[SCM] PostGIS branch master updated. 3.5.0-36-gd0e53a54a
Tue Oct 29 14:56:58 PDT 2024
the project "PostGIS".
       via  d0e53a54a10cac4fd4128c2c17f86304a8ef2c66 (commit)
      from  fc88b11cdbf25999c7f1510cf7e26d40e8a9dfd3 (commit)
revisions in full, below.
commit d0e53a54a10cac4fd4128c2c17f86304a8ef2c66
Author: Nikolai B <nikolai-b at users.noreply.github.com>
Date:   Tue Sep 24 12:20:08 2024 +0100
    - doc: unify gdal_enabled_drivers and enable_outdb_rasters
    - RO: add PostgreSQL manual links
    Closes https://github.com/postgis/postgis/pull/779
diff --git a/doc/reference_guc.xml b/doc/reference_guc.xml
index 4efc5b0c5..71dd16bf7 100644
--- a/doc/reference_guc.xml
+++ b/doc/reference_guc.xml
@@ -149,30 +149,25 @@ SET postgis.gdal_datapath = 'C:/Program Files/PostgreSQL/9.3/gdal-data';</progra
             <refsection>
                 <title>Examples</title>
-                <para>Set and reset <varname>postgis.gdal_enabled_drivers</varname></para>
-                <para>Sets backend for all new connections to database</para>
-                <programlisting>ALTER DATABASE mygisdb SET postgis.gdal_enabled_drivers TO 'GTiff PNG JPEG';</programlisting>
-                <para>Sets default enabled drivers for all new connections to server. Requires super user access and PostgreSQL 9.4+.
-                    Also note that database, session, and user settings override this.</para>
-                <programlisting>ALTER SYSTEM SET postgis.gdal_enabled_drivers TO 'GTiff PNG JPEG';
-SELECT pg_reload_conf();
-                </programlisting>
+                <para>To set and reset <varname>postgis.gdal_enabled_drivers</varname> for current session</para>
                 <programlisting>
-SET postgis.gdal_enabled_drivers TO 'GTiff PNG JPEG';
+SET postgis.gdal_enabled_drivers = 'ENABLE_ALL';
 SET postgis.gdal_enabled_drivers = default;
                 </programlisting>
-                <para>Enable all GDAL Drivers</para>
-                <programlisting>
-SET postgis.gdal_enabled_drivers = 'ENABLE_ALL';
-                </programlisting>
+                <para>Set for all new connections to a specific database to specific drivers</para>
+                <programlisting>ALTER DATABASE mygisdb SET postgis.gdal_enabled_drivers TO 'GTiff PNG JPEG';</programlisting>
+                <para>Setting for whole database cluster to enable all drivers. Requires super user access.
+                    Also note that database, session, and user settings override this.</para>
-                <para>Disable all GDAL Drivers</para>
                 <programlisting>
-SET postgis.gdal_enabled_drivers = 'DISABLE_ALL';
+ --writes to postgres.auto.conf
+ALTER SYSTEM SET postgis.gdal_enabled_drivers TO 'ENABLE_ALL';
+ --Reloads postgres conf
+SELECT pg_reload_conf();
                 </programlisting>
             </refsection>
@@ -234,16 +229,17 @@ SET postgis.enable_outdb_rasters = True;
 SET postgis.enable_outdb_rasters = False;
                 </programlisting>
-                <para>Set for specific database</para>
+                <para>Set for all new connections to a specific database</para>
                 <programlisting>
 ALTER DATABASE gisdb SET postgis.enable_outdb_rasters = true;
                 </programlisting>
-                <para>Setting for whole database cluster. You need to reconnect to the database for changes to take effect.</para>
+                <para>Setting for whole database cluster. Requires super user access.
                 <programlisting>
-ALTER SYSTEM postgis.enable_outdb_rasters = true;
+ALTER SYSTEM SET postgis.enable_outdb_rasters = true;
                 </programlisting>
Summary of changes:
 doc/reference_guc.xml | 36 ++++++++++++++++--------------------
 1 file changed, 16 insertions(+), 20 deletions(-)
hooks/post-receive
