[PostGIS] #5789: berrie64 is failing at configure step Please install libiconv and libiconv-devel
PostGIS trac at osgeo.org
Thu Oct 3 23:14:53 PDT 2024
devel
 Reporter:  robe          |      Owner:  robe
     Type:  defect        |     Status:  new
 Priority:  blocker       |  Milestone:  PostGIS 3.6.0
Component:  QA/buildbots  |    Version:  master
 Keywords:                |
 berrie64 seems to be unhappy of late
 11:30:41 checking for _LARGEFILE_SOURCE value needed for large files... no
 11:30:41 checking for perl... /usr/bin/perl
 11:30:41 checking for xsltproc... /usr/bin/xsltproc
 11:30:41 checking for xml2pot... /usr/bin/xml2pot
 11:30:41 checking for msgmerge... /usr/bin/msgmerge
 11:30:41 checking for msginit... /usr/bin/msginit
 11:30:41 checking for convert... /usr/bin/convert
 11:30:41 checking for dblatex... /usr/bin/dblatex
 11:30:41 checking for xmllint... /usr/bin/xmllint
 11:30:41 checking for pkg-config... /usr/bin/pkg-config
 11:30:41 checking pkg-config is at least version 0.9.0... yes
 11:30:41 checking for CUNIT... yes
 11:30:41 checking iconv.h usability... yes
 11:30:41 checking iconv.h presence... yes
 11:30:41 checking for iconv.h... yes
 11:30:41 checking for libiconv_open in -liconv... no
 11:30:41 checking for iconv_open in -lc... no
 11:30:41 checking for iconv_open in -liconv... no
 11:30:42 configure: error: Could not find libiconv. Please install
 libiconv and libiconv-devel.
 11:30:42 Build step 'Execute shell' marked build as failure
 11:30:42 [Gitea] do not publish assets due to build being non-Successful
 I thought it was only the past couple of days but might have been going on
 for longer
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5789>
