[SCM] PostGIS branch master updated. 3.5.0alpha2-54-gdea96e48c
Wed Sep 4 02:09:47 PDT 2024
the project "PostGIS".
       via  dea96e48cbc12117593b4c09222d13bdcb63e4d5 (commit)
      from  e33e9c32199df85c7fa40c337fde5e6d15b75ad1 (commit)
revisions in full, below.
commit dea96e48cbc12117593b4c09222d13bdcb63e4d5
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date:   Tue Sep 3 06:56:41 2024 +0200
    utils/check_all_upgrades.sh: Improve shell compatibility and OS detection
    - Add OS detection to use gmake on FreeBSD, Darwin, and OpenBSD
    - Replace 'make' with '${MAKE}' to use the correct make command
    - Fix CURRENTVERSION extraction using tr instead of paste
diff --git a/utils/check_all_upgrades.sh b/utils/check_all_upgrades.sh
index 587ea3eff..ee01e344e 100755
--- a/utils/check_all_upgrades.sh
+++ b/utils/check_all_upgrades.sh
@@ -8,7 +8,7 @@ PGVER=`pg_config --version | awk '{print $2}'`
 PGVER_MAJOR=$(echo "${PGVER}" | sed 's/\.[^\.]*//' | sed 's/\(alpha\|beta\|rc\).*//' )
 SKIP_LABEL_REGEXP=
 echo "INFO: PostgreSQL version: ${PGVER} [${PGVER_MAJOR}]"
+MAKE=$(which gmake make | head -1)
 BUILDDIR=$PWD # TODO: allow override ?
 cd $(dirname $0)/..
@@ -252,7 +252,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     fi
     echo "Testing ${test_label}"
     RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
-    make -C ${REGDIR} check ${MAKE_ARGS} && {
+    ${MAKE} -C ${REGDIR} check ${MAKE_ARGS} && {
       echo "PASS: ${test_label}"
       echo "FAIL: ${test_label}"
@@ -286,7 +286,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     fi
@@ -295,7 +295,8 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
   done
   # Check unpackaged->unpackaged upgrades (if target version == current version)
-  CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
+#  CURRENTVERSION=`grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | paste -sd '.'`
+  CURRENTVERSION=$(grep '^POSTGIS_' ${SRCDIR}/Version.config | cut -d= -f2 | tr '\n' '.')
   if test "${to_version}" != "${CURRENTVERSION}"; then #{
     echo "SKIP: ${EXT} script-based upgrades (${to_version_param} [${to_version}] does not match built version ${CURRENTVERSION})"
@@ -315,7 +316,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
     if kept_label "${test_label}"; then #{
       RUNTESTFLAGS="-v --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
@@ -327,7 +328,7 @@ for EXT in ${INSTALLED_EXTENSIONS}; do #{
       RUNTESTFLAGS="-v --dumprestore --upgrade-path=${UPGRADE_PATH} ${USERTESTFLAGS}" \
Summary of changes:
 utils/check_all_upgrades.sh | 13 +++++++------
 1 file changed, 7 insertions(+), 6 deletions(-)
hooks/post-receive
