuffer03.png   | Bin 0 -> 17436 bytes
 doc/html/images/static/cg_3dbuffer04.png   | Bin 0 -> 7944 bytes
 doc/reference_sfcgal.xml                   |  72 ++++++++++++++++++++++++++++-
 6 files changed, 71 insertions(+), 1 deletion(-)
 create mode 100644 doc/html/images/static/cg_3dbuffer01-8.png
 create mode 100644 doc/html/images/static/cg_3dbuffer01.png
 create mode 100644 doc/html/images/static/cg_3dbuffer02.png
 create mode 100644 doc/html/images/static/cg_3dbuffer03.png
 create mode 100644 doc/html/images/static/cg_3dbuffer04.png
hooks/post-receive
