[SCM] PostGIS branch stable-3.3 updated. 3.3.6-37-ga0c796766
git at osgeo.org
git at osgeo.org
Thu Sep 5 15:11:10 PDT 2024
the project "PostGIS".
The branch, stable-3.3 has been updated
via a0c796766cbcd369d871283f559fd97a186464dd (commit)
from 36b1515938115efda53f18e2b4d859bd4e7ea5bd (commit)
revisions in full, below.
commit a0c796766cbcd369d871283f559fd97a186464dd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Sep 5 15:11:00 2024 -0700
Bump versions for 3.3.7
diff --git a/README.postgis b/README.postgis
index c99c0902b..3859b0623 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.3.6
-:Date: 2024-02-07
+:Version: 3.3.7
+:Date: 2024-09-05
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 52b09cc9d..337584ec8 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=7dev
+POSTGIS_MICRO_VERSION=7
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 35f4bf80a..88a158d7d 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,27 @@
<appendix id="release_notes">
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
+ <sect1>
+ <title>PostGIS 3.3.7</title>
+ <para>2024/09/05</para>
+ <simplesect>
+ <title>Bug Fixes</title>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5766">5766</ulink>, Always report invalid non-null MBR of universal face (Sandro Santilli)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5709">5709</ulink>, Fix loose mbr in topology.face on ST_ChangeEdgeGeom (Sandro Santilli)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5698">5698</ulink>, Fix robustness issue splitting line by vertex very close to endpoints, affecting topology population functions (Sandro Santilli)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5649">5649</ulink>, ST_Value should return NULL on missing band (Paul Ramsey)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5677">5677</ulink>, ST_Union(geom[]) should unary union single entry arrays (Paul Ramsey)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5679">5679</ulink>, Remove spurious COMMIT statements from sfcgal script (Sandro Santilli, Loïc Bartoletti)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5680">5680</ulink>, Fix populate_topology_layer with standard_conforming_strings set to off (Sandro Santilli)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5589">5589</ulink>, ST_3DDistance error for shared first point (Paul Ramsey)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5686">5686</ulink>, ST_NumInteriorRings and Triangle crash (Paul Ramsey)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5671">5671</ulink>, Bug in ST_Area function with use_spheroid=false (Paul Ramsey, Regina Obe)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5687">5687</ulink>, #5756 Support for PostgreSQL 17, revise postgis_get_full_version_schema() to not rely on search_path</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5740">5740</ulink>, ST_DistanceSpheroid(geometry) incorrectly handles polygons (Paul Ramsey)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5765">5765</ulink>, Handle nearly co-linear edges with slightly less slop (Paul Ramsey)</para>
+ <para><ulink url="https://trac.osgeo.org/postgis/ticket/5745">5745</ulink>, St_AsLatLonText rounding errors (Paul Ramsey)</para>
+ </simplesect>
+ </sect1>
<sect1>
<title>PostGIS 3.3.6</title>
<para>2024/02/07</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 1b04e030d..0b1ac9a68 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -70,9 +70,10 @@ UPGRADEABLE_VERSIONS = \
3.0.8 \
3.0.9 \
3.0.10 \
+ 3.0.11 \
3.1.0 \
3.1.1 \
- 3.1.2 \
+ 3.1.2 \
3.1.3 \
3.1.4 \
3.1.5 \
@@ -81,6 +82,7 @@ UPGRADEABLE_VERSIONS = \
3.1.8 \
3.1.9 \
3.1.10 \
+ 3.1.11 \
3.2.0 \
3.2.1 \
3.2.2 \
@@ -88,9 +90,11 @@ UPGRADEABLE_VERSIONS = \
3.2.4 \
3.2.5 \
3.2.6 \
+ 3.2.7 \
3.3.0 \
3.3.1 \
3.3.2 \
3.3.3 \
3.3.4 \
- 3.3.5
+ 3.3.5 \
+ 3.3.6
Summary of changes:
README.postgis | 4 ++--
Version.config | 2 +-
doc/release_notes.xml | 21 +++++++++++++++++++++
extensions/upgradeable_versions.mk | 8 ++++++--
4 files changed, 30 insertions(+), 5 deletions(-)
hooks/post-receive
