[PostGIS] #5781: Concave Hull returning multi poly with polygons
trac at osgeo.org
Thu Oct 24 14:56:50 PDT 2024
Reporter: latot | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Changes (by pramsey):
* milestone: PostGIS 3.4.4 => PostGIS GEOS
Comment:
This is 100% a GEOS thing. I'm not Sure precisely how much I care, you
could also decompose the polygons to their points (ST_Points) and run that
against the concave hull function. Depends on what kind of result you are
looking for, if you really want a *polygon* concave hull, rather than a
point-wise one.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5781#comment:3>
