[PostGIS] #5798: Out of memory: Killed process
trac at osgeo.org
Wed Oct 16 02:25:07 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: 3.4.x
Resolution: | Keywords:
Comment (by strk):
If I understand the message correctly PostgreSQL autovacuum process is
unable to allocate new memory for the TopTransactionContext memory pool.
This isn't necessarely due to a leak, it could also "just" be higher
memory consumption. To find a leak you should run a single process and see
if the memory of that process keeps raising.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5798#comment:7>
