[SCM] PostGIS branch stable-3.5 updated. 3.5.0-26-gaf101253e
git at osgeo.org
git at osgeo.org
Fri Nov 22 18:01:12 PST 2024
the project "PostGIS".
The branch, stable-3.5 has been updated
via af101253e8adbaafe8a7fc7b7879c8770af27d4e (commit)
from 5314c457fa8cfa0eac19d8e2f1e6e20be129d144 (commit)
revisions in full, below.
commit af101253e8adbaafe8a7fc7b7879c8770af27d4e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Nov 22 18:00:27 2024 -0800
Fix performance regression in ST_Within, closes #5812
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index ec97e0185..9074d4ff4 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -594,8 +594,8 @@ Datum within(PG_FUNCTION_ARGS)
POSTGIS_DEBUGF(3, "Contains: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
- ** Short-circuit 1: if geom2 bounding box is not completely inside
- ** geom1 bounding box we can return FALSE.
+ ** Short-circuit 1: if geom1 bounding box is not completely inside
+ ** geom2 bounding box we can return FALSE.
if (gserialized_get_gbox_p(geom1, &box1) &&
gserialized_get_gbox_p(geom2, &box2))
@@ -620,7 +620,7 @@ Datum within(PG_FUNCTION_ARGS)
initGEOS(lwpgnotice, lwgeom_geos_error);
- prep_cache = GetPrepGeomCache(fcinfo, shared_geom1, NULL);
+ prep_cache = GetPrepGeomCache(fcinfo, NULL, shared_geom2);
if ( prep_cache && prep_cache->prepared_geom && prep_cache->gcache.argnum == 2 )
g1 = POSTGIS2GEOS(geom1);
Summary of changes:
postgis/lwgeom_geos_predicates.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
