[SCM] PostGIS branch stable-3.4 updated. 3.4.2-59-gdd88eb5b4
Tue Sep 3 11:00:06 PDT 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  dd88eb5b435daea3525565d1bac66c00798746e5 (commit)
      from  c8bdf2b6fdba896d979b9a8fe0d2867b935ac8bb (commit)
revisions in full, below.
commit dd88eb5b435daea3525565d1bac66c00798746e5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Sep 3 10:59:27 2024 -0700
    Prep for 3.4.3rc1
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index afed140ee..489d95318 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -80,7 +80,7 @@ Release procedure
   - Edit NEWS: set release date and check all notable changes have been reported
     (extract from git log and trac tickets for milestone).
-  - Create milestone for next verison in Trac.
+  - Create milestone for next version in Trac.
   - Push all the open tickets in Trac milestone to future and Fund Me milestones.
 4. Update code.
diff --git a/README.postgis b/README.postgis
index 01651f90d..93069a84a 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.4.2
-:Date: 2024-02-08
+:Version: 3.4.3
+:Date: 2024-09-03
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 8f75c59d0..1cdbf66fd 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=4
-POSTGIS_MICRO_VERSION=3dev
+POSTGIS_MICRO_VERSION=3rc1
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 77c1b0004..c21d184bf 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,33 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+        <sect1>
+            <title>PostGIS 3.4.3</title>
+            <para>2024/09/04</para>
+            <simplesect>
+                <title>Bug Fixes</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5766">5766</ulink>, Always report invalid non-null MBR of universal face (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5709">5709</ulink>, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5698">5698</ulink>, Fix robustness issue splitting line by vertex very close to endpoints, affecting topology population functions (Sandro Santilli) </para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5649">5649</ulink>, ST_Value should return NULL on missing band (Paul Ramsey) </para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5677">5677</ulink>, ST_Union(geom[]) should unary union single entry arrays (Paul Ramsey) </para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5679">5679</ulink>, Remove spurious COMMIT statements from sfcgal script (Sandro Santilli, Loïc Bartoletti)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5680">5680</ulink>, Fix populate_topology_layer with standard_conforming_strings set to off (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5589">5589</ulink>, ST_3DDistance error for shared first point (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5686">5686</ulink>, ST_NumInteriorRings and Triangle crash (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5666">5666</ulink>, Build reproducibility: timestamps in extension upgrade SQL scripts (James Addison)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5671">5671</ulink>, Bug in ST_Area function with use_spheroid=false (Paul Ramsey, Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5687">5687</ulink>, Don't rely on search_path to determine postgis schema. Fix for PG17 security change (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5695">5695</ulink>, [address_standardizer_data_us] standardize_address incorrect handling of directionals (Regina Obe)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5653">5653</ulink>, Do not simplify away points when linestring doubles back on itself (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5720">5720</ulink>, Correctly mangle special column names in shp2pgsql (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5734">5734</ulink>, Estimate geography extent more correctly (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5752">5752</ulink>, ST_ClosestPoint(geography) error (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5740">5740</ulink>, ST_DistanceSpheroid(geometry) incorrectly handles polygons (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5765">5765</ulink>, Handle nearly co-linear edges with slightly less slop (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5745">5745</ulink>, St_AsLatLonText rounding errors (Paul Ramsey)</para>
+            </simplesect>
+        </sect1>
         <sect1>
             <title>PostGIS 3.4.2</title>
             <para>2024/02/08</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 9d9780b07..0d7f09ac2 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -96,4 +96,5 @@ UPGRADEABLE_VERSIONS = \
 	3.3.5 \
 	3.4.0 \
 	3.4.1 \
-	3.4.2
+	3.4.2 \
+	3.4.3dev
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index e9dc77bb5..6f2c9ec01 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -24,7 +24,7 @@
-*  GSERIALIZED verison 2 includes an optional extended flags uint64_t
+*  GSERIALIZED version 2 includes an optional extended flags uint64_t
 *  before the optional bounding box. There may be other optional
 *  components before the data area, but they all must be double
 *  aligned to that the ordinates remain double aligned.
Summary of changes:
 HOWTO_RELEASE                      |  2 +-
 README.postgis                     |  4 ++--
 Version.config                     |  2 +-
 doc/release_notes.xml              | 27 +++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |  3 ++-
 liblwgeom/gserialized2.c           |  2 +-
 6 files changed, 34 insertions(+), 6 deletions(-)
hooks/post-receive
