[SCM] PostGIS branch master updated. 3.5.0-30-gf8b6beb84
git at osgeo.org
git at osgeo.org
Tue Oct 22 14:29:07 PDT 2024
the project "PostGIS".
via f8b6beb840c6beefd8d61d5d6ff7574d0ae2e63f (commit)
via db1750887985f849c1fbffbb8cfcd040307f38da (commit)
via 8939d501c9a22a5cfe9add9acb3a0e4d729a0d1b (commit)
via 6bd6cf8e34e4c118d8633b0ee6f16e23d619a2c8 (commit)
via d2860f337cea095b01346307cdaa026460d525ad (commit)
from b5fbbdd742effd92bca5f235c22c4fcc39d99c34 (commit)
revisions in full, below.
commit f8b6beb840c6beefd8d61d5d6ff7574d0ae2e63f
Merge: b5fbbdd74 db1750887
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Oct 22 14:29:03 2024 -0700
Merge branch 'justsml-docs/fix-kmeans-args'
commit db1750887985f849c1fbffbb8cfcd040307f38da
Author: Regina Obe <lr at pcorp.us>
Date: Tue Oct 22 12:01:58 2024 -0400
MISSING SCHEMA qualifications
- Schema qualify all uses of spatial_ref_sys
and postgis functions in postgis.sql.in script
- Schema qualify postgis and raster functions
and types in rtpostgis.sql.in
References #5790 for PostGIS 3.6.0
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index b45ac89ae..6b492a2d7 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2404,7 +2404,7 @@ BEGIN
RAISE EXCEPTION 'AddGeometryColumn() - SRID must be <= %', SRID_USR_MAX;
END IF;
new_srid := new_srid_in;
- SELECT SRID INTO sr FROM spatial_ref_sys WHERE SRID = new_srid;
+ SELECT SRID INTO sr FROM @extschema at .spatial_ref_sys WHERE SRID = new_srid;
IF NOT FOUND THEN
RAISE EXCEPTION 'AddGeometryColumn() - invalid SRID';
RETURN 'fail';
@@ -2761,7 +2761,7 @@ BEGIN
-- Ensure that new_srid is valid
IF ( new_srid > 0 ) THEN
- IF ( SELECT count(*) = 0 from spatial_ref_sys where srid = new_srid ) THEN
+ IF ( SELECT count(*) = 0 from @extschema at .spatial_ref_sys where srid = new_srid ) THEN
RAISE EXCEPTION 'invalid SRID: % not found in spatial_ref_sys', new_srid;
RETURN false;
END IF;
@@ -2971,7 +2971,7 @@ CREATE OR REPLACE FUNCTION ST_Transform(geometry,integer)
CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, to_proj text)
RETURNS geometry AS
'SELECT @extschema at .postgis_transform_geometry($1, proj4text, $2, 0)
- FROM spatial_ref_sys WHERE srid=@extschema at .ST_SRID($1);'
+ FROM @extschema at .spatial_ref_sys WHERE srid=@extschema at .ST_SRID($1);'
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE
_COST_HIGH;
@@ -2986,7 +2986,7 @@ CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, from_proj text, to_proj t
CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, from_proj text, to_srid integer)
RETURNS geometry AS
'SELECT @extschema at .postgis_transform_geometry($1, $2, proj4text, $3)
- FROM spatial_ref_sys WHERE srid=$3;'
+ FROM @extschema at .spatial_ref_sys WHERE srid=$3;'
_COST_HIGH;
@@ -3875,7 +3875,7 @@ CREATE OR REPLACE FUNCTION ST_SymDifference(geom1 geometry, geom2 geometry, grid
-- Availability: 1.2.2
CREATE OR REPLACE FUNCTION ST_SymmetricDifference(geom1 geometry, geom2 geometry)
RETURNS geometry
- AS 'SELECT ST_SymDifference(geom1, geom2, -1.0);'
+ AS 'SELECT @extschema at .ST_SymDifference(geom1, geom2, -1.0);'
LANGUAGE 'sql';
CREATE OR REPLACE FUNCTION ST_Union(geom1 geometry, geom2 geometry)
@@ -6958,7 +6958,7 @@ CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFA
-- Availability: 2.3.0
-- has to be here because need ST_StartPoint
CREATE OR REPLACE FUNCTION ST_Angle(line1 geometry, line2 geometry)
- RETURNS float8 AS 'SELECT ST_Angle(St_StartPoint($1), ST_EndPoint($1), St_StartPoint($2), ST_EndPoint($2))'
+ RETURNS float8 AS 'SELECT @extschema at .ST_Angle(@extschema at .St_StartPoint($1), @extschema at .ST_EndPoint($1), @extschema at .ST_StartPoint($2), @extschema at .ST_EndPoint($2))'
_COST_LOW;
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 9546fcbfc..c5e66c7a3 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -341,7 +341,7 @@ CREATE OR REPLACE FUNCTION st_makeemptyraster(width int, height int, upperleftx
CREATE OR REPLACE FUNCTION st_makeemptyraster(width int, height int, upperleftx float8, upperlefty float8, pixelsize float8)
RETURNS raster
- AS $$ SELECT @extschema at .ST_makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0, @extschema at .ST_SRID('POINT(0 0)'::geometry)) $$
+ AS $$ SELECT @extschema at .ST_makeemptyraster($1, $2, $3, $4, $5, -($5), 0, 0, @extschema at .ST_SRID('POINT(0 0)'::@extschema at .geometry)) $$
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE;
CREATE OR REPLACE FUNCTION st_makeemptyraster(rast raster)
@@ -389,7 +389,7 @@ CREATE OR REPLACE FUNCTION st_addband(
nodataval float8 DEFAULT NULL
RETURNS raster
- AS $$ SELECT @extschema at .ST_addband($1, ARRAY[ROW($2, $3, $4, $5)]::addbandarg[]) $$
+ AS $$ SELECT @extschema at .ST_addband($1, ARRAY[ROW($2, $3, $4, $5)]::@extschema at .addbandarg[]) $$
LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
-- This function can not be STRICT, because nodataval can be NULL indicating that no nodata value should be set
@@ -400,7 +400,7 @@ CREATE OR REPLACE FUNCTION st_addband(
RETURNS raster
- AS $$ SELECT @extschema at .ST_addband($1, ARRAY[ROW(NULL, $2, $3, $4)]::addbandarg[]) $$
+ AS $$ SELECT @extschema at .ST_addband($1, ARRAY[ROW(NULL, $2, $3, $4)]::@extschema at .addbandarg[]) $$
-- This function can not be STRICT, because torastindex can not be determined (could be st_numbands(raster) though)
@@ -458,7 +458,7 @@ CREATE OR REPLACE FUNCTION st_band(rast raster, nband int)
CREATE OR REPLACE FUNCTION st_band(rast raster, nbands text, delimiter char DEFAULT ',')
RETURNS RASTER
- AS $$ SELECT @extschema at .ST_band($1, regexp_split_to_array(regexp_replace($2, '[[:space:]]', '', 'g'), E'\\' || array_to_string(regexp_split_to_array($3, ''), E'\\'))::int[]) $$
+ AS $$ SELECT @extschema at .ST_band($1, pg_catalog.regexp_split_to_array(pg_catalog.regexp_replace($2, '[[:space:]]', '', 'g'), E'\\' || pg_catalog.array_to_string(pg_catalog.regexp_split_to_array($3, ''), E'\\'))::int[]) $$
@@ -1347,12 +1347,12 @@ CREATE OR REPLACE FUNCTION st_reclass(rast raster, VARIADIC reclassargset reclas
-- Cannot be strict as "nodataval" can be NULL
CREATE OR REPLACE FUNCTION st_reclass(rast raster, nband int, reclassexpr text, pixeltype text, nodataval double precision DEFAULT NULL)
RETURNS raster
- AS $$ SELECT st_reclass($1, ROW($2, $3, $4, $5)) $$
+ AS $$ SELECT @extschema at .st_reclass($1, ROW($2, $3, $4, $5)) $$
CREATE OR REPLACE FUNCTION st_reclass(rast raster, reclassexpr text, pixeltype text)
RETURNS raster
- AS $$ SELECT st_reclass($1, ROW(1, $2, $3, NULL)) $$
+ AS $$ SELECT @extschema at .st_reclass($1, ROW(1, $2, $3, NULL)) $$
@@ -1565,7 +1565,7 @@ CREATE OR REPLACE FUNCTION st_astiff(rast raster, options text[] DEFAULT NULL, s
-- Cannot be strict as "options" and "srid" can be NULL
CREATE OR REPLACE FUNCTION st_astiff(rast raster, nbands int[], options text[] DEFAULT NULL, srid integer DEFAULT NULL)
RETURNS bytea
- AS $$ SELECT st_astiff(st_band($1, $2), $3, $4) $$
+ AS $$ SELECT @extschema at .st_astiff(@extschema at .st_band($1, $2), $3, $4) $$
-- Cannot be strict as "srid" can be NULL
@@ -1656,7 +1656,7 @@ CREATE OR REPLACE FUNCTION st_astiff(rast raster, compression text, srid integer
CREATE OR REPLACE FUNCTION st_astiff(rast raster, nbands int[], compression text, srid integer DEFAULT NULL)
RETURNS bytea
@@ -1675,13 +1675,13 @@ CREATE OR REPLACE FUNCTION st_asjpeg(rast raster, options text[] DEFAULT NULL)
RETURN NULL;
END IF;
- num_bands := st_numbands($1);
+ num_bands := @extschema at .st_numbands($1);
-- JPEG allows 1 or 3 bands
IF num_bands <> 1 AND num_bands <> 3 THEN
RAISE NOTICE 'The JPEG format only permits one or three bands. The first band will be used.';
- rast2 := st_band(rast, ARRAY[1]);
- num_bands := st_numbands(rast);
+ rast2 := @extschema at .st_band(rast, ARRAY[1]);
+ num_bands := @extschema at .st_numbands(rast);
ELSE
rast2 := rast;
END IF;
@@ -1693,14 +1693,14 @@ CREATE OR REPLACE FUNCTION st_asjpeg(rast raster, options text[] DEFAULT NULL)
END IF;
END LOOP;
- RETURN st_asgdalraster(rast2, 'JPEG', $2, NULL);
+ RETURN @extschema at .st_asgdalraster(rast2, 'JPEG', $2, NULL);
END;
$$ LANGUAGE 'plpgsql' IMMUTABLE PARALLEL SAFE;
-- Cannot be strict as "options" can be NULL
CREATE OR REPLACE FUNCTION st_asjpeg(rast raster, nbands int[], options text[] DEFAULT NULL)
RETURNS bytea
- AS $$ SELECT st_asjpeg(st_band($1, $2), $3) $$
+ AS $$ SELECT @extschema at .st_asjpeg(@extschema at .st_band($1, $2), $3) $$
CREATE OR REPLACE FUNCTION st_asjpeg(rast raster, nbands int[], quality int)
@@ -1722,7 +1722,7 @@ CREATE OR REPLACE FUNCTION st_asjpeg(rast raster, nbands int[], quality int)
options := array_append(options, 'QUALITY=' || quality2);
END IF;
- RETURN @extschema at .st_asjpeg(st_band($1, $2), options);
+ RETURN @extschema at .st_asjpeg(@extschema at .st_band($1, $2), options);
END;
$$ LANGUAGE 'plpgsql' IMMUTABLE STRICT PARALLEL SAFE;
@@ -1802,13 +1802,13 @@ CREATE OR REPLACE FUNCTION st_aspng(rast raster, nbands int[], compression int)
options := array_append(options, 'ZLEVEL=' || compression2);
END IF;
- RETURN @extschema at .st_aspng(st_band($1, $2), options);
+ RETURN @extschema at .st_aspng(@extschema at .st_band($1, $2), options);
END;
CREATE OR REPLACE FUNCTION st_aspng(rast raster, nband int, options text[] DEFAULT NULL)
RETURNS bytea
- AS $$ SELECT @extschema at .st_aspng(st_band($1, $2), $3) $$
+ AS $$ SELECT @extschema at .st_aspng(@extschema at .st_band($1, $2), $3) $$
CREATE OR REPLACE FUNCTION st_aspng(rast raster, nband int, compression int)
@@ -2713,7 +2713,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebra(
VARIADIC userargs text[] DEFAULT NULL
RETURNS raster
- AS $$ SELECT @extschema at ._ST_MapAlgebra(ARRAY[ROW($1, $2)]::rastbandarg[], $3, $4, $7, $8, $5, $6,NULL::double precision [],NULL::boolean, VARIADIC $9) $$
+ AS $$ SELECT @extschema at ._ST_MapAlgebra(ARRAY[ROW($1, $2)]::@extschema at .rastbandarg[], $3, $4, $7, $8, $5, $6,NULL::double precision [],NULL::boolean, VARIADIC $9) $$
@@ -2726,7 +2726,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebra(
RETURNS raster
- AS $$ SELECT @extschema at ._ST_MapAlgebra(ARRAY[ROW($1, $2), ROW($3, $4)]::rastbandarg[], $5, $6, $9, $10, $7, $8,NULL::double precision [],NULL::boolean, VARIADIC $11) $$
+ AS $$ SELECT @extschema at ._ST_MapAlgebra(ARRAY[ROW($1, $2), ROW($3, $4)]::@extschema at .rastbandarg[], $5, $6, $9, $10, $7, $8,NULL::double precision [],NULL::boolean, VARIADIC $11) $$
@@ -2739,7 +2739,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebra(
RETURNS raster
AS $$
- select @extschema at ._ST_mapalgebra(ARRAY[ROW($1,$2)]::rastbandarg[],$3,$6,NULL::integer,NULL::integer,$7,$8,$4,$5,VARIADIC $9)
+ select @extschema at ._ST_mapalgebra(ARRAY[ROW($1,$2)]::@extschema at .rastbandarg[],$3,$6,NULL::integer,NULL::integer,$7,$8,$4,$5,VARIADIC $9)
$$ LANGUAGE 'sql' IMMUTABLE PARALLEL SAFE;
@@ -2763,7 +2763,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebra(
expression text, nodataval double precision DEFAULT NULL
RETURNS raster
- AS $$ SELECT @extschema at ._ST_mapalgebra(ARRAY[ROW($1, $2)]::rastbandarg[], $4, $3, 'FIRST', $5::text) $$
+ AS $$ SELECT @extschema at ._ST_mapalgebra(ARRAY[ROW($1, $2)]::@extschema at .rastbandarg[], $4, $3, 'FIRST', $5::text) $$
@@ -2784,7 +2784,7 @@ CREATE OR REPLACE FUNCTION st_mapalgebra(
nodatanodataval double precision DEFAULT NULL
RETURNS raster
- AS $$ SELECT @extschema at ._ST_mapalgebra(ARRAY[ROW($1, $2), ROW($3, $4)]::rastbandarg[], $5, $6, $7, $8, $9, $10) $$
+ AS $$ SELECT @extschema at ._ST_mapalgebra(ARRAY[ROW($1, $2), ROW($3, $4)]::@extschema at .rastbandarg[], $5, $6, $7, $8, $9, $10) $$
@@ -3717,7 +3717,7 @@ CREATE OR REPLACE FUNCTION st_aspect(
SELECT width, height INTO _width, _height FROM @extschema at .ST_Metadata(_rast);
RETURN @extschema at .ST_MapAlgebra(
- ARRAY[ROW(_rast, _nband)]::rastbandarg[],
+ ARRAY[ROW(_rast, _nband)]::@extschema at .rastbandarg[],
' @extschema at ._ST_aspect4ma(double precision[][][], integer[][], text[])'::regprocedure,
_pixtype,
_extenttype, _customextent,
@@ -3912,7 +3912,7 @@ CREATE OR REPLACE FUNCTION st_hillshade(
IF interpolate_nodata IS TRUE THEN
_rast := @extschema at .ST_MapAlgebra(
- ARRAY[ROW(rast, nband)]::rastbandarg[],
+ ARRAY[ROW(rast, nband)]::@extschema at .rastbandarg[],
'@extschema at .st_invdistweight4ma(double precision[][][], integer[][], text[])'::regprocedure,
pixeltype,
'FIRST', NULL,
@@ -3932,7 +3932,7 @@ CREATE OR REPLACE FUNCTION st_hillshade(
SELECT width, height, scalex INTO _width, _height FROM @extschema at .ST_Metadata(_rast);
' @extschema at ._ST_hillshade4ma(double precision[][][], integer[][], text[])'::regprocedure,
_pixtype,
@@ -4223,7 +4223,7 @@ CREATE OR REPLACE FUNCTION st_roughness(
END IF;
' @extschema at ._ST_roughness4ma(double precision[][][], integer[][], text[])'::regprocedure,
_pixtype,
@@ -4443,14 +4443,14 @@ CREATE OR REPLACE FUNCTION st_grayscale(
_NODATA integer DEFAULT 255;
_PIXTYPE text DEFAULT '8BUI';
- _set rastbandarg[];
+ _set @extschema at .rastbandarg[];
nrast integer;
idx integer;
rast @extschema at .raster;
nband integer;
- stats summarystats;
+ stats @extschema at .summarystats;
nodata double precision;
nodataval integer;
reclassexpr text;
@@ -4649,7 +4649,7 @@ CREATE OR REPLACE FUNCTION st_value(rast raster, band integer, pt geometry, excl
CREATE OR REPLACE FUNCTION st_value(rast raster, x integer, y integer, exclude_nodata_value boolean DEFAULT TRUE)
RETURNS float8
- AS $$ SELECT st_value($1, 1::integer, $2, $3, $4) $$
+ AS $$ SELECT @extschema at .st_value($1, 1::integer, $2, $3, $4) $$
LANGUAGE 'sql' IMMUTABLE STRICT PARALLEL SAFE _COST_MEDIUM;
-- Availability: 2.0.0
@@ -5197,7 +5197,7 @@ CREATE OR REPLACE FUNCTION st_pixelaspoints(
CREATE OR REPLACE FUNCTION st_pixelaspoint(rast raster, x integer, y integer)
RETURNS geometry
- AS $$ SELECT ST_PointN(ST_ExteriorRing(geom), 1) FROM @extschema at ._ST_pixelaspolygons($1, NULL, $2, $3) $$
+ AS $$ SELECT @extschema at .ST_PointN(@extschema at .ST_ExteriorRing(geom), 1) FROM @extschema at ._ST_pixelaspolygons($1, NULL, $2, $3) $$
@@ -6344,7 +6344,7 @@ CREATE OR REPLACE FUNCTION ST_Intersection(geomin geometry, rast raster, band in
SELECT
emptygeom,
NULL::float8
- FROM ST_GeomCollFromText('GEOMETRYCOLLECTION EMPTY', ST_SRID($1)) emptygeom;
+ FROM @extschema at .ST_GeomCollFromText('GEOMETRYCOLLECTION EMPTY', @extschema at .ST_SRID($1)) emptygeom;
END IF;
END;
@@ -6381,8 +6381,8 @@ CREATE OR REPLACE FUNCTION ST_Intersection(
RAISE EXCEPTION 'The two rasters do not have the same SRID';
END IF;
- newnodata1 := coalesce(nodataval[1], ST_BandNodataValue(rast1, band1), ST_MinPossibleValue(@extschema at .ST_BandPixelType(rast1, band1)));
- newnodata2 := coalesce(nodataval[2], ST_BandNodataValue(rast2, band2), ST_MinPossibleValue(@extschema at .ST_BandPixelType(rast2, band2)));
+ newnodata1 := coalesce(nodataval[1], @extschema at .ST_BandNodataValue(rast1, band1), @extschema at .ST_MinPossibleValue(@extschema at .ST_BandPixelType(rast1, band1)));
+ newnodata2 := coalesce(nodataval[2], @extschema at .ST_BandNodataValue(rast2, band2), @extschema at .ST_MinPossibleValue(@extschema at .ST_BandPixelType(rast2, band2)));
_returnband := upper(returnband);
@@ -6396,9 +6396,9 @@ CREATE OR REPLACE FUNCTION ST_Intersection(
rtn := @extschema at .ST_SetBandNodataValue(rtn, 1, newnodata2);
WHEN _returnband = 'BOTH' THEN
rtn := @extschema at .ST_MapAlgebraExpr(rast1, band1, rast2, band2, '[rast1.val]', @extschema at .ST_BandPixelType(rast1, band1), 'INTERSECTION', newnodata1::text, newnodata1::text, newnodata1);
- rtn := ST_SetBandNodataValue(rtn, 1, newnodata1);
- rtn := ST_AddBand(rtn, ST_MapAlgebraExpr(rast1, band1, rast2, band2, '[rast2.val]', @extschema at .ST_BandPixelType(rast2, band2), 'INTERSECTION', newnodata2::text, newnodata2::text, newnodata2));
- rtn := ST_SetBandNodataValue(rtn, 2, newnodata2);
+ rtn := @extschema at .ST_SetBandNodataValue(rtn, 1, newnodata1);
+ rtn := @extschema at .ST_AddBand(rtn, @extschema at .ST_MapAlgebraExpr(rast1, band1, rast2, band2, '[rast2.val]', @extschema at .ST_BandPixelType(rast2, band2), 'INTERSECTION', newnodata2::text, newnodata2::text, newnodata2));
+ rtn := @extschema at .ST_SetBandNodataValue(rtn, 2, newnodata2);
ELSE
RAISE EXCEPTION 'Unknown value provided for returnband: %', returnband;
RETURN NULL;
@@ -6415,7 +6415,7 @@ CREATE OR REPLACE FUNCTION st_intersection(
RETURNS raster AS
- $$ SELECT st_intersection($1, $2, $3, $4, $5, ARRAY[$6, $6]) $$
+ $$ SELECT @extschema at .st_intersection($1, $2, $3, $4, $5, ARRAY[$6, $6]) $$
@@ -6424,7 +6424,7 @@ CREATE OR REPLACE FUNCTION st_intersection(
nodataval double precision[]
RETURNS raster AS
- $$ SELECT st_intersection($1, $2, $3, $4, 'BOTH', $5) $$
+ $$ SELECT @extschema at .st_intersection($1, $2, $3, $4, 'BOTH', $5) $$
@@ -6433,7 +6433,7 @@ CREATE OR REPLACE FUNCTION st_intersection(
RETURNS raster AS
- $$ SELECT st_intersection($1, $2, $3, $4, 'BOTH', ARRAY[$5, $5]) $$
+ $$ SELECT @extschema at .st_intersection($1, $2, $3, $4, 'BOTH', ARRAY[$5, $5]) $$
-- Variants without band number
@@ -6444,7 +6444,7 @@ CREATE OR REPLACE FUNCTION st_intersection(
nodataval double precision[] DEFAULT NULL
RETURNS raster AS
- $$ SELECT st_intersection($1, 1, $2, 1, $3, $4) $$
+ $$ SELECT @extschema at .st_intersection($1, 1, $2, 1, $3, $4) $$
@@ -6454,7 +6454,7 @@ CREATE OR REPLACE FUNCTION st_intersection(
RETURNS raster AS
- $$ SELECT st_intersection($1, 1, $2, 1, $3, ARRAY[$4, $4]) $$
+ $$ SELECT @extschema at .st_intersection($1, 1, $2, 1, $3, ARRAY[$4, $4]) $$
@@ -6463,7 +6463,7 @@ CREATE OR REPLACE FUNCTION st_intersection(
RETURNS raster AS
- $$ SELECT st_intersection($1, 1, $2, 1, 'BOTH', $3) $$
+ $$ SELECT @extschema at .st_intersection($1, 1, $2, 1, 'BOTH', $3) $$
@@ -6472,7 +6472,7 @@ CREATE OR REPLACE FUNCTION st_intersection(
RETURNS raster AS
- $$ SELECT st_intersection($1, 1, $2, 1, 'BOTH', ARRAY[$3, $3]) $$
+ $$ SELECT @extschema at .st_intersection($1, 1, $2, 1, 'BOTH', ARRAY[$3, $3]) $$
@@ -6691,7 +6691,7 @@ CREATE OR REPLACE FUNCTION st_nearestvalue(
RETURNS double precision
- AS $$ SELECT st_nearestvalue($1, 1, $2, $3) $$
+ AS $$ SELECT @extschema at .st_nearestvalue($1, 1, $2, $3) $$
@@ -6700,7 +6700,7 @@ CREATE OR REPLACE FUNCTION st_nearestvalue(
- AS $$ SELECT st_nearestvalue($1, $2, st_setsrid(st_makepoint(st_rastertoworldcoordx($1, $3, $4), st_rastertoworldcoordy($1, $3, $4)), st_srid($1)), $5) $$
+ AS $$ SELECT @extschema at .st_nearestvalue($1, $2, @extschema at .st_setsrid(@extschema at .st_makepoint(@extschema at .st_rastertoworldcoordx($1, $3, $4), @extschema at .st_rastertoworldcoordy($1, $3, $4)), @extschema at .st_srid($1)), $5) $$
@@ -6709,7 +6709,7 @@ CREATE OR REPLACE FUNCTION st_nearestvalue(
- AS $$ SELECT st_nearestvalue($1, 1, st_setsrid(st_makepoint(st_rastertoworldcoordx($1, $2, $3), st_rastertoworldcoordy($1, $2, $3)), st_srid($1)), $4) $$
+ AS $$ SELECT @extschema at .st_nearestvalue($1, 1, @extschema at .st_setsrid(@extschema at .st_makepoint(@extschema at .st_rastertoworldcoordx($1, $2, $3), @extschema at .st_rastertoworldcoordy($1, $2, $3)), @extschema at .st_srid($1)), $4) $$
@@ -6759,21 +6759,21 @@ CREATE OR REPLACE FUNCTION st_neighborhood(
wy double precision;
rtn double precision[][];
BEGIN
- IF (st_geometrytype($3) != 'ST_Point') THEN
+ IF (@extschema at .st_geometrytype($3) != 'ST_Point') THEN
RAISE EXCEPTION 'Attempting to get the neighbor of a pixel with a non-point geometry';
END IF;
- IF ST_SRID(rast) != ST_SRID(pt) THEN
+ IF @extschema at .ST_SRID(rast) != @extschema at .ST_SRID(pt) THEN
RAISE EXCEPTION 'Raster and geometry do not have the same SRID';
END IF;
- wx := st_x($3);
- wy := st_y($3);
+ wx := @extschema at .st_x($3);
+ wy := @extschema at .st_y($3);
SELECT @extschema at ._ST_neighborhood(
$1, $2,
- st_worldtorastercoordx(rast, wx, wy),
- st_worldtorastercoordy(rast, wx, wy),
+ @extschema at .st_worldtorastercoordx(rast, wx, wy),
+ @extschema at .st_worldtorastercoordy(rast, wx, wy),
$4, $5,
$6
) INTO rtn;
@@ -6788,7 +6788,7 @@ CREATE OR REPLACE FUNCTION st_neighborhood(
RETURNS double precision[][]
- AS $$ SELECT st_neighborhood($1, 1, $2, $3, $4, $5) $$
+ AS $$ SELECT @extschema at .st_neighborhood($1, 1, $2, $3, $4, $5) $$
@@ -6883,7 +6883,7 @@ CREATE OR REPLACE FUNCTION _add_raster_constraint_srid(rastschema name, rasttabl
cn := 'enforce_srid_' || $3;
- sql := 'SELECT st_srid('
+ sql := 'SELECT @extschema at .st_srid('
|| quote_ident($3)
|| ') FROM ' || fqtn
|| ' WHERE '
@@ -7053,7 +7053,7 @@ CREATE OR REPLACE FUNCTION _add_raster_constraint_blocksize(rastschema name, ras
cn := 'enforce_' || $4 || '_' || $3;
- sql := 'SELECT st_' || $4 || '('
+ sql := 'SELECT @extschema at .st_' || $4 || '('
|| quote_ident($3)
|| ') FROM ' || fqtn
|| ' GROUP BY 1 ORDER BY count(*) DESC';
@@ -7545,7 +7545,7 @@ CREATE OR REPLACE FUNCTION _add_raster_constraint_pixel_types(rastschema name, r
sql := 'ALTER TABLE ' || fqtn
|| ' ADD CONSTRAINT ' || quote_ident(cn)
- || ' CHECK (_raster_constraint_pixel_types(' || quote_ident($3)
+ || ' CHECK (@extschema at ._raster_constraint_pixel_types(' || quote_ident($3)
FOR x in 1..max LOOP
sql := sql || '"' || attr[x] || '"';
@@ -7633,7 +7633,7 @@ CREATE OR REPLACE FUNCTION _add_raster_constraint_nodata_values(rastschema name,
- || ' CHECK (_raster_constraint_nodata_values(' || quote_ident($3)
+ || ' CHECK (@extschema at ._raster_constraint_nodata_values(' || quote_ident($3)
|| ')::numeric[] = ''{';
IF attr[x] IS NULL THEN
@@ -8251,7 +8251,7 @@ CREATE OR REPLACE FUNCTION DropRasterConstraints (
extent boolean DEFAULT TRUE
RETURNS boolean AS
- $$ SELECT DropRasterConstraints('', $1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14) $$
+ $$ SELECT @extschema at .DropRasterConstraints('', $1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14) $$
LANGUAGE 'sql' VOLATILE STRICT;
@@ -8701,23 +8701,23 @@ BEGIN
-- 2. Loop over each target tile and build it from source tiles
ipx := st_xmin(ext);
- ncols := ceil((st_xmax(ext)-ipx)/sfx/tw);
+ ncols := ceil((@extschema at .st_xmax(ext)-ipx)/sfx/tw);
IF sfy < 0 THEN
- ipy := st_ymax(ext);
- nlins := ceil((st_ymin(ext)-ipy)/sfy/th);
+ ipy := @extschema at .st_ymax(ext);
+ nlins := ceil((@extschema at .st_ymin(ext)-ipy)/sfy/th);
ELSE
- ipy := st_ymin(ext);
- nlins := ceil((st_ymax(ext)-ipy)/sfy/th);
+ ipy := @extschema at .st_ymin(ext);
+ nlins := ceil((@extschema at .st_ymax(ext)-ipy)/sfy/th);
END IF;
- srid := ST_Srid(ext);
+ srid := @extschema at .ST_Srid(ext);
RAISE DEBUG 'Target coverage will have % x % tiles, each of approx size % x %', ncols, nlins, tw, th;
RAISE DEBUG 'Target coverage will cover extent %', ext::box2d;
FOR tx IN 0..ncols-1 LOOP
FOR ty IN 0..nlins-1 LOOP
- te := ST_MakeEnvelope(ipx + tx * tw * sfx,
+ te := @extschema at .ST_MakeEnvelope(ipx + tx * tw * sfx,
ipy + ty * th * sfy,
ipx + (tx+1) * tw * sfx,
ipy + (ty+1) * th * sfy,
@@ -8729,12 +8729,12 @@ BEGIN
|| ' WHERE @extschema at .ST_Intersects(' || quote_ident(col) || ', $3)';
--RAISE DEBUG 'SQL: %', sql;
FOR rec IN EXECUTE sql USING sfx, sfy, te, ipx, ipy, algo LOOP
- --RAISE DEBUG '% source tiles intersect target tile %,% with extent %', rec.count, tx, ty, te::box2d;
+ --RAISE DEBUG '% source tiles intersect target tile %,% with extent %', rec.count, tx, ty, te::@extschema at .box2d;
IF rec.g IS NULL THEN
RAISE WARNING 'No source tiles cover target tile %,% with extent %',
- tx, ty, te::box2d;
+ tx, ty, te::@extschema at .box2d;
ELSE
- --RAISE DEBUG 'Tile for extent % has size % x %', te::box2d, st_width(rec.g), st_height(rec.g);
+ --RAISE DEBUG 'Tile for extent % has size % x %', te::@extschema at .box2d, @extschema at .st_width(rec.g), @extschema at .st_height(rec.g);
RETURN NEXT rec.g;
END IF;
END LOOP;
@@ -8791,7 +8791,7 @@ BEGIN
ttab := 'o_' || factor || '_' || sinfo.tab;
sql := 'CREATE TABLE ' || quote_ident(sinfo.sch)
|| '.' || quote_ident(ttab)
- || ' AS SELECT ST_Retile($1, $2, $3, $4, $5, $6, $7) '
+ || ' AS SELECT @extschema at .ST_Retile($1, $2, $3, $4, $5, $6, $7) '
|| quote_ident(col);
EXECUTE sql USING tab, col, sinfo.ext,
sinfo.sfx * factor, sinfo.sfy * factor,
commit 8939d501c9a22a5cfe9add9acb3a0e4d729a0d1b
Date: Mon Oct 21 11:48:27 2024 -0700
ST_TileEnvelope with margin is not clipped fully to WM extent, references #5799
diff --git a/NEWS b/NEWS
index e035f6c71..7040644c3 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ PostGIS 3.6.0
* Breaking Changes *
+#5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
* Deprecated signatures *
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index c2892ce7e..1f9348c1b 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2143,9 +2143,11 @@ Datum ST_TileEnvelope(PG_FUNCTION_ARGS)
y1 = bbox.ymax - tileGeoSizeY * (y + 1 + margin);
y2 = bbox.ymax - tileGeoSizeY * (y - margin);
- /* Clip y-axis to the given bounds */
+ /* Clip the final tile bounds to the bounds of the tile plane */
if (y1 < bbox.ymin) y1 = bbox.ymin;
if (y2 > bbox.ymax) y2 = bbox.ymax;
+ if (x1 < bbox.xmin) x1 = bbox.xmin;
+ if (x2 > bbox.xmax) x2 = bbox.xmax;
PG_RETURN_POINTER(
geometry_serialize(
diff --git a/regress/core/regress_expected b/regress/core/regress_expected
index bd34c236a..42a03aaaf 100644
--- a/regress/core/regress_expected
+++ b/regress/core/regress_expected
@@ -204,7 +204,7 @@ ERROR: ST_TileEnvelope: Invalid tile y value, 1
234|POLYGON((-100 87.5,-100 100,-87.5 100,-87.5 87.5,-100 87.5))
235|POLYGON((0 -12.5,0 0,25 0,25 -12.5,0 -12.5))
236|POLYGON((-20037508.34 -20037508.34,-20037508.34 20037508.34,20037508.34 20037508.34,20037508.34 -20037508.34,-20037508.34 -20037508.34))
-237|POLYGON((-22041259.18 -2003750.83,-22041259.18 20037508.34,2003750.83 20037508.34,2003750.83 -2003750.83,-22041259.18 -2003750.83))
+237|POLYGON((-20037508.34 -2003750.83,-20037508.34 20037508.34,2003750.83 20037508.34,2003750.83 -2003750.83,-20037508.34 -2003750.83))
238|POLYGON((-15028131.26 -20037508.34,-15028131.26 -5009377.09,5009377.09 -5009377.09,5009377.09 -20037508.34,-15028131.26 -20037508.34))
239|POLYGON((0 0,0 0,0 0,0 0,0 0))
ERROR: ST_TileEnvelope: Margin must not be less than -50%, margin=-0.510000
commit 6bd6cf8e34e4c118d8633b0ee6f16e23d619a2c8
Date: Sun Oct 20 22:57:33 2024 -0400
FIX copy paste error
in postgis_proj_compiled_version
References #5800 for PostGIS 3.6.0
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index 4786474b2..df9cf4e4d 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -237,8 +237,8 @@ Datum postgis_proj_compiled_version(PG_FUNCTION_ARGS)
ver,
"%d.%d.%d",
(POSTGIS_PROJ_VERSION/10000),
- ((POSTGIS_GEOS_VERSION%10000)/100),
- ((POSTGIS_GEOS_VERSION)%100)
+ ((POSTGIS_PROJ_VERSION%10000)/100),
+ ((POSTGIS_PROJ_VERSION)%100)
result = cstring_to_text(ver);
commit d2860f337cea095b01346307cdaa026460d525ad
Author: Dan Levy <397632+justsml at users.noreply.github.com>
Date: Thu Oct 17 20:42:27 2024 -0600
fix parameter name
diff --git a/doc/reference_cluster.xml b/doc/reference_cluster.xml
index cb4b4b8e8..21da74650 100644
--- a/doc/reference_cluster.xml
+++ b/doc/reference_cluster.xml
@@ -291,16 +291,22 @@ FROM testdata;
<refsynopsisdiv>
<funcsynopsis>
<funcprototype>
- <funcdef>integer <function>ST_ClusterKMeans</function></funcdef>
- <paramdef><type>geometry winset </type>
- <parameter>geom</parameter></paramdef>
- <paramdef><type>integer </type>
- <parameter>number_of_clusters</parameter></paramdef>
- <paramdef><type>float </type>
- <parameter>max_radius</parameter></paramdef>
+ <funcdef>integer <function>ST_ClusterKMeans</function></funcdef>
+ <paramdef>
+ <type>geometry winset </type>
+ <parameter>geom</parameter>
+ </paramdef>
+ <paramdef>
+ <type>integer </type>
+ <parameter>k</parameter>
+ </paramdef>
+ <paramdef>
+ <type>float8 </type>
+ <parameter>max_radius</parameter>
+ </paramdef>
</funcprototype>
</funcsynopsis>
</refsynopsisdiv>
Summary of changes:
doc/reference_cluster.xml | 26 ++++++++++++++++----------
1 file changed, 16 insertions(+), 10 deletions(-)
hooks/post-receive
