[PostGIS] #5448: Test failures on i386
PostGIS trac at osgeo.org
Fri Sep 20 22:27:12 PDT 2024
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  closed
  Priority:  medium          |  Milestone:  PostGIS 3.5.0
 Component:  QA/testsuite    |    Version:  master
Resolution:  wontfix         |   Keywords:
Comment (by Bas Couwenberg):
 Also note that the Debian packages for PostGIS extensions stopped
 supporting 32-bit architectures with PostgreSQL 17.
 https://lists.debian.org/debian-devel/2024/08/msg00202.html
Ticket URL: <https://trac.osgeo.org/$(basename)s/ticket/5448#comment:15>
