[PostGIS] #5782: TopoGeo_addLinestring corrups topology: adjacent edges 33 and -32 bind different face (1 and 0)
trac at osgeo.org
Thu Sep 26 03:13:16 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.4
Component: topology | Version:
Resolution: | Keywords:
Comment (by strk):
Replying to [comment:19 Lars Aksel Opsahl]:
> So if ST_Distance in postgis had used the same GEOS call that you do it
would have worked ?
In this specific case YES, I've tried it and if `ST_Distance` used
GEOSDistance the test would pass. I guess the reason to use liblwgeom
would be avoidinng the conversion to GEOS but if it gives wrong answers we
could switch over.
What Martin says about distance being not robust enough remains as a
problem though...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:24>
