[PostGIS] #5782: TopoGeo_addLinestring corrups topology: adjacent edges 33 and -32 bind different face (1 and 0)
trac at osgeo.org
Thu Sep 26 06:39:35 PDT 2024
Reporter: Lars Aksel Opsahl | Owner: strk
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.4.4
Component: topology | Version:
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
> POSTGIS="3.5.0dev 3.5.0rc1-5-gb9d4311f9" [EXTENSION] PGSQL="160"
GEOS="3.13.0-CAPI-1.19.0" PROJ="9.3.0 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/tmp/proj
DATABASE_PATH=/usr/local/share/proj/proj.db" (compiled against PROJ
9.13.0) LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" TOPOLOGY
With the code abouve this is the first error I always see
XX000 message: Programmatic error ? Geometry of face 38716
Then I end with errorss like this
Corrupted topology: face 559 could not be constructed only
The problem seems to frequent running higher tolerance, I am now using
1e-04.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5782#comment:28>
