[PostGIS] #5798: Out of memory: Killed process
trac at osgeo.org
Wed Oct 16 03:09:36 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: 3.4.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
Replying to [comment:7 strk]:
> If I understand the message correctly PostgreSQL autovacuum process is
unable to allocate new memory for the TopTransactionContext memory pool.
This isn't necessarely due to a leak, it could also "just" be higher
memory consumption. To find a leak you should run a single process and see
if the memory of that process keeps raising.
This has not been an problem before.
sysctl -w vm.overcommit_memory=0
vm.overcommit_memory = 0
I now run a test with 10 threads in parallel .
And started out with
Wed Oct 16 12:08:54 CEST 2024
total used free shared buff/cache
available
Mem: 125Gi 4.1Gi 100Gi 3.3Gi 20Gi
117Gi
Swap: 7.8Gi 258Mi 7.6Gi
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5798#comment:9>
