[PostGIS] #1247: [raster] ST_AsRaster aggregate function
trac at osgeo.org
Tue Oct 29 02:04:24 PDT 2024
Reporter: robe | Owner: strk
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.6.0
Component: raster | Version: master
Resolution: | Keywords:
Description changed by strk:
Old description:
> Pierre,
> Not sure if this is what you had in mind when you said "Burn In" function
> in your talk. A common need I have which I am sure is that of many BI
> analysts is the need to show simple thematic maps in reports.
> What came to mind to me was an aggregate ST_AsRaster function that takes
> a set of geomval rows (or multicolumn geom, value) and builds a raster.
> Basically a reverse of the ST_DumpAsPolgons function.
> http://www.postgis.org/documentation/manual-svn/RT_ST_AsRaster.html
> This would make it trivial to do a query such as
> SELECT ST_AsPNG(ST_AsRaster(gval),300,300) As mymap
> FROM (SELECT ROW(ST_Union(geom), SUM(pop))::geomval As gval
> FROM sumregion
> GROUP BY region_name) As foo;
> Which is big considering many report writers allow their picture box
> controls to be bound to query fields. We might have a new crowd of BI
> analysts looking to get a piece of PostGIS action.
New description:
Pierre,
What came to mind to me was an aggregate [https://www.postgis.net/docs
/manual-dev/RT_ST_AsRaster.html ST_AsRaster] function that takes a set of
geomval rows (or multicolumn geom, value) and builds a raster. Basically
a reverse of the [https://www.postgis.net/docs/manual-
dev/RT_ST_DumpAsPolygons.html ST_DumpAsPolgons] function.
FROM sumregion
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1247#comment:7>
