[SCM] PostGIS branch master updated. 3.5.0-85-gfecfa4c34
Thu Nov 28 00:13:20 PST 2024
the project "PostGIS".
       via  fecfa4c34170c91cd68aef4a8afeba7ec1906fc6 (commit)
       via  8f757da5bc0db6c811eafff535a45a657082501b (commit)
      from  8448363e6110ff9a301708b1e75b876b6175b7f2 (commit)
revisions in full, below.
commit fecfa4c34170c91cd68aef4a8afeba7ec1906fc6
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Thu Nov 28 08:12:33 2024 +0000
    Translated PostGIS Manual using Weblate (German)
    Currently translated at 49.4% (2845 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index b8ce393d2..ae1aaa68b 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
 "PO-Revision-Date: 2024-11-28 08:13+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/de/>\n"
 "Language: de\n"
@@ -5739,6 +5739,8 @@ msgstr ""
 #, no-c-format
 msgid "Enhanced: 3.2.0 added support for returning signed identifier."
 msgstr ""
+"Verbessert: In Version 3.2.0 wurde Unterstützung für die Rückgabe signierter "
+"Bezeichner hinzugefügt."
 #. Tag: para
 #, no-c-format
commit 8f757da5bc0db6c811eafff535a45a657082501b
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date:   Thu Nov 28 08:11:27 2024 +0000
index 9d31f5500..b8ce393d2 100644
@@ -9,8 +9,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-11-28 08:11+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-11-28 08:13+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language: de\n"
@@ -5718,12 +5718,12 @@ msgid ""
 "be split by the line. New nodes and faces may be added."
 msgstr ""
 "Fügt einen Linienzug zu einer bestehenden Topologie hinzu und gibt einen "
-"Satz vorzeichenbehafteter Kantenbezeichner zurück, die ihn bilden (negative "
-"Bezeichner bedeuten, dass die Kante in die entgegengesetzte Richtung des "
-"eingegebenen Linienzugs verläuft). Die angegebene Linie rastet an "
-"vorhandenen Knoten oder Kanten innerhalb der angegebenen Toleranz ein. "
-"Vorhandene Kanten und Flächen können durch die Linie geteilt werden. Neue "
-"Knoten und Flächen können hinzugefügt werden."
+"Satz vorzeichenbehafteter Kantenbezeichner zurück, aus denen dieser "
+"aufgebaut ist (negative Bezeichner bedeuten, dass die Kante in die "
+"entgegengesetzte Richtung des eingegebenen Linienzugs verläuft). Die "
+"angegebene Linie rastet an vorhandenen Knoten oder Kanten innerhalb einer "
+"gegebenen Toleranz ein. Vorhandene Kanten und Maschen können durch die Linie "
+"geteilt werden. Neue Knoten und Maschen können hinzugefügt werden."
 #. Tag: para
 #, fuzzy, no-c-format
Summary of changes:
 doc/po/de/postgis-manual.po | 16 +++++++++-------
 1 file changed, 9 insertions(+), 7 deletions(-)
hooks/post-receive
