[SCM] PostGIS branch master updated. 3.5.0alpha2-58-gddfb090b9
git at osgeo.org
git at osgeo.org
Thu Sep 12 07:11:31 PDT 2024
the project "PostGIS".
via ddfb090b9cd3c5d6a0b358a8b7a9a84310b27038 (commit)
from 42da0a05f85494c14af08d81088e5020ef193533 (commit)
revisions in full, below.
commit ddfb090b9cd3c5d6a0b358a8b7a9a84310b27038
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Sep 12 16:11:10 2024 +0200
Fix indenting in lwgeom_topo.c
diff --git a/.editorconfig b/.editorconfig
index a5d7b210b..8b62171f9 100644
--- a/.editorconfig
+++ b/.editorconfig
@@ -57,6 +57,7 @@ indent_size = 2
# topology C files want space indentation
[liblwgeom/topo/**.{c,h}]
indent_style = space
+indent_size = 2
[liblwgeom/lwgeom_log.h]
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 9c420a82d..ae53d1f11 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -154,11 +154,11 @@ lwt_be_getNodeById(LWT_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numelems
LWT_ISO_NODE *
lwt_be_getNodeWithinDistance2D(LWT_TOPOLOGY *topo,
- const LWPOINT *pt,
- double dist,
- uint64_t *numelems,
- int fields,
- int64_t limit)
+ const LWPOINT *pt,
+ double dist,
+ uint64_t *numelems,
+ int fields,
+ int64_t limit)
CBT5(topo, getNodeWithinDistance2D, pt, dist, numelems, fields, limit);
@@ -243,11 +243,11 @@ lwt_be_getNodeByFace(LWT_TOPOLOGY *topo, const LWT_ELEMID *ids, uint64_t *numele
LWT_ISO_EDGE *
lwt_be_getEdgeWithinDistance2D(LWT_TOPOLOGY *topo,
- double dist,
- int fields,
- int64_t limit)
+ double dist,
+ int fields,
+ int64_t limit)
CBT5(topo, getEdgeWithinDistance2D, pt, dist, numelems, fields, limit);
@@ -378,26 +378,26 @@ lwt_be_getRingEdges(LWT_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numedges, uin
int
lwt_be_ExistsCoincidentNode(LWT_TOPOLOGY* topo, const LWPOINT* pt)
- uint64_t exists = 0;
- lwt_be_getNodeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
- if (exists == UINT64_MAX)
- PGTOPO_BE_ERROR();
- return 0;
+ uint64_t exists = 0;
+ lwt_be_getNodeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
+ if (exists == UINT64_MAX)
+ PGTOPO_BE_ERROR();
+ return 0;
return exists;
int
lwt_be_ExistsEdgeIntersectingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
- lwt_be_getEdgeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
- return 0;
+ lwt_be_getEdgeWithinDistance2D(topo, pt, 0, &exists, 0, -1);
+ return 0;
return exists;
@@ -589,7 +589,7 @@ LWT_ELEMID
lwt_AddIsoNode( LWT_TOPOLOGY* topo, LWT_ELEMID face,
LWPOINT* pt, int skipISOChecks )
- return _lwt_AddIsoNode( topo, face, pt, skipISOChecks, 1 );
+ return _lwt_AddIsoNode( topo, face, pt, skipISOChecks, 1 );
@@ -607,20 +607,20 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
LWT_ELEMID start_node, LWT_ELEMID end_node,
const LWLINE *geom, LWT_ELEMID myself )
- uint64_t i, num_nodes, num_edges;
- LWT_ISO_EDGE *edges;
- LWT_ISO_NODE *nodes;
- const GBOX *edgebox;
- GEOSGeometry *edgegg;
+ uint64_t i, num_nodes, num_edges;
+ LWT_ISO_EDGE *edges;
+ LWT_ISO_NODE *nodes;
+ const GBOX *edgebox;
+ GEOSGeometry *edgegg;
- initGEOS(lwnotice, lwgeom_geos_error);
+ initGEOS(lwnotice, lwgeom_geos_error);
- edgegg = LWGEOM2GEOS(lwline_as_lwgeom(geom), 0);
- if (!edgegg)
- lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
- return -1;
+ edgegg = LWGEOM2GEOS(lwline_as_lwgeom(geom), 0);
+ if (!edgegg)
+ lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
+ return -1;
edgebox = lwgeom_get_bbox( lwline_as_lwgeom(geom) );
/* loop over each node within the edge's gbox */
@@ -629,8 +629,8 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %d nodes", num_nodes);
if (num_nodes == UINT64_MAX)
- return -1;
+ return -1;
for ( i=0; i<num_nodes; ++i )
@@ -658,9 +658,9 @@ _lwt_CheckEdgeCrossing( LWT_TOPOLOGY* topo,
LWDEBUGF(1, "lwt_be_getEdgeWithinBox2D returned %d edges", num_edges);
if (num_edges == UINT64_MAX)
- GEOSGeom_destroy(edgegg);
- return -1;
+ GEOSGeom_destroy(edgegg);
+ return -1;
for ( i=0; i<num_edges; ++i )
@@ -808,24 +808,24 @@ LWT_ELEMID
lwt_AddIsoEdge( LWT_TOPOLOGY* topo, LWT_ELEMID startNode,
LWT_ELEMID endNode, const LWLINE* geom )
- uint64_t num_nodes;
- uint64_t i;
- LWT_ISO_EDGE newedge;
- LWT_ISO_NODE *endpoints;
- LWT_ELEMID containing_face = -1;
- LWT_ELEMID node_ids[2];
- LWT_ISO_NODE updated_nodes[2];
- int skipISOChecks = 0;
- POINT2D p1, p2;
+ uint64_t num_nodes;
+ uint64_t i;
+ LWT_ISO_EDGE newedge;
+ LWT_ISO_NODE *endpoints;
+ LWT_ELEMID containing_face = -1;
+ LWT_ELEMID node_ids[2];
+ LWT_ISO_NODE updated_nodes[2];
+ int skipISOChecks = 0;
+ POINT2D p1, p2;
- /* NOT IN THE SPECS:
- * A closed edge is never isolated (as it forms a face)
- if (startNode == endNode)
- lwerror("Closed edges would not be isolated, try lwt_AddEdgeNewFaces");
- return -1;
+ /* NOT IN THE SPECS:
+ * A closed edge is never isolated (as it forms a face)
+ if (startNode == endNode)
+ lwerror("Closed edges would not be isolated, try lwt_AddEdgeNewFaces");
+ return -1;
if ( ! skipISOChecks )
@@ -1558,8 +1558,8 @@ _lwt_FindAdjacentEdges( LWT_TOPOLOGY* topo, LWT_ELEMID node, edgeend *data,
edges = lwt_be_getEdgeByNode( topo, &node, &numedges, LWT_COL_EDGE_ALL );
if (numedges == UINT64_MAX)
- return 0;
+ return 0;
LWDEBUGF(1, "getEdgeByNode returned %d edges, minaz=%g, maxaz=%g",
@@ -1900,23 +1900,23 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
LWT_ELEMID sedge, LWT_ELEMID face,
int mbr_only )
- uint64_t numfaceedges, i, j;
- int newface_outside;
- uint64_t num_signed_edge_ids;
- LWT_ELEMID *signed_edge_ids;
- LWT_ISO_EDGE *forward_edges = NULL;
- int forward_edges_count = 0;
- LWT_ISO_EDGE *backward_edges = NULL;
- int backward_edges_count = 0;
+ uint64_t numfaceedges, i, j;
+ int newface_outside;
+ uint64_t num_signed_edge_ids;
+ LWT_ELEMID *signed_edge_ids;
+ LWT_ISO_EDGE *forward_edges = NULL;
+ int forward_edges_count = 0;
+ LWT_ISO_EDGE *backward_edges = NULL;
+ int backward_edges_count = 0;
- signed_edge_ids = lwt_be_getRingEdges(topo, sedge, &num_signed_edge_ids, 0);
- if (!signed_edge_ids)
- //PGTOPO_BE_ERRORF("no ring edges for edge %" LWTFMT_ELEMID, sedge);
- return -2;
+ signed_edge_ids = lwt_be_getRingEdges(topo, sedge, &num_signed_edge_ids, 0);
+ if (!signed_edge_ids)
+ //PGTOPO_BE_ERRORF("no ring edges for edge %" LWTFMT_ELEMID, sedge);
+ return -2;
LWDEBUGF(1, "getRingEdges returned %d edges", num_signed_edge_ids);
/* You can't get to the other side of an edge forming a ring */
@@ -2080,9 +2080,9 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
edges = lwt_be_getEdgeByFace( topo, &face, &numfaceedges, fields, newface.mbr );
if (numfaceedges == UINT64_MAX)
- lwfree(signed_edge_ids);
- return -2;
+ lwfree(signed_edge_ids);
+ return -2;
LWDEBUGF(1, "_lwt_AddFaceSplit: lwt_be_getEdgeByFace(%d) returned %d edges", face, numfaceedges);
@@ -2240,9 +2240,9 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
&numisonodes, fields, newface.mbr);
if (numisonodes == UINT64_MAX)
- return -2;
+ return -2;
if ( numisonodes ) {
LWT_ISO_NODE *updated_nodes = lwalloc(sizeof(LWT_ISO_NODE)*numisonodes);
@@ -2407,8 +2407,8 @@ _lwt_AddEdge( LWT_TOPOLOGY* topo,
endpoints = lwt_be_getNodeById( topo, node_ids, &num_nodes, LWT_COL_NODE_ALL );
- return -1;
+ return -1;
@@ -2842,19 +2842,19 @@ _lwt_FaceByEdges(LWT_TOPOLOGY *topo, LWT_ISO_EDGE *edges, int numfaceedges)
LWGEOM*
lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
- uint64_t numfaceedges;
- LWT_ISO_FACE *face;
- LWPOLY *out;
- LWGEOM *outg;
- uint64_t i, edgeid;
- int fields;
+ uint64_t numfaceedges;
+ LWT_ISO_FACE *face;
+ LWPOLY *out;
+ LWGEOM *outg;
+ uint64_t i, edgeid;
+ int fields;
- if (faceid == 0)
- lwerror("SQL/MM Spatial exception - universal face has no geometry");
- return NULL;
+ if (faceid == 0)
+ lwerror("SQL/MM Spatial exception - universal face has no geometry");
+ return NULL;
/* Construct the face geometry */
numfaceedges = 1;
@@ -2866,8 +2866,8 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
edges = lwt_be_getEdgeByFace( topo, &faceid, &numfaceedges, fields, NULL );
- return NULL;
+ return NULL;
LWDEBUGF(1, "lwt_GetFaceGeometry: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
@@ -2877,8 +2877,8 @@ lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID faceid)
face = lwt_be_getFaceById(topo, &faceid, &i, LWT_COL_FACE_FACE_ID);
if (i == UINT64_MAX)
- return NULL;
+ return NULL;
if ( i == 0 ) {
lwerror("SQL/MM Spatial exception - non-existent face.");
@@ -3113,8 +3113,8 @@ lwt_GetFaceEdges(LWT_TOPOLOGY* topo, LWT_ELEMID face_id, LWT_ELEMID **out )
edges = lwt_be_getEdgeByFace( topo, &face_id, &numfaceedges, fields, NULL );
- return -1;
+ return -1;
if ( ! numfaceedges ) return 0; /* no edges in output */
LWDEBUGF(1, "lwt_GetFaceEdges: lwt_be_getEdgeByFace returned %d edges", numfaceedges);
@@ -3397,9 +3397,9 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
LWDEBUGF(1, "lwt_be_getNodeWithinBox2D returned %d nodes", numnodes);
if (numnodes == UINT64_MAX)
- _lwt_release_edges(oldedge, 1);
- return -1;
+ _lwt_release_edges(oldedge, 1);
+ return -1;
// 3. if any node beside endnodes are found:
if ( numnodes > ( 1 + isclosed ? 0 : 1 ) )
@@ -3437,7 +3437,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
/* initialize span_pre.myaz and epan_pre.myaz with existing edge */
int res = _lwt_InitEdgeEndByLine(&span_pre, &epan_pre, oldedge->geom, &p1, &p2);
if (res)
- return -1; /* lwerror should have been raised */
+ return -1; /* lwerror should have been raised */
_lwt_FindAdjacentEdges( topo, oldedge->start_node, &span_pre,
isclosed ? &epan_pre : NULL, edge_id );
_lwt_FindAdjacentEdges( topo, oldedge->end_node, &epan_pre,
@@ -3473,7 +3473,7 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
/* initialize epan_post.myaz and epan_post.myaz */
res = _lwt_InitEdgeEndByLine(&span_post, &epan_post, geom, &p1, &p2);
if (res)
_lwt_FindAdjacentEdges( topo, oldedge->start_node, &span_post,
isclosed ? &epan_post : NULL, edge_id );
_lwt_FindAdjacentEdges( topo, oldedge->end_node, &epan_post,
@@ -3561,16 +3561,16 @@ lwt_ChangeEdgeGeom(LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, LWLINE *geom)
if ( facestoupdate )
uint64_t updatedFaces = lwt_be_updateFacesById(topo, &(faces[0]), facestoupdate);
- if (updatedFaces != facestoupdate)
+ if (updatedFaces != facestoupdate)
while ( facestoupdate-- ) lwfree(faces[facestoupdate].mbr);
- if (updatedFaces == UINT64_MAX)
- else
- lwerror("Unexpected error: %" PRIu64 " faces updated when expecting 1", updatedFaces);
- return -1;
+ if (updatedFaces == UINT64_MAX)
+ else
+ lwerror("Unexpected error: %" PRIu64 " faces updated when expecting 1", updatedFaces);
+ return -1;
@@ -3595,8 +3595,8 @@ _lwt_GetIsoNode(LWT_TOPOLOGY* topo, LWT_ELEMID nid)
node = lwt_be_getNodeById( topo, &nid, &n, LWT_COL_NODE_CONTAINING_FACE );
if (n == UINT64_MAX)
- return 0;
+ return 0;
if ( n < 1 ) {
lwerror("SQL/MM Spatial exception - non-existent node");
@@ -3747,17 +3747,17 @@ lwt_RemIsoEdge(LWT_TOPOLOGY* topo, LWT_ELEMID id)
edge = lwt_be_getEdgeByNode( topo, nid, &n, LWT_COL_EDGE_EDGE_ID );
if ((n == UINT64_MAX) || (edge == NULL))
- return -1;
+ return -1;
for (i = 0; i < n; ++i)
- if (edge[i].edge_id != id)
- lwfree(edge);
- lwerror("SQL/MM Spatial exception - not isolated edge");
- return -1;
+ if (edge[i].edge_id != id)
+ lwfree(edge);
+ lwerror("SQL/MM Spatial exception - not isolated edge");
+ return -1;
lwfree(edge);
@@ -3869,51 +3869,52 @@ _lwt_UpdateNodeFaceRef( LWT_TOPOLOGY *topo, LWT_ELEMID of, LWT_ELEMID nf)
static LWT_ELEMID
_lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
- uint64_t i, nedges, nfaces, fields;
- LWT_ISO_EDGE *edge = NULL;
- LWT_ISO_EDGE *upd_edge = NULL;
- LWT_ISO_EDGE upd_edge_left[2];
- int nedge_left = 0;
- LWT_ISO_EDGE upd_edge_right[2];
- int nedge_right = 0;
- LWT_ISO_NODE upd_node[2];
- int nnode = 0;
- LWT_ISO_FACE *faces = NULL;
- LWT_ISO_FACE newface;
- LWT_ELEMID face_ids[2];
- int fnode_edges = 0; /* number of edges on the first node (excluded
- * the one being removed ) */
- int lnode_edges = 0; /* number of edges on the last node (excluded
+ uint64_t i, nedges, nfaces, fields;
+ LWT_ISO_EDGE *edge = NULL;
+ LWT_ISO_EDGE *upd_edge = NULL;
+ LWT_ISO_EDGE upd_edge_left[2];
+ int nedge_left = 0;
+ LWT_ISO_EDGE upd_edge_right[2];
+ int nedge_right = 0;
+ LWT_ISO_NODE upd_node[2];
+ int nnode = 0;
+ LWT_ISO_FACE *faces = NULL;
+ LWT_ISO_FACE newface;
+ LWT_ELEMID face_ids[2];
+ int fnode_edges = 0; /* number of edges on the first node (excluded
+ * the one being removed ) */
+ int lnode_edges = 0; /* number of edges on the last node (excluded
- newface.face_id = 0;
- i = 1;
- edge = lwt_be_getEdgeById(topo, &edge_id, &i, LWT_COL_EDGE_ALL);
- if (!edge)
- LWDEBUGF(1, "lwt_be_getEdgeById returned NULL and set i=%d", i);
- if (i == UINT64_MAX)
- return -1;
- else if (i == 0)
- lwerror("SQL/MM Spatial exception - non-existent edge %" LWTFMT_ELEMID, edge_id);
- return -1;
- else
- lwerror(
- "Backend coding error: getEdgeById callback returned NULL "
- "but numelements output parameter has value %" PRIu64 " "
- "(expected 0 or 1)",
- i);
- return -1;
+ newface.face_id = 0;
+ i = 1;
+ edge = lwt_be_getEdgeById(topo, &edge_id, &i, LWT_COL_EDGE_ALL);
+ if (!edge)
+ LWDEBUGF(1, "lwt_be_getEdgeById returned NULL and set i=%d", i);
+ if (i == UINT64_MAX)
+ return -1;
+ else if (i == 0)
+ lwerror("SQL/MM Spatial exception - non-existent edge %" LWTFMT_ELEMID, edge_id);
+ return -1;
+ else
+ lwerror(
+ "Backend coding error: getEdgeById callback returned NULL "
+ "but numelements output parameter has value %" PRIu64 " "
+ "(expected 0 or 1)",
+ i);
+ return -1;
if ( ! lwt_be_checkTopoGeomRemEdge(topo, edge_id,
edge->face_left, edge->face_right) )
@@ -3938,8 +3939,8 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
upd_edge = lwt_be_getEdgeByNode( topo, &(node_ids[0]), &nedges, fields );
if (nedges == UINT64_MAX)
- return -1;
+ return -1;
nedge_left = nedge_right = 0;
for ( i=0; i<nedges; ++i )
@@ -4041,8 +4042,8 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
faces = lwt_be_getFaceById(topo, face_ids, &nfaces, fields);
if (nfaces == UINT64_MAX)
- return -1;
+ return -1;
GBOX *box1=NULL;
GBOX *box2=NULL;
@@ -4107,38 +4108,38 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
if ( modFace )
newface.face_id = floodface;
- int result = lwt_be_updateFacesById(topo, &newface, 1);
- _lwt_release_faces(faces, 2);
- if (result == -1)
- _lwt_release_edges(edge, 1);
- return -1;
- if (result != 1)
- lwerror("Unexpected error: %" PRIu64 " faces updated when expecting 1", i);
- return -1;
+ int result = lwt_be_updateFacesById(topo, &newface, 1);
+ _lwt_release_faces(faces, 2);
+ if (result == -1)
+ _lwt_release_edges(edge, 1);
+ return -1;
+ if (result != 1)
+ lwerror("Unexpected error: %" PRIu64 " faces updated when expecting 1", i);
+ return -1;
else
/* New face replaces the old two faces */
newface.face_id = -1;
- int result = lwt_be_insertFaces(topo, &newface, 1);
- if (result == -1)
- return -1;
- if (result != 1)
+ int result = lwt_be_insertFaces(topo, &newface, 1);
+ if (result == -1)
+ return -1;
+ if (result != 1)
- lwerror("Unexpected error: %d faces inserted when expecting 1", result);
- return -1;
+ lwerror("Unexpected error: %d faces inserted when expecting 1", result);
+ return -1;
floodface = newface.face_id;
@@ -4194,9 +4195,9 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
int result = lwt_be_deleteEdges(topo, edge, LWT_COL_EDGE_EDGE_ID);
if (result == -1)
- return -1;
+ return -1;
/* If any of the edge nodes remained isolated, set
@@ -4216,13 +4217,13 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
if ( nnode )
- int result = lwt_be_updateNodesById(topo, upd_node, nnode, LWT_COL_NODE_CONTAINING_FACE);
- if (result == -1)
- return -1;
+ int result = lwt_be_updateNodesById(topo, upd_node, nnode, LWT_COL_NODE_CONTAINING_FACE);
+ if (result == -1)
+ return -1;
if ( edge->face_left != edge->face_right )
@@ -4237,9 +4238,9 @@ _lwt_RemEdge( LWT_TOPOLOGY* topo, LWT_ELEMID edge_id, int modFace )
int result = lwt_be_deleteFacesById(topo, ids, nids);
if (result == -1)
- return -1;
+ return -1;
@@ -4321,19 +4322,19 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
if ( ! e1 )
- _lwt_release_edges(edges, nedges);
- lwerror(
- "SQL/MM Spatial exception - non-existent edge %" LWTFMT_ELEMID,
- eid1);
- return -1;
+ _lwt_release_edges(edges, nedges);
+ lwerror(
+ "SQL/MM Spatial exception - non-existent edge %" LWTFMT_ELEMID,
+ eid1);
+ return -1;
if ( ! e2 )
- lwerror(
- eid2);
- return -1;
+ lwerror(
+ eid2);
+ return -1;
/* NOT IN THE SPECS: See if any of the two edges are closed. */
@@ -4372,9 +4373,9 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
&num_node_edges, LWT_COL_EDGE_EDGE_ID );
if (num_node_edges == UINT64_MAX)
- return -1;
+ return -1;
for (i=0; i<num_node_edges; ++i)
@@ -4424,9 +4425,9 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
- return -1;
+ return -1;
@@ -4555,10 +4556,10 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
/* Update data of the first edge */
newedge.edge_id = eid1;
int result = lwt_be_updateEdgesById(topo,
- &newedge,
- 1,
- LWT_COL_EDGE_NEXT_LEFT | LWT_COL_EDGE_NEXT_RIGHT | LWT_COL_EDGE_START_NODE |
- LWT_COL_EDGE_END_NODE | LWT_COL_EDGE_GEOM);
+ &newedge,
+ 1,
+ LWT_COL_EDGE_NEXT_LEFT | LWT_COL_EDGE_NEXT_RIGHT | LWT_COL_EDGE_START_NODE |
+ LWT_COL_EDGE_END_NODE | LWT_COL_EDGE_GEOM);
if (result == -1)
lwline_free(newedge.geom);
@@ -4583,17 +4584,17 @@ _lwt_HealEdges( LWT_TOPOLOGY* topo, LWT_ELEMID eid1, LWT_ELEMID eid2,
int result = lwt_be_insertEdges(topo, &newedge, 1);
if (result == -1)
- lwline_free(newedge.geom);
- return -1;
+ lwline_free(newedge.geom);
+ return -1;
else if (result == 0)
- lwerror("Insertion of split edge failed (no reason)");
- return -1;
+ lwerror("Insertion of split edge failed (no reason)");
+ return -1;
@@ -4963,14 +4964,14 @@ typedef struct scored_pointer_t {
static int
compare_scored_pointer(const void *si1, const void *si2)
- double a = ((scored_pointer *)si1)->score;
- double b = ((scored_pointer *)si2)->score;
- if ( a < b )
- return -1;
- else if ( a > b )
- return 1;
- else
- return 0;
+ double a = ((scored_pointer *)si1)->score;
+ double b = ((scored_pointer *)si2)->score;
+ if ( a < b )
+ return -1;
+ else if ( a > b )
+ return 1;
+ else
+ return 0;
/* Return identifier of an equal edge, 0 if none or -1 on error
@@ -5840,8 +5841,8 @@ _lwt_SnapEdgeToExistingNode(
int ret = lwt_be_insertEdges(topo, &newEdge, 1);
if (ret != 1)
- return -1;
+ return -1;
/* Updating the first portion of the edge */
@@ -6310,8 +6311,8 @@ _lwt_SnapEdgeToExistingNode(
static LWT_ELEMID
_lwt_SplitAllEdgesToNewNode(LWT_TOPOLOGY* topo, LWT_ISO_EDGE *edges, uint64_t num, LWPOINT *point, double tol, int *moved)
- uint64_t i, j;
- scored_pointer *sorted = lwalloc(sizeof(scored_pointer)*num);
+ uint64_t i, j;
+ scored_pointer *sorted = lwalloc(sizeof(scored_pointer)*num);
LWT_ISO_EDGE *edges2 = NULL;
LWT_ISO_NODE node;
node.node_id = 0; /* unneeded, but hushes a compiler warning */
@@ -6542,33 +6543,33 @@ static LWT_ELEMID
_lwt_AddPoint(LWT_TOPOLOGY* topo, LWPOINT* point, double tol, int
findFace, int *moved)
- uint64_t num, i;
- double mindist = FLT_MAX;
- LWT_ISO_NODE *nodes, *nodes2;
- LWGEOM *pt = lwpoint_as_lwgeom(point);
- scored_pointer *sorted;
- int flds;
- LWT_ELEMID id = 0;
+ uint64_t num, i;
+ double mindist = FLT_MAX;
+ LWT_ISO_NODE *nodes, *nodes2;
+ LWGEOM *pt = lwpoint_as_lwgeom(point);
+ scored_pointer *sorted;
+ int flds;
+ LWT_ELEMID id = 0;
- /* Get tolerance, if 0 was given */
- if (!tol)
- tol = _LWT_MINTOLERANCE(topo, pt);
+ /* Get tolerance, if 0 was given */
+ if (!tol)
+ tol = _LWT_MINTOLERANCE(topo, pt);
- LWDEBUGG(1, pt, "Adding point");
+ LWDEBUGG(1, pt, "Adding point");
- -- 1. Check if any existing node is closer than the given precision
- -- and if so pick the closest
- TODO: use WithinBox2D
- flds = LWT_COL_NODE_NODE_ID | LWT_COL_NODE_GEOM;
- nodes = lwt_be_getNodeWithinDistance2D(topo, point, tol, &num, flds, 0);
- if (num == UINT64_MAX)
- return -1;
+ -- 1. Check if any existing node is closer than the given precision
+ -- and if so pick the closest
+ TODO: use WithinBox2D
+ flds = LWT_COL_NODE_NODE_ID | LWT_COL_NODE_GEOM;
+ nodes = lwt_be_getNodeWithinDistance2D(topo, point, tol, &num, flds, 0);
+ if (num == UINT64_MAX)
+ return -1;
if ( num )
LWDEBUGF(1, "New point is within %.15g units of %d nodes", tol, num);
@@ -6902,7 +6903,7 @@ _lwt_split_by_nodes(const LWGEOM *g, const LWGEOM *nodes)
static LWT_ELEMID*
_lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
- int handleFaceSplit)
+ int handleFaceSplit)
LWGEOM *geomsbuf[1];
LWGEOM **geoms;
@@ -7280,13 +7281,13 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
LWT_ELEMID*
lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges)
- return _lwt_AddLine(topo, line, tol, nedges, 1);
+ return _lwt_AddLine(topo, line, tol, nedges, 1);
LWT_ELEMID*
lwt_AddLineNoFace(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges)
- return _lwt_AddLine(topo, line, tol, nedges, 0);
+ return _lwt_AddLine(topo, line, tol, nedges, 0);
static void
@@ -7467,9 +7468,9 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
/* cberror(topo->be_data, "Error from cb_getClosestEdge"); */
- return -1;
+ return -1;
if (numedges == 0)
@@ -7480,7 +7481,7 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
if ( closestEdge->face_left < 0 )
lwerror("Closest edge %" LWTFMT_ELEMID " has invalid face %" LWTFMT_ELEMID
- " on its left side", closestEdge->edge_id, closestEdge->face_left);
+ " on its left side", closestEdge->edge_id, closestEdge->face_left);
_lwt_release_edges(closestEdge, 1);
return -1;
@@ -7488,7 +7489,7 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
if ( closestEdge->face_right < 0 )
- " on its right side", closestEdge->edge_id, closestEdge->face_right);
+ " on its right side", closestEdge->edge_id, closestEdge->face_right);
return -1;
@@ -7509,20 +7510,20 @@ lwt_GetFaceContainingPoint(LWT_TOPOLOGY* topo, const LWPOINT* pt)
closestSegmentP1->y
- * We use comp.graphics.algorithms Frequently Asked Questions method
- * (1) AC dot AB
- * r = ----------
- * ||AB||^2
- * r has the following meaning:
- * r=0 P = A
- * r=1 P = B
- * r<0 P is on the backward extension of AB
- * r>1 P is on the forward extension of AB
- * 0<r<1 P is interior to AB
+ * We use comp.graphics.algorithms Frequently Asked Questions method
+ * (1) AC dot AB
+ * r = ----------
+ * ||AB||^2
+ * r has the following meaning:
+ * r=0 P = A
+ * r=1 P = B
+ * r<0 P is on the backward extension of AB
+ * r>1 P is on the forward extension of AB
+ * 0<r<1 P is interior to AB
const POINT2D *p = queryPoint;
const POINT2D *A = closestSegmentP0;
const POINT2D *B = closestSegmentP1;
@@ -7819,12 +7820,12 @@ _lwt_LoadGeometryRecursive(LWT_TOPOLOGY* topo, LWGEOM* geom, double tol)
return;
- default:
- lwerror("%s: Unsupported geometry type: %s", __func__,
- lwtype_name(geom->type));
- return;
+ default:
+ lwerror("%s: Unsupported geometry type: %s", __func__,
+ lwtype_name(geom->type));
+ return;
@@ -7832,5 +7833,5 @@ _lwt_LoadGeometryRecursive(LWT_TOPOLOGY* topo, LWGEOM* geom, double tol)
void
lwt_LoadGeometry(LWT_TOPOLOGY* topo, LWGEOM* geom, double tol)
- _lwt_LoadGeometryRecursive(topo, geom, tol);
+ _lwt_LoadGeometryRecursive(topo, geom, tol);
Summary of changes:
.editorconfig | 1 +
liblwgeom/topo/lwgeom_topo.c | 631 ++++++++++++++++++++++---------------------
2 files changed, 317 insertions(+), 315 deletions(-)
hooks/post-receive
