[PostGIS] #5797: TopoGeo_addPoint fails: end node not geometry end point
trac at osgeo.org
Fri Oct 11 03:01:55 PDT 2024
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: 3.5.x
Resolution: | Keywords:
Comment (by strk):
The problem is that the input point (9 5) is first projected to the
existing edge and then the edge is snapped to it, effectively moving its
last point.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5797#comment:1>
