[SCM] PostGIS branch master updated. 3.5.0beta1-9-gf83f78426
git at osgeo.org
git at osgeo.org
Sat Sep 21 18:10:08 PDT 2024
the project "PostGIS".
via f83f784268aac67e92fdbf0d55a007161d94ac34 (commit)
from be1c2273cdfe0490a43b0148bb8f18ce57a63916 (commit)
revisions in full, below.
commit f83f784268aac67e92fdbf0d55a007161d94ac34
Author: Regina Obe <lr at pcorp.us>
Date: Sat Sep 21 21:09:32 2024 -0400
Align release notes with NEWS file
Update pot
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 05fff215b..5e4d545bf 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2024-07-05 06:17+0000\n"
+"POT-Creation-Date: 2024-09-22 00:49+0000\n"
"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -4233,16 +4233,17 @@ msgstr ""
#, no-c-format
msgid ""
"Adds a linestring to an existing topology using a tolerance and possibly "
-"splitting existing edges/faces. Returns edge identifiers."
+"splitting existing edges/faces."
msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Adds a linestring to an existing topology and returns a set of edge "
-"identifiers forming it up. The given line will snap to existing nodes or "
-"edges within given tolerance. Existing edges and faces may be split by the "
-"line. New nodes and faces may be added."
+"Adds a linestring to an existing topology and returns a set of signed edge "
+"identifiers forming it up (negative identifies mean the edge goes in the "
+"opposite direction of the input linestring). The given line will snap to "
+"existing nodes or edges within given tolerance. Existing edges and faces may "
+"be split by the line. New nodes and faces may be added."
msgstr ""
#. Tag: para
@@ -4252,6 +4253,11 @@ msgid ""
"caller, see <xref linkend=\"Topology_StatsManagement\"/>."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Enhanced: 3.2.0 added support for returning signed identifier."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -11070,6 +11076,16 @@ msgid ""
"instead."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Escaping names for tables and/or namespaces that include special characters "
+"and quotes may require special handling. A user notes: \"For schemas and "
+"tables, use identifier escaping rules to produce a double-quoted string, and "
+"afterwards remove the first and last double-quote character. For geometry "
+"column pass as is.\""
+msgstr ""
#. Tag: para
#, no-c-format
msgid "Changed: 2.1.0. Up to 2.0.x this was called ST_Estimated_Extent."
@@ -12370,10 +12386,10 @@ msgstr ""
msgid ""
"Creates a rectangular Polygon giving the extent of a tile in the <link xlink:"
"href=\"https://en.wikipedia.org/wiki/Tiled_web_map\">XYZ tile system</link>. "
-"The tile is specified by the zoom level Z and the XY index of the tile in the "
-"grid at that level. Can be used to define the tile bounds required by <xref "
-"linkend=\"ST_AsMVTGeom\"/> to convert geometry into the MVT tile coordinate "
-"space."
+"The tile is specified by the zoom level Z and the XY index of the tile in "
+"the grid at that level. Can be used to define the tile bounds required by "
+"<xref linkend=\"ST_AsMVTGeom\"/> to convert geometry into the MVT tile "
+"coordinate space."
msgstr ""
#. Tag: para
@@ -13812,6 +13828,16 @@ msgid ""
"invalid (see example below)."
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"If <code>cartesian_hint</code> is set to <code>true</code>, the algorithm "
+"applies additional optimizations involving cartesian math to further reduce "
+"the resulting point number. Please note that using this option might "
+"introduce rendering artifacts if the resulting coordinates are projected "
+"into another (non-cartesian) coordinate system before rendering."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -19274,6 +19300,11 @@ msgstr ""
msgid "3D geometries are supported:"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Options argument can be used to add BBOX and CRS in GeoJSON output:"
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -19332,10 +19363,10 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"16: Declare that data are lat/lon (e.g srid=4326). Default is to assume "
-"that data are planars. This option is useful for GML 3.1.1 output only, "
-"related to axis order. So if you set it, it will swap the coordinates so "
-"order is lat lon instead of database lon lat."
+"16: Declare that data are lat/lon (e.g srid=4326). Default is to assume that "
+"data are planars. This option is useful for GML 3.1.1 output only, related "
+"to axis order. So if you set it, it will swap the coordinates so order is "
+"lat lon instead of database lon lat."
msgstr ""
#. Tag: para
@@ -19619,9 +19650,9 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid ""
-"Converting a <varname>GEOMETRYCOLLECTION</varname> to MARC21/XML formatted in "
-"decimal minutes. The geometries order in the MARC21/XML output correspond to "
-"their order in the collection."
+"Converting a <varname>GEOMETRYCOLLECTION</varname> to MARC21/XML formatted "
+"in decimal minutes. The geometries order in the MARC21/XML output correspond "
+"to their order in the collection."
msgstr ""
#. Tag: refpurpose
@@ -21007,8 +21038,8 @@ msgid ""
"The optional third parameter controls the buffer accuracy and style. The "
"accuracy of circular arcs in the buffer is specified as the number of line "
"segments used to approximate a quarter circle (default is 8). The buffer "
-"style can be specified by providing a list of blank-separated key=value pairs "
-"as follows:"
+"style can be specified by providing a list of blank-separated key=value "
+"pairs as follows:"
msgstr ""
#. Tag: para
@@ -22591,7 +22622,7 @@ msgid ""
"The reduction in vertex count is controlled by the <varname>vertex_fraction</"
"varname> parameter, which is a number in the range 0 to 1. Lower values "
"produce simpler results, with smaller vertex count and less concaveness. For "
-"both outer and inner hulls a vertex fraction of 1.0 produces the orginal "
+"both outer and inner hulls a vertex fraction of 1.0 produces the original "
"geometry. For outer hulls a value of 0.0 produces the convex hull (for a "
"single polygon); for inner hulls it produces a triangle."
msgstr ""
@@ -26944,9 +26975,11 @@ msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid ""
-"Returns the raster clipped by the input geometry. If band number not is "
+"Returns the raster clipped by the input geometry. If band number is not "
"specified, all bands are processed. If <varname>crop</varname> is not "
-"specified or TRUE, the output raster is cropped."
+"specified or TRUE, the output raster is cropped. If <varname>touched</"
+"varname> is set to TRUE, then touched pixels are included, otherwise only if "
+"the center of the pixel is in the geometry it is included."
msgstr ""
#. Tag: para
@@ -30985,7 +31018,8 @@ msgstr ""
msgid ""
"It is better to use a named relationship function if available, since they "
"automatically use a spatial index where one exists. Also, they may implement "
-"performance optimizations which are not available with full relate evaluation."
+"performance optimizations which are not available with full relate "
+"evaluation."
msgstr ""
#. Tag: para
@@ -31983,6 +32017,11 @@ msgid ""
"do and like most aggregates, it also ignores NULL geometries."
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Perform 3D union using postgis_sfcgal."
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
@@ -32499,8 +32538,8 @@ msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid ""
-"Perform surface Tessellation of a polygon or polyhedralsurface and returns as "
-"a TIN or collection of TINS"
+"Perform surface Tessellation of a polygon or polyhedralsurface and returns "
+"as a TIN or collection of TINS"
msgstr ""
#. Tag: para
@@ -34189,6 +34228,16 @@ msgid ""
">, <xref linkend=\"PostGIS_Version\"/>"
msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Returns the version number of the libjson-c library."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Returns the version number of the LibJSON-C library."
+msgstr ""
#. Tag: refpurpose
#, no-c-format
msgid "<refpurpose>Returns build date of the PostGIS library.</refpurpose>"
@@ -34509,6 +34558,44 @@ msgstr ""
msgid "Remove the WFS_locks extra package. (Paul Ramsey)"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5747\">5747</link>, "
+"<link xlink:href=\"https://github.com/postgis/postgis/pull/776\">GH-776</"
+"link>, ST_Length: Return 0 for CurvePolygon (Dan Baston)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5770\">5770</link>, "
+"support for GEOS 3.13 and RelateNG. Most functionality remains the same, but "
+"new GEOS predicate implementation has a few small changes."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Boundary Node Rule relate matrices might be different when using the \"multi-"
+"valent end point\" rule."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Relate matrices for situations with invalid MultiPolygons with shared "
+"boundaries might be different. Run ST_MakeValid to get valid inputs to feed "
+"to the calculation."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Zero length LineStrings are treated as if they are the equivalent Point "
+"object."
+msgstr ""
#. Tag: title
#, no-c-format
msgid "Deprecated signatures"
@@ -34648,6 +34735,13 @@ msgstr ""
msgid "Enhancements"
msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5550\">5550</link>, "
+"Fix upgrades from 2.x in sandboxed systems (Sandro Santilli)"
+msgstr ""
#. Tag: para
#, no-c-format
msgid ""
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index 0f8ca5ab7..bb10ff8cc 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -9364,7 +9364,7 @@ FROM dummy_rast WHERE rid=2;
<refentry xml:id="RT_ST_Clip">
<refnamediv>
<refname>ST_Clip</refname>
- <refpurpose>Returns the raster clipped by the input geometry. If band number not is specified, all bands are processed. If <varname>crop</varname> is not specified or TRUE, the output raster is cropped.</refpurpose>
+ <refpurpose>Returns the raster clipped by the input geometry. If band number is not specified, all bands are processed. If <varname>crop</varname> is not specified or TRUE, the output raster is cropped. If <varname>touched</varname> is set to TRUE, then touched pixels are included, otherwise only if the center of the pixel is in the geometry it is included.</refpurpose>
</refnamediv>
<refsynopsisdiv>
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 7b5bad8be..4b4c26caf 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -41,6 +41,17 @@
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5659">#5659</link>, ST_DFullyWithin behaviour has changed to
be ST_Contains(ST_Buffer(A, R), B) (Paul Ramsey)</para>
<para>Remove the WFS_locks extra package. (Paul Ramsey)</para>
+<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5747">5747</link>, <link xlink:href="https://github.com/postgis/postgis/pull/776">GH-776</link>, ST_Length: Return 0 for CurvePolygon (Dan Baston)</para>
+<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5770">5770</link>, support for GEOS 3.13 and RelateNG. Most functionality
+ remains the same, but new GEOS predicate implementation
+ has a few small changes.</para>
+ <para>Boundary Node Rule relate matrices might be different when
+ using the "multi-valent end point" rule.</para>
+ <para>Relate matrices for situations with invalid MultiPolygons
+ with shared boundaries might be different. Run ST_MakeValid
+ to get valid inputs to feed to the calculation.</para>
+ <para>Zero length LineStrings are treated as if they are the
+ equivalent Point object.</para>
</simplesect>
<simplesect><title>Deprecated signatures</title>
@@ -82,6 +93,7 @@
<simplesect>
<title>Enhancements</title>
+ <para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5550">5550</link>, Fix upgrades from 2.x in sandboxed systems (Sandro Santilli)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/3587">#3587</link>, postgis_topology: faster load of big lines in topologies (Sandro Santilli)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5670">#5670</link>, postgis_topology: faster ST_CreateTopoGeo (Sandro Santilli)</para>
<para><link xlink:href="https://trac.osgeo.org/postgis/ticket/5531">#5531</link>, documentation format upgraded to DocBook 5 (Sandro Santilli)</para>
Summary of changes:
doc/po/templates/postgis-manual.pot | 144 +++++++++++++++++++++++++++++-------
doc/reference_raster.xml | 2 +-
doc/release_notes.xml | 12 +++
3 files changed, 132 insertions(+), 26 deletions(-)
hooks/post-receive
