[PostGIS] #5777: st_intersects() throws exception when using geometrycollection as first argument
PostGIS trac at osgeo.org
Fri Sep 13 16:41:14 PDT 2024
argument
  Reporter:  cfischer    |      Owner:  pramsey
      Type:  defect      |     Status:  new
  Priority:  medium      |  Milestone:  PostGIS GEOS
 Component:  postgis     |    Version:  3.4.x
Resolution:              |   Keywords:  relate st_intersects
                         |  TopologyException
Comment (by mdavis):
 Replying to [comment:4 robe]:
 > Replying to [comment:3 pramsey]:
 > > This exists in GEOS 3.12, but not in GEOS 3.13.
 > You mean the other way around I hope  -- exists in GEOS 3.13 and not in
 3.12 and below
 He means that the **problem** exists in GEOS 3.12 but not in 3.13.
 > Now that GEOS 3.13 is released, is there a reason to keep this ticket
 open?
 Probably not.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5777#comment:5>
