[PostGIS] #5782: TopoGeo_addLinestring corrups topology: adjacent edges 33 and -32 bind different face (1 and 0)
trac at osgeo.org
Tue Sep 24 03:27:57 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.0
Component: topology | Version:
Resolution: | Keywords:
Comment (by strk):
Of course the same problem occurs with GetFaceContainingPoint:
=# select GetFaceContainingPoint('t5782', 'POINT(18.006691126034692
69.04048768506776)');
getfacecontainingpoint
1
(1 row)
Both edges are found to have no interior intersection with the shortest
line between the query point and edge 3:
=# with candidate as ( select ST_ShortestLine('POINT(18.006691126034692
69.04048768506776)', geom) sl from t5782.edge where edge_id = 3) select
edge_id, ST_Relate(geom, sl) from t5782.edge, candidate where
ST_Intersects(geom, sl)
edge_id | st_relate
4 | F01FF0102
3 | F01FF0102
(2 rows)
And both edges are found to have an interior intersection with the
shortest line between query point and edge 4:
69.04048768506776)', geom) sl from t5782.edge where edge_id = 4) select
edge_id | st_relate
4 | 0F1FF0102
3 | 0F1FF0102
(2 rows)
I don't feel I can trust any of the above
Here's a picture of the shortest line between query point and any of the
two edges:
[[Image(shortestLine.png)]]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:13>
