[PostGIS] #5665: st_concavehull Unable to find shell join index with interior join line error on valid geometry
PostGIS trac at osgeo.org
Tue Sep 24 06:46:14 PDT 2024
  Reporter:  mapcreatorguus  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS GEOS
 Component:  postgis         |    Version:  3.4.x
Resolution:                  |   Keywords:  st_concavehull
Comment (by latot):
 Replying to [comment:3 mdavis]:
 > Replying to [comment:1 latot]:
 > > Hi, here a simpler version I found today
 > The second case is an invalid polygonal geometry (overlapping polygons).
 So it doesn't work for the concave hull of polygons algorithm.
 !! So support for overlapping polygons should be a new issue?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5665#comment:6>
