[SCM] PostGIS branch stable-3.5 updated. 3.5.0-11-g8389f4b30
git at osgeo.org
git at osgeo.org
Fri Oct 11 12:30:24 PDT 2024
the project "PostGIS".
The branch, stable-3.5 has been updated
via 8389f4b30cf6946374475feec20fe72a97c9232e (commit)
from 0b55ff4279d1b30d17b1e520ef8b5d466cdfd8e9 (commit)
revisions in full, below.
commit 8389f4b30cf6946374475feec20fe72a97c9232e
Author: Björn Harrtell <bjorn at septima.dk>
Date: Thu Oct 10 14:46:49 2024 +0200
Fix ST_NewEdgesSplit can cause invalid topology
References #5795 in 3.5 branch (3.5.1dev)
Includes testcase
diff --git a/NEWS b/NEWS
index 60e268649..4dc5ffe8e 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
* Bug fixes *
+- #5795, Fix ST_NewEdgesSplit can cause invalid topology
+ (Björn Harrtell
- #5794, Fix crash in TopoGeo_addPoint (Sandro Santilli)
- #5785, [raster] ST_MapAlgebra segfaults when expression references
a supernumerary rast argument (Dian M Fay)
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index cf869bb1a..c5accb28c 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -1336,7 +1336,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
/* Update all next edge references pointing to old edge id */
- updedge.next_right = newedges[1].edge_id;
+ updedge.next_right = newedges[0].edge_id;
seledge.next_right = edge;
seledge.start_node = oldedge->start_node;
ret = lwt_be_updateEdges(topo,
@@ -1350,7 +1350,7 @@ lwt_NewEdgesSplit( LWT_TOPOLOGY* topo, LWT_ELEMID edge,
return -1;
- updedge.next_right = -newedges[0].edge_id;
+ updedge.next_right = -newedges[1].edge_id;
seledge.next_right = -edge;
seledge.start_node = oldedge->end_node;
diff --git a/topology/test/regress/st_newedgessplit.sql b/topology/test/regress/st_newedgessplit.sql
index 075f599b3..893ac8a24 100644
--- a/topology/test/regress/st_newedgessplit.sql
+++ b/topology/test/regress/st_newedgessplit.sql
@@ -143,3 +143,33 @@ DROP TABLE t;
DROP FUNCTION check_changes();
SELECT DropTopology('city_data');
+select '---';
+-- Regression test for ST_NewEdgesSplit can cause invalid topology
+-- See https://trac.osgeo.org/postgis/ticket/5795
+select '#5795|Regression test starting';
+select '#5795|Create t5795' from (select null from topology.createtopology('t5795', 0, 0)) q;
+select '#5795|N' || topology.st_addisonode('t5795', 0, st_geomfromtext('POINT(0 0)'));
+select '#5795|N' || topology.st_addisonode('t5795', 0, st_geomfromtext('POINT(10 10)'));
+select '#5795|E' || topology.st_addisoedge('t5795', 1, 2, st_geomfromtext('LINESTRING(0 0, 10 0, 10 10)'));
+select '#5795|E' || topology.st_addedgenewfaces('t5795', 2, 1, st_geomfromtext('LINESTRING(10 10, 0 10, 0 0)'));
+select '#5795|N' || topology.st_newedgessplit('t5795', 1, st_geomfromtext('POINT(5 0)'));
+select '#5795|E' || edge_id, next_left_edge, next_right_edge, left_face, right_face from t5795.edge_data order by edge_id;
+select '#5795|V1' ||topology.validatetopology('t5795');
+select '#5795|N' || topology.st_newedgessplit('t5795', 4, st_geomfromtext('POINT(10 5)'));
+select '#5795|V2' ||topology.validatetopology('t5795');
+select '#5795|E' || topology.st_addedgenewfaces('t5795', 3, 4, st_geomfromtext('LINESTRING(5 0, 10 5)'));
+select '#5795|V3' ||topology.validatetopology('t5795');
+select '#5795|N' || topology.st_newedgessplit('t5795', 7, st_geomfromtext('POINT(7.5 2.5)'));
+select '#5795|V4' ||topology.validatetopology('t5795');
+select '#5795|N' || topology.st_newedgessplit('t5795', 5, st_geomfromtext('POINT(10 2.5)'));
+select '#5795|V5' || topology.validatetopology('t5795');
+select '#5795|E' || topology.st_addedgenewfaces('t5795', 5, 6, st_geomfromtext('LINESTRING(7.5 2.5, 10 2.5)'));
+select topology.validatetopology('t5795');
+select '#5795|Drop t5795' from (select null from topology.droptopology('t5795')) q;
+select '#5795|Regression test finished';
diff --git a/topology/test/regress/st_newedgessplit_expected b/topology/test/regress/st_newedgessplit_expected
index d02e0bee0..9d9d4abfd 100644
--- a/topology/test/regress/st_newedgessplit_expected
+++ b/topology/test/regress/st_newedgessplit_expected
@@ -36,3 +36,43 @@ seq_reset|1|1|1
robust.1|E1|N3
robust.2|t|t
Topology 'city_data' dropped
+#5795|Regression test starting
+#5795|Create t5795
+#5795|N1
+#5795|N2
+#5795|E1
+#5795|E2
+#5795|N3
+#5795|E2|3|-4|1|0
+#5795|E3|4|-2|1|0
+#5795|E4|2|-3|1|0
+#5795|N4
+#5795|E2|3|-6|1|0
+#5795|E3|5|-2|1|0
+#5795|E5|6|-3|1|0
+#5795|E6|2|-5|1|0
+#5795|E7
+#5795|E2|3|-6|3|0
+#5795|E3|7|-2|3|0
+#5795|E5|-7|-3|2|0
+#5795|E6|2|-5|3|0
+#5795|E7|6|5|3|2
+#5795|N5
+#5795|E2|3|-6|3|0
+#5795|E3|8|-2|3|0
+#5795|E5|-9|-3|2|0
+#5795|E6|2|-5|3|0
+#5795|E8|9|5|3|2
+#5795|E9|6|-8|3|2
+#5795|N6
+#5795|E2|3|-6|3|0
+#5795|E3|8|-2|3|0
+#5795|E6|2|-11|3|0
+#5795|E8|9|10|3|2
+#5795|E9|6|-8|3|2
+#5795|E10|11|-3|2|0
+#5795|E11|-9|-10|2|0
+#5795|E12
+#5795|Drop t5795
+#5795|Regression test finished
Summary of changes:
NEWS | 2 ++
liblwgeom/topo/lwgeom_topo.c | 4 +--
topology/test/regress/st_newedgessplit.sql | 30 +++++++++++++++++++
topology/test/regress/st_newedgessplit_expected | 40 +++++++++++++++++++++++++
4 files changed, 74 insertions(+), 2 deletions(-)
hooks/post-receive
