[PostGIS] #5793: Crash on Buffer of Empty array on PG17
PostGIS trac at osgeo.org
Wed Oct 9 12:27:15 PDT 2024
  Reporter:  pramsey  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.5.1
 Component:  postgis  |    Version:  3.4.x
Resolution:           |   Keywords:  pg17
Changes (by pramsey):
 * milestone:  PostGIS PostgreSQL => PostGIS 3.5.1
Comment:
 Actually, can get it down to this
 CREATE TABLE n (i integer);
 CREATE OR REPLACE FUNCTION l2(numeric[])
     RETURNS integer
     AS 'SELECT array_length($1,1) + array_length($1,1)'
     LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
 SELECT l2(array_agg(i)::numeric[]) FROM n;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5793#comment:10>
