[PostGIS] #5782: TopoGeo_addLinestring corrups topology: adjacent edges 33 and -32 bind different face (1 and 0)
trac at osgeo.org
Tue Sep 24 07:58:52 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.4
Component: topology | Version:
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
Replying to [comment:13 strk]:
> Of course the same problem occurs with GetFaceContainingPoint:
> =# select GetFaceContainingPoint('t5782', 'POINT(18.006691126034692
69.04048768506776)');
> getfacecontainingpoint
> 1
> (1 row)
> Both edges are found to have no interior intersection with the shortest
line between the query point and edge 3:
> =# with candidate as ( select ST_ShortestLine('POINT(18.006691126034692
69.04048768506776)', geom) sl from t5782.edge where edge_id = 3) select
edge_id, ST_Relate(geom, sl) from t5782.edge, candidate where
ST_Intersects(geom, sl)
> edge_id | st_relate
> 4 | F01FF0102
> 3 | F01FF0102
> (2 rows)
> And both edges are found to have an interior intersection with the
shortest line between query point and edge 4:
69.04048768506776)', geom) sl from t5782.edge where edge_id = 4) select
> edge_id | st_relate
> 4 | 0F1FF0102
> 3 | 0F1FF0102
> (2 rows)
> I don't feel I can trust any of the above
Can it be related to performance or other fixes in GEOS ?
Does it for instance fail on GEOS from 2023 ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:16>
