[PostGIS] #5790: Postgis-functions in Materialized views fail in Postgres 17 due to not fully qualified search path
trac at osgeo.org
Fri Oct 4 03:27:21 PDT 2024
Reporter: maxbo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.4
Component: postgis | Version: 3.4.x
Keywords: |
Since Postgres 17, While REFRESH MATERIALIZED VIEW is running, the
search_path is temporarily changed to pg_catalog, pg_temp.
Materialized Views, that use a directly some PostGIS-Functions fail, if
these functions call other PostGIS-Functions without a full schema
qualifier.
For example:
public.st_value(raster, integer, integer, boolean)
calls
st_value($1, 1::integer, $2, $3, $4)
And if this is done during a "REFRESH MATERIALIZED VIEW",
st_value(raster, integer, integer, integer, boolean)
cannot be found.
Another example:
public.st_worldtorastercoordx(raster, geometry);
refers to ST_x, ST_y, ST_SRID and ST_geometrytype
which cannot be found during a "REFRESH MATERIALIZED VIEW".
The issue could be fixed by changing the postgis-functions that call other
postgis-functions by adding the schema:
IF ( public.ST_geometrytype(pt) != 'ST_Point' ) THEN
RAISE EXCEPTION 'Attempting to compute raster
coordinate with a non-point geometry';
END IF;
IF public.ST_SRID(rast) != public.ST_SRID(pt) THEN
RAISE EXCEPTION 'Raster and geometry do not have
the same SRID';
END IF;
SELECT columnx INTO xr FROM
public._ST_worldtorastercoord($1, public.ST_x(pt), public.ST_y(pt));
RETURN xr;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5790>
