[PostGIS] #5777: st_intersects() throws exception when using geometrycollection as first argument
trac at osgeo.org
Tue Sep 3 05:37:25 PDT 2024
argument
Reporter: cfischer | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.4.3
Component: postgis | Version: 3.4.x
Resolution: | Keywords: relate st_intersects
| TopologyException
Description changed by cfischer:
Old description:
> PostGIS throws an exception with st_intersects on geometry collection as
> first parameter
> SQL Error [XX000]: ERROR: GEOSIntersects: TopologyException: side
> location conflict at 725217.59322033904 6176386.5423728814. This can
> occur if the input geometry is invalid.
> A have isolated the problem, shown below. The order of the arguments to
> st_intersects appears to be signifikant.
> - geom_1 : is a point
> - geom_2 : is a geometrycollection, containing two triangles
> - geom_3 : is a multipolygon-version of geom_2
> - st_intersects (geom_1, geom_2) -> SUCCESS
> - **st_intersects (geom_2, geom_1) -> FAILS**
> - st_intersects (geom_1, geom_3) -> SUCCESS
> - st_intersects (geom_3, geom_1) -> SUCCESS
> WITH geom_1 AS (
> SELECT st_point(725220, 6176385, 25832) AS geom
> geom_2 AS (
> SELECT
> st_geometryfromtext(
> 'GEOMETRYCOLLECTION (
> POLYGON ((725210 6176386, 725220 6176382, 725224 6176387, 725210
> 6176386)),
> POLYGON ((725215 6176390, 725218 6176386, 725225 6176385, 725215
> 6176390))
> , 25832) AS geom
> geom_3 AS (
> SELECT
> 'MULTIPOLYGON (
> 6176386)),
> 6176390))
> , 25832) AS geom
> SELECT
> FROM
> geom_1
> JOIN geom_2 ON (st_intersects(geom_2.geom, geom_1.geom)) -- fails
> -- JOIN geom_2 ON (st_intersects(geom_1.geom, geom_2.geom)) -- works
> -- JOIN geom_3 ON (st_intersects(geom_1.geom, geom_3.geom)) -- works
> -- JOIN geom_3 ON (st_intersects(geom_3.geom, geom_1.geom)) -- works
New description:
first parameter
SQL Error [XX000]: ERROR: GEOSIntersects: TopologyException: side location
conflict at 725217.59322033904 6176386.5423728814. This can occur if the
WITH geom_1 AS (
geom_2 AS (
SELECT
6176386)),
6176390))
, 25832) AS geom
geom_3 AS (
SELECT
'MULTIPOLYGON (
6176386)),
6176390))
, 25832) AS geom
SELECT
FROM
geom_1
SELECT postgis_full_version();
POSTGIS="3.4.0 0874ea3" [EXTENSION] PGSQL="160" GEOS="3.12.0-CAPI-1.18.0"
PROJ="8.0.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/rdsdbbin/postgres-16.1.R2/share/proj/proj.db"
LIBXML="2.9.1" LIBJSON="0.15" LIBPROTOBUF="1.3.2" WAGYU="0.5.0 (Internal)"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5777#comment:1>
