[SCM] PostGIS branch master updated. 3.5.0-80-g78f164621
Fri Nov 22 18:01:07 PST 2024
the project "PostGIS".
       via  78f1646214ca915fd34580a63989afd772736521 (commit)
      from  3baef024ebacff32572291c6e6497dcb58306582 (commit)
revisions in full, below.
commit 78f1646214ca915fd34580a63989afd772736521
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Nov 22 18:00:27 2024 -0800
    Fix performance regression in ST_Within, closes #5812
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index ec97e0185..9074d4ff4 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -594,8 +594,8 @@ Datum within(PG_FUNCTION_ARGS)
 	POSTGIS_DEBUGF(3, "Contains: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
-	** Short-circuit 1: if geom2 bounding box is not completely inside
-	** geom1 bounding box we can return FALSE.
+	** Short-circuit 1: if geom1 bounding box is not completely inside
+	** geom2 bounding box we can return FALSE.
 	if (gserialized_get_gbox_p(geom1, &box1) &&
 	    gserialized_get_gbox_p(geom2, &box2))
@@ -620,7 +620,7 @@ Datum within(PG_FUNCTION_ARGS)
 	initGEOS(lwpgnotice, lwgeom_geos_error);
-	prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, NULL);
+	prep_cache = GetPrepGeomCache(fcinfo, NULL, shared_geom2);
 	if ( prep_cache && prep_cache->prepared_geom && prep_cache->gcache.argnum == 2 )
 		g1 = POSTGIS2GEOS(geom1);
Summary of changes:
 postgis/lwgeom_geos_predicates.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
