[PostGIS] #5786: Side-location conflict: new edge starts in face 42 and ends in face 10
trac at osgeo.org
Wed Oct 2 00:48:33 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: master
Resolution: | Keywords: robustness
Comment (by Lars Aksel Opsahl):
So with that new merge line code I assume lines may be merged into a
single line ?
Just like what happens when I define the topology.CreateTopology
('t5786',4258,1e-04); the two lines are merge into one and we get no
error.
One issue is how handle bleeding polygons.
We could off always add closed polygons , but that's not possible since we
polygons that may cover many content based grid cells.
So If endpoints of a line connecting to another cell has been moved we
will not be able connect them.
What happens if we disable the new line merge code ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5786#comment:7>
