[PostGIS] #5802: CREATE OPERATOR = not marked as changed
PostGIS trac at osgeo.org
Sun Oct 27 14:23:44 PDT 2024
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  medium   |  Milestone:  PostGIS 3.5.1
Component:  postgis  |    Version:  3.5.x
 Keywords:           |
 I just noticed when comparing 3.4 with 3.5, that the
 OPERATOR = was changed in 3.5.0, but this was not marked as such, so
 migrations from 3.4 to 3.5 will not pick this up.
 e.g.
 3.4 has signature:
 CREATE OPERATOR = (
         LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_eq,
         COMMUTATOR = '=', -- we might implement a faster negator here
         RESTRICT = contsel, JOIN = contjoinsel, HASHES, MERGES
 and 3.5 has signature and addition of <> operator
 CREATE OPERATOR = (
         COMMUTATOR = '=', NEGATOR = '<>',
 -- Availability: 3.5.0
 CREATE OPERATOR <> (
         LEFTARG = geometry, RIGHTARG = geometry, PROCEDURE = geometry_neq,
         COMMUTATOR = '<>', NEGATOR = '=',
 I have to confirm that our upgrade machinery is smart enough to handle
 this too if we mark it as changed in 3.5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5802>
