[PostGIS] #5788: ERROR: XX000: GEOSIntersects: TopologyException: side location conflict at
trac at osgeo.org
Thu Oct 3 12:53:00 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.4
Component: postgis | Version: 3.4.x
Keywords: |
On
POSTGIS="3.4.2 c19ce56" [EXTENSION] PGSQL="160" GEOS="3.12.1-CAPI-1.18.1"
(compiled against GEOS 3.10.2) SFCGAL="SFCGAL 1.4.1, CGAL 5.3.1, BOOST
1.74.0" PROJ="8.2.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
GDAL="GDAL 3.4.1, released 2021/12/27" LIBXML="2.9.13" LIBJSON="0.15"
LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
When uploading files and run this below sql
SELECT ST_area(ST_Union(ST_Intersection(mt.geo,f.geo)),true)
FROM
free_area_geo_before_must_overlap f,
must_overlap_area_used_list_soknad_and_tiltak mt
WHERE mt.geo && f.geo AND ST_Intersects(mt.geo,f.geo)
AND ST_IsValid(mt.geo) AND ST_IsValid(f.geo);
I get this error
at 5.993730927467122 59.273001457529752. This can occur if the input
geometry is invalid.
With a the new SQL below it works where I use st_dump it works
FROM
(SELECT (ST_Dump(ff.geo)).geom geo FROM
free_area_geo_before_must_overlap ff) f,
(SELECT (ST_Dump(mt1.geo)).geom geo FROM
must_overlap_area_used_list_soknad_and_tiltak mt1) mt
st_area
0.1568622817327
(1 row)
And the sql below also works but gives a different result as you see
FROM
(SELECT ST_collect(mt1.geo) geo FROM
st_area
0
(1 row)
On latest postgis all 3 sql's works but they give different result
POSTGIS="3.6.0dev 3.5.0-13-g290fffd11" [EXTENSION] PGSQL="160"
GEOS="3.13.0beta2-CAPI-1.19.0" PROJ="9.3.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ
9.13.0) LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
As you see here
FROM
FROM
FROM
st_area
0.12751095705231963
(1 row)
st_area
0.1569281251764355
(1 row)
st_area
0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5788>
