[SCM] PostGIS branch master updated. 3.5.0beta1-5-g167219620
Wed Sep 18 09:14:04 PDT 2024
the project "PostGIS".
       via  16721962049068cc26a18ee6a16eb42ac002b0c4 (commit)
       via  b4cf3d95d83de80bf62a07e64215ed7a499cbd9a (commit)
      from  4b786d9992479041f4bc0cf559cc10e3feca4e2c (commit)
revisions in full, below.
commit 16721962049068cc26a18ee6a16eb42ac002b0c4
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Sep 18 12:11:26 2024 -0400
    Many sections ignoring topology and sfcgal funcs
    Closes #5778 for PostGIS 3.5.0
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 6f3527c86..41b9ffd12 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -217,7 +217,8 @@ XSL_GENERATED_SOURCES = \
 	list_raster_functions.xsl.xml \
 	list_sqlmm_functions.xsl.xml \
 	list_window_functions.xsl.xml \
-	table_body_function_support_matrix.xsl.xml
+	table_body_function_support_matrix.xsl.xml \
+	list_polyhedral_functions.xsl.xml
 TAG_GENERATED_SOURCES = \
 	address_standardizer_required.tag \
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 1fbd28ec8..fbe169b2e 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -83,7 +83,7 @@
 <!ENTITY list_dump_functions SYSTEM "list_dump_functions.xsl.xml">
 <!ENTITY list_geography_functions SYSTEM "list_geography_functions.xsl.xml">
 <!ENTITY list_new_functions SYSTEM "list_new_functions.xsl.xml">
-<!ENTITY list_polyhedral_geometry_functions SYSTEM "list_curved_geometry_functions.xsl.xml">
+<!ENTITY list_polyhedral_geometry_functions SYSTEM "list_polyhedral_functions.xsl.xml">
 <!ENTITY list_raster_functions SYSTEM "list_raster_functions.xsl.xml">
 <!ENTITY list_sqlmm_functions SYSTEM "list_sqlmm_functions.xsl.xml">
 <!ENTITY list_window_functions SYSTEM "list_window_functions.xsl.xml">
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index fc27d67c6..c45e2e5c9 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -1407,7 +1407,7 @@ ST_GeomFromText('POLYHEDRALSURFACE Z( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
         <refnamediv>
             <refname>CG_3DUnion</refname>
-            <refpurpose>Perform 3D union.</refpurpose>
+            <refpurpose>Perform 3D union using postgis_sfcgal.</refpurpose>
         </refnamediv>
         <refsynopsisdiv>
diff --git a/doc/xsl/list_3d_functions.xml.xsl b/doc/xsl/list_3d_functions.xml.xsl
index cbee3e2d4..46c2460d6 100644
--- a/doc/xsl/list_3d_functions.xml.xsl
+++ b/doc/xsl/list_3d_functions.xml.xsl
@@ -13,12 +13,12 @@
 	<xsl:output method="xml" indent="yes" encoding="utf-8" />
-	<!-- We deal only with the reference chapter -->
+	<!-- We deal only with the reference chapters -->
 	<xsl:template match="/">
-		<xsl:apply-templates select="/db:book/db:chapter[@xml:id='reference']" />
+		<xsl:apply-templates select="/db:book/db:chapter[contains(@xml:id, 'reference')]" />
 	</xsl:template>
-	<xsl:template match="//db:chapter">
+	<xsl:template match="/">
 				<itemizedlist>
 			<!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment  -->
diff --git a/doc/xsl/list_aggregates.xml.xsl b/doc/xsl/list_aggregates.xml.xsl
index 395289711..a8f268cae 100644
--- a/doc/xsl/list_aggregates.xml.xsl
+++ b/doc/xsl/list_aggregates.xml.xsl
@@ -13,12 +13,12 @@
-		<xsl:apply-templates select="//db:chapter[@xml:id='reference']" />
 	</xsl:template>
 			<itemizedlist>
 			<xsl:for-each select='//db:refentry'>
diff --git a/doc/xsl/list_box_functions.xml.xsl b/doc/xsl/list_box_functions.xml.xsl
index 4f714a2c4..f121d6948 100644
--- a/doc/xsl/list_box_functions.xml.xsl
+++ b/doc/xsl/list_box_functions.xml.xsl
@@ -13,12 +13,12 @@
 	</xsl:template>
 				<itemizedlist>
diff --git a/doc/xsl/list_curved_geometry_functions.xml.xsl b/doc/xsl/list_curved_geometry_functions.xml.xsl
index 8ea4ed12e..5e5a06149 100644
--- a/doc/xsl/list_curved_geometry_functions.xml.xsl
+++ b/doc/xsl/list_curved_geometry_functions.xml.xsl
@@ -13,12 +13,13 @@
 	</xsl:template>
 				<itemizedlist>
diff --git a/doc/xsl/list_dump_functions.xml.xsl b/doc/xsl/list_dump_functions.xml.xsl
index 43612c736..efce19214 100644
--- a/doc/xsl/list_dump_functions.xml.xsl
+++ b/doc/xsl/list_dump_functions.xml.xsl
@@ -13,12 +13,13 @@
 	</xsl:template>
 				<itemizedlist>
diff --git a/doc/xsl/list_geography_functions.xml.xsl b/doc/xsl/list_geography_functions.xml.xsl
index de2f0f33d..ddca40d7c 100644
--- a/doc/xsl/list_geography_functions.xml.xsl
+++ b/doc/xsl/list_geography_functions.xml.xsl
@@ -13,12 +13,13 @@
 	</xsl:template>
 				<itemizedlist>
diff --git a/doc/xsl/list_new_functions.xml.xsl b/doc/xsl/list_new_functions.xml.xsl
index ac0f1cb8a..aabea424e 100644
--- a/doc/xsl/list_new_functions.xml.xsl
+++ b/doc/xsl/list_new_functions.xml.xsl
@@ -13,12 +13,12 @@
 	</xsl:template>
 		<xsl:variable name="chap" select="." />
diff --git a/doc/xsl/list_curved_geometry_functions.xml.xsl b/doc/xsl/list_polyhedral_functions.xml.xsl
similarity index 88%
copy from doc/xsl/list_curved_geometry_functions.xml.xsl
copy to doc/xsl/list_polyhedral_functions.xml.xsl
index 8ea4ed12e..0061d859b 100644
+++ b/doc/xsl/list_polyhedral_functions.xml.xsl
@@ -13,12 +13,13 @@
 	</xsl:template>
 				<itemizedlist>
@@ -36,7 +37,7 @@
 			<!-- For each section if there is note that it implements Circular String catalog it -->
 						<xsl:for-each select="db:refsection">
 							<xsl:choose>
-								<xsl:when test="descendant::node()[@conformance='curve']">
+								<xsl:when test="descendant::node()[@conformance='polyhedral']">
 									<listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="$comment" /></simpara></listitem>
 								</xsl:when>
 							</xsl:choose>
diff --git a/doc/xsl/list_raster_functions.xml.xsl b/doc/xsl/list_raster_functions.xml.xsl
index 3095581e3..ec561f5a7 100644
--- a/doc/xsl/list_raster_functions.xml.xsl
+++ b/doc/xsl/list_raster_functions.xml.xsl
@@ -13,12 +13,12 @@
 	</xsl:template>
 				<itemizedlist>
diff --git a/doc/xsl/list_sqlmm_functions.xml.xsl b/doc/xsl/list_sqlmm_functions.xml.xsl
index 0030a1345..620b74e62 100644
--- a/doc/xsl/list_sqlmm_functions.xml.xsl
+++ b/doc/xsl/list_sqlmm_functions.xml.xsl
@@ -13,12 +13,12 @@
 	</xsl:template>
 			<itemizedlist>
diff --git a/doc/xsl/list_window_functions.xml.xsl b/doc/xsl/list_window_functions.xml.xsl
index 45d5bee47..5104817e7 100644
--- a/doc/xsl/list_window_functions.xml.xsl
+++ b/doc/xsl/list_window_functions.xml.xsl
@@ -13,12 +13,12 @@
 	</xsl:template>
             <xsl:if test="//db:funcprototype[contains(db:paramdef/db:type,' winset')]">
 			<itemizedlist>
commit b4cf3d95d83de80bf62a07e64215ed7a499cbd9a
Date:   Mon Sep 16 15:52:27 2024 -0400
    Reenable postgis raster testing for windows PG17
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 94e6cb76b..68bb41988 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -60,11 +60,6 @@ sh autogen.sh
 # excluding topology cause it's erroring out on some tests
 EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-topology"
-if [ $PG_VER == "17" ]; then
-  #skipping raster cause it's failing on cunit when building with new chain
-  EXTRA_CONFIGURE_ARGS="${EXTRA_CONFIGURE_ARGS} --without-raster"
-fi;
 if [ -n "$PCRE_VER" ]; then
     export PATH="${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/include:${PROJECTS}/pcre/rel-${PCRE_VER}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
 fi
Summary of changes:
 ci/winnie/regress_postgis.sh                                     | 5 -----
 doc/Makefile.in                                                  | 3 ++-
 doc/postgis.xml                                                  | 2 +-
 doc/reference_sfcgal.xml                                         | 2 +-
 doc/xsl/list_3d_functions.xml.xsl                                | 6 +++---
 doc/xsl/list_aggregates.xml.xsl                                  | 6 +++---
 doc/xsl/list_box_functions.xml.xsl                               | 6 +++---
 doc/xsl/list_curved_geometry_functions.xml.xsl                   | 7 ++++---
 doc/xsl/list_dump_functions.xml.xsl                              | 7 ++++---
 doc/xsl/list_geography_functions.xml.xsl                         | 7 ++++---
 doc/xsl/list_new_functions.xml.xsl                               | 6 +++---
 ...metry_functions.xml.xsl => list_polyhedral_functions.xml.xsl} | 9 +++++----
 doc/xsl/list_raster_functions.xml.xsl                            | 6 +++---
 doc/xsl/list_sqlmm_functions.xml.xsl                             | 6 +++---
 doc/xsl/list_window_functions.xml.xsl                            | 6 +++---
 15 files changed, 42 insertions(+), 42 deletions(-)
 copy doc/xsl/{list_curved_geometry_functions.xml.xsl => list_polyhedral_functions.xml.xsl} (88%)
hooks/post-receive
