[PostGIS] #5790: Postgis-functions in Materialized views fail in Postgres 17 due to not fully qualified search path
trac at osgeo.org
Sat Oct 19 03:00:41 PDT 2024
Reporter: maxbo | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.4
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by mboeringa):
Just wanted to add that I am running into similar issues with a "CREATE
MATERIALIZED VIEW" statement, see the error message below that indicates
the 'spatial_ref_sys' table cannot be found (but it is installed in the
proper 'public' schema location where it always resided). This is PG17 /
PostGIS 3.5.0. If I swap out "CREATE MATERIALIZED VIEW" with "CREATE
TABLE" in the original SQL statement (not included here), the exact same
SQL will work.
SQL Error [42P01]: ERROR: relation "spatial_ref_sys" does not exist
LINE 2: FROM spatial_ref_sys WHERE srid=public.ST_SRID($1);
QUERY: SELECT public.postgis_transform_geometry($1, proj4text, $2, 0)
CONTEXT: SQL function "st_transform" during inlining
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5790#comment:2>
