[PostGIS] #5792: TopoGeo_addPoint silently corrupts topology
PostGIS trac at osgeo.org
Wed Oct 9 03:47:29 PDT 2024
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  high      |  Milestone:  PostGIS 3.5.1
 Component:  topology  |    Version:  3.5.x
Resolution:            |   Keywords:
Comment (by strk):
 The test:
 select NULL FROM topology.DropTopology ('t5792');
 select NULL FROM topology.CreateTopology ('t5792');
 SELECT NULL FROM topology.TopoGeo_addLinestring('t5792', 'LINESTRING(
 11.812075769533624 59.77938755222866,
 11.811862389533625 59.77938237222866
 11.811862389533625 59.77938237222866,
 11.811969079533624 59.77938496222866,
 SELECT * FROM ValidateTopology('t5792');  -- topology is valid here
 BEGIN;
 -- This breaks the topology
 SELECT NULL FROM topology.TopoGeo_addPoint('t5792',
 'POINT(11.812029186127067 59.7793864213727)');
 SELECT * FROM ValidateTopology('t5792'); -- topology is INVALID here
 The introduced invalidities are reported as:
              error              | id1 | id2
  universal face has shell rings |   0 |
  face has wrong mbr             |   1 |
  hole not in advertised face    |  -3 |
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5792#comment:1>
