[SCM] postgis.net branch website updated. clarity-final-104-g7dbd675
git at osgeo.org
git at osgeo.org
Wed Sep 4 12:51:40 PDT 2024
the project "postgis.net".
The branch, website has been updated
via 7dbd675d86feebe0c52c486209e363fd6883256c (commit)
from fce60eefb52d9756cd2c3da7aa5b753526775f05 (commit)
revisions in full, below.
commit 7dbd675d86feebe0c52c486209e363fd6883256c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Sep 4 12:51:34 2024 -0700
news item for 3.4.3 release
diff --git a/content/news/2024/09-04_postgis-3.4.3.md b/content/news/2024/09-04_postgis-3.4.3.md
new file mode 100644
index 0000000..454cdcd
--- /dev/null
+++ b/content/news/2024/09-04_postgis-3.4.3.md
@@ -0,0 +1,73 @@
+title: PostGIS 3.4.3
+layout: post
+category: news
+tags: [release, 3.4]
+author: Paul Ramsey
+thumbnail:
+date: "2024-09-04"
+The PostGIS Team is pleased to release PostGIS 3.4.3!
+This version requires PostgreSQL 12-17, GEOS 3.8+, and Proj 6.1+.
+To take advantage of all features, GEOS 3.12+ is needed.
+To take advantage of all SFCGAL features, SFCGAL 1.5+ is needed.
+### 3.4.3
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.4.3.tar.gz) [md5]({{< loc "postgis.dev_download">}}/postgis-3.4.3.tar.gz.md5)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.4.3/NEWS)
+* PDF docs: [en]({{< loc "postgis.release_docs">}}/postgis-3.4.3-en.pdf), [ja]({{< loc "postgis.release_docs">}}/postgis-3.4.3-ja.pdf), [fr]({{< loc "postgis.release_docs">}}/postgis-3.4.3-fr.pdf)
+<!--more-->
+### Changes
+ - [#5766](https://trac.osgeo.org/postgis/ticket/5766), Always report invalid non-null MBR of universal face (Sandro Santilli)
+ - [#5709](https://trac.osgeo.org/postgis/ticket/5709), Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)
+ - [#5698](https://trac.osgeo.org/postgis/ticket/5698), Fix robustness issue splitting line by vertex very close to endpoints,
+ affecting topology population functions (Sandro Santilli)
+ - [#5649](https://trac.osgeo.org/postgis/ticket/5649), ST_Value should return NULL on missing band (Paul Ramsey)
+ - [#5677](https://trac.osgeo.org/postgis/ticket/5677), ST_Union(geom[]) should unary union single entry arrays (Paul Ramsey)
+ - [#5679](https://trac.osgeo.org/postgis/ticket/5679), Remove spurious COMMIT statements from sfcgal script
+ (Sandro Santilli, Loïc Bartoletti)
+ - [#5680](https://trac.osgeo.org/postgis/ticket/5680), Fix populate_topology_layer with standard_conforming_strings
+ set to off (Sandro Santilli)
+ - [#5589](https://trac.osgeo.org/postgis/ticket/5589), ST_3DDistance error for shared first point (Paul Ramsey)
+ - [#5686](https://trac.osgeo.org/postgis/ticket/5686), ST_NumInteriorRings and Triangle crash (Paul Ramsey)
+ - [#5666](https://trac.osgeo.org/postgis/ticket/5666), Build reproducibility: timestamps
+ in extension upgrade SQL scripts (James Addison)
+ - [#5671](https://trac.osgeo.org/postgis/ticket/5671), Bug in ST_Area function with use_spheroid=false
+ (Paul Ramsey, Regina Obe)
+ - [#5687](https://trac.osgeo.org/postgis/ticket/5687), Don't rely on search_path to determine postgis schema
+ Fix for PG17 security change (Regina Obe)
+ - [#5695](https://trac.osgeo.org/postgis/ticket/5695), [address_standardizer_data_us] standardize_address
+ incorrect handling of directionals (Regina Obe)
+ - [#5653](https://trac.osgeo.org/postgis/ticket/5653), Do not simplify away points when linestring doubles back on
+ itself (Paul Ramsey)
+ - [#5720](https://trac.osgeo.org/postgis/ticket/5720), Correctly mangle special column names in shp2pgsql (Paul Ramsey)
+ - [#5734](https://trac.osgeo.org/postgis/ticket/5734), Estimate geography extent more correctly (Paul Ramsey)
+ - [#5752](https://trac.osgeo.org/postgis/ticket/5752), ST_ClosestPoint(geography) error (Paul Ramsey)
+ - [#5740](https://trac.osgeo.org/postgis/ticket/5740), ST_DistanceSpheroid(geometry) incorrectly handles polygons (Paul Ramsey)
+ - [#5765](https://trac.osgeo.org/postgis/ticket/5765), Handle nearly co-linear edges with slightly less slop (Paul Ramsey)
+ - [#5745](https://trac.osgeo.org/postgis/ticket/5745), St_AsLatLonText rounding errors (Paul Ramsey)
+### Upgrading
+After installing the binaries or after running `pg_upgrade`:
+For PostGIS 3.4, 3.3, 3.2, 3.1, 3.0
+do below which will upgrade all your postgis extensions.
+```postgres
+SELECT postgis_extensions_upgrade();
+If you come across any issues, feel free to report via our
+[ticket tracker](https://trac.osgeo.org/postgis) or
+[mailing list](https://lists.osgeo.org/listinfo/postgis-users) with details
+View all [tickets for 3.4.3 milestone][1].
+[1]: https://trac.osgeo.org/postgis/query?status=assigned&status=closed&milestone=PostGIS+3.4.3
Summary of changes:
content/news/2024/09-04_postgis-3.4.3.md | 73 ++++++++++++++++++++++++++++++++
1 file changed, 73 insertions(+)
create mode 100644 content/news/2024/09-04_postgis-3.4.3.md
hooks/post-receive
postgis.net
