[PostGIS] #2614: Prepared geometry support for ST_DWithin
trac at osgeo.org
Tue Oct 8 14:47:58 PDT 2024
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: high | Milestone: PostGIS Fund Me
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by pramsey):
Note you cannot test one gnarly case and call all things faster. At a
minimum, point/point distance will be worse, because of the marshalling
cost for GEOS. Also true no doubt of all kinds of small feature->small
feature cases. Great care is required to muck with the distance functions
because they drive so many of the use cases.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2614#comment:15>
