[PostGIS] #5800: PROJ compiled with version seems to be reading the wrong minor version
PostGIS trac at osgeo.org
Sun Oct 20 19:52:18 PDT 2024
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.5.1
Component:  postgis  |    Version:  3.5.x
 Keywords:           |
 I'm not sure if this is a bug in packaging or something about how we are
 reading proj versions.
 I ran an apt update && apt upgrade pn one of my ubuntu noble servers that
 I had installed PostgreSQL 17 on.
 To my great delight, the PostGIS version changed from 3.4.3 to 3.5.0.
 Before doing my SELECT postgis_extensions_upgrade() dance, the output of
 SELECT postgis_full_version();
 Looked like this:
 POSTGIS="3.5.0 d2c3ca4" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1"
 SFCGAL="SFCGAL 1.5.1, CGAL 5.6, BOOST 1.83.0" PROJ="9.4.0
 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
 GDAL="GDAL 3.8.4, released 2024/02/08" LIBXML="2.9.14" LIBJSON="0.17"
 LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)" (core procs from "3.4.3
 e365945" need upgrade) TOPOLOGY (topology procs from "3.4.3 e365945" need
 upgrade) RASTER (raster procs from "3.4.3 e365945" need upgrade) (sfcgal
 of course no surprise there since the compiled with version feature is new
 in PostGIS 3.5.0.
 But once I ran
 SELECT postgis_extensions_upgrade();
 The version output shows:
 (compiled against PROJ 9.12.1) GDAL="GDAL 3.8.4, released 2024/02/08"
 LIBXML="2.9.14" LIBJSON="0.17" LIBPROTOBUF="1.4.1" WAGYU="0.5.0
 (Internal)" TOPOLOGY RASTER
 I checked https://proj.org/en/9.5/download.html
 and I see no version 9.12.1.  Latest version available is 9.5.
 So where is this 9.12.1 reading coming from.
 I thought maybe it's some sort of artifact of how ubuntu postgis is
 packaged, so I went to check my windows build.  Guess what it shows the
 same bizarro difference.  I haven't looked at the code, but based on
 looking at the 12 and 13s, it looks like it might be reading the Proj
 major version and the GEOS minor version and ascribing in to proj.  So
 that would explain the 13 in my windows case since I compile against GEOS
 3.13 and the 12 in the ubuntu which is going against GEOS 3.12
 POSTGIS="3.5.0 3.5.0" [EXTENSION] PGSQL="150" GEOS="3.13.0-CAPI-1.19.0"
 SFCGAL="SFCGAL 1.5.2, CGAL 5.6.1, BOOST 1.84.0" PROJ="8.2.1
 USER_WRITABLE_DIRECTORY=C:\Users\Administrator\AppData\Local/proj
 DATABASE_PATH=C:\Program
 Files\PostgreSQL\16\share\contrib\postgis-3.5\proj\proj.db" (compiled
 against PROJ 8.13.0) GDAL="GDAL 3.9.2, released 2024/08/13"
 LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5800>
