[SCM] postgis.net branch website updated. clarity-final-124-g8e8b0c1
git at osgeo.org
git at osgeo.org
Sun Oct 27 13:38:38 PDT 2024
the project "postgis.net".
The branch, website has been updated
via 8e8b0c156e81f15fc91b3a0c1ff05650be677238 (commit)
from 80bdb68b125bd865bca400fedbf66639514d0167 (commit)
revisions in full, below.
commit 8e8b0c156e81f15fc91b3a0c1ff05650be677238
Author: Regina Obe <lr at pcorp.us>
Date: Sun Oct 27 16:38:34 2024 -0400
Update postgis schema move tip as the old instructions don't work for postgis 3.5+
diff --git a/content/documentation/tips/tip-move-postgis-schema.md b/content/documentation/tips/tip-move-postgis-schema.md
index e64703d..1c3fbe6 100644
--- a/content/documentation/tips/tip-move-postgis-schema.md
+++ b/content/documentation/tips/tip-move-postgis-schema.md
@@ -5,7 +5,7 @@ layout: post
category: tips
tags: [newbie, upgrade]
author: Regina Obe
-date: "2017-11-07"
+date: "2024-10-25"
thumbnail:
geekdocHidden: true
geekdocHiddenTocTree: false
@@ -32,7 +32,9 @@ Now lets create a new schema to move it and add this schema to search_path
CREATE SCHEMA postgis;
ALTER DATABASE mydb
-SET search_path = public,postgis;
+ SET search_path = public,postgis;
+GRANT USAGE ON SCHEMA postgis to public;
If you are running PostGIS 2.3 or higher, trying to move to a different schema
@@ -58,15 +60,27 @@ UPDATE pg_extension
ALTER EXTENSION postgis
SET SCHEMA postgis;
--- Force an upgrade through a dummy version
+-- Force an upgrade toh a dummy version
+-- For PostGIS 3.5.0+ do
- UPDATE TO "2.4.1next";
+ UPDATE TO "ANY";
--- Force a second upgrade to remove references to the dummy version
+-- For PostGIS 3.4 and lower use next
- UPDATE TO "2.4.1";
+ UPDATE TO "3.4.3next";
+-- Force a second upgrade to do the real upgrade
+ALTER EXTENSION postgis UPDATE;
-Note the use of the extension version that includes `next`.
+Note the use of the extension version that includes `next` or `ANY`.
-The `next` version step is needed in order to upgrade all the schema qualified function references to the new schema location. `next` is designed to allow upgrading a postgis extension to a version it is already on.
+The `next` or `ANY` version step is needed in order to upgrade to a version other than current version
+because same version to same version updates aren't allowed by the extension system.
+The final upgrade does the work of upgrading to the latest installed version.
+In the process all functions are reinstalled with the `@extschema@` variable in the scripts
+now referencing the new schema location.
+**NOTE**: if you have postgis_raster installed as well, repeat the same above steps with *postgis_raster*.
+postgis_raster will not work properly unless it is installed in the same schema as postgis.
\ No newline at end of file
Summary of changes:
.../documentation/tips/tip-move-postgis-schema.md | 30 ++++++++++++++++------
1 file changed, 22 insertions(+), 8 deletions(-)
hooks/post-receive
postgis.net
