[SCM] PostGIS branch master updated. 3.5.0-4-gb28f00c3e
git at osgeo.org
git at osgeo.org
Thu Sep 26 13:55:42 PDT 2024
the project "PostGIS".
via b28f00c3efd772460714cb9db30b0dc9a0ff27fd (commit)
via 6e0291a73bb565dab7e395132b356e5e4e6d2952 (commit)
from 126f44b423595b9c8c9bb8637240f19ed6b5d40e (commit)
revisions in full, below.
commit b28f00c3efd772460714cb9db30b0dc9a0ff27fd
Merge: 126f44b42 6e0291a73
Author: Loïc Bartoletti <lituus at free.fr>
Date: Thu Sep 26 13:55:40 2024 -0700
Merge pull request 'fix(test): Fix deprecated call of ST_* functions for SFCGAL. Use CG_* ones' (!217) from lbartoletti/postgis:fix_deprecated_regress into master
Reviewed-on: https://gitea.osgeo.org/gitea/postgis/postgis/pulls/217
commit 6e0291a73bb565dab7e395132b356e5e4e6d2952
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date: Thu Sep 26 07:08:18 2024 +0200
diff --git a/sfcgal/regress/alphashape.sql b/sfcgal/regress/alphashape.sql
index 6d9b4c203..23dcee024 100644
--- a/sfcgal/regress/alphashape.sql
+++ b/sfcgal/regress/alphashape.sql
@@ -1,9 +1,9 @@
-SELECT 'ST_AlphaShape_default',
- ST_AsText(ST_AlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))'));
-SELECT 'ST_AlphaShape_hole',
- ST_AsText(ST_AlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))', allow_holes => true));
+SELECT 'CG_AlphaShape_default',
+ ST_AsText(CG_AlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))'));
+SELECT 'CG_AlphaShape_hole',
+ ST_AsText(CG_AlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))', allow_holes => true));
-SELECT 'ST_OptimalAlphaShape_default',
- ST_AsText(ST_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))'));
-SELECT 'ST_OptimalAlphaShape_hole',
- ST_AsText(ST_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))', allow_holes => true));
+SELECT 'CG_OptimalAlphaShape_default',
+ ST_AsText(CG_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))'));
+SELECT 'CG_OptimalAlphaShape_hole',
+ ST_AsText(CG_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))', allow_holes => true));
diff --git a/sfcgal/regress/alphashape_expected b/sfcgal/regress/alphashape_expected
index 4ed0fe5f1..4e3a2c5b3 100644
--- a/sfcgal/regress/alphashape_expected
+++ b/sfcgal/regress/alphashape_expected
@@ -1,4 +1,4 @@
-ST_AlphaShape_default|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3))
-ST_AlphaShape_hole|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3),(3.6 6.1,3.6 6.8,4 7.5,4.3 8,6 8.1,6.8 7.3,7.7 6.7,8.1 6,8.2 5.4,8.1 4.7,7.8 4.3,7.6 2.7,6.2 2.2,5.4 3.2,4.4 4.2,3.8 4.6,3.6 6.1))
-ST_OptimalAlphaShape_default|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3))
-ST_OptimalAlphaShape_hole|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3),(3.6 6.1,3.6 6.8,4 7.5,4.3 8,5 8.6,6 8.1,6.8 7.3,7.7 6.7,8.1 6,8.2 5.4,8.1 4.7,7.8 4.3,8.1 2.9,7.6 2.7,7 2,6.2 2.2,5.5 2.6,5.4 3.2,4.8 3.4,4.4 4.2,3.8 4.6,3.6 6.1))
+CG_AlphaShape_default|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3))
+CG_AlphaShape_hole|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3),(3.6 6.1,3.6 6.8,4 7.5,4.3 8,6 8.1,6.8 7.3,7.7 6.7,8.1 6,8.2 5.4,8.1 4.7,7.8 4.3,7.6 2.7,6.2 2.2,5.4 3.2,4.4 4.2,3.8 4.6,3.6 6.1))
+CG_OptimalAlphaShape_default|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3))
+CG_OptimalAlphaShape_hole|POLYGON((8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3),(3.6 6.1,3.6 6.8,4 7.5,4.3 8,5 8.6,6 8.1,6.8 7.3,7.7 6.7,8.1 6,8.2 5.4,8.1 4.7,7.8 4.3,8.1 2.9,7.6 2.7,7 2,6.2 2.2,5.5 2.6,5.4 3.2,4.8 3.4,4.4 4.2,3.8 4.6,3.6 6.1))
diff --git a/sfcgal/regress/approximatemedialaxis.sql b/sfcgal/regress/approximatemedialaxis.sql
index e3611b828..1b5c10519 100644
--- a/sfcgal/regress/approximatemedialaxis.sql
+++ b/sfcgal/regress/approximatemedialaxis.sql
@@ -1,2 +1,2 @@
-SELECT 'square', ST_AsEwkt(ST_ApproximateMedialAxis('SRID=3857;POLYGON((0 0,1 0,1 1,0 1,0 0))'));
-SELECT 'rect1', ST_AsEwkt(ST_ApproximateMedialAxis('SRID=4326;POLYGON((0 0,2 0,2 1,0 1,0 0))'));
+SELECT 'square', ST_AsEwkt(CG_ApproximateMedialAxis('SRID=3857;POLYGON((0 0,1 0,1 1,0 1,0 0))'));
+SELECT 'rect1', ST_AsEwkt(CG_ApproximateMedialAxis('SRID=4326;POLYGON((0 0,2 0,2 1,0 1,0 0))'));
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index bbbc8fe3a..c46949a38 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -7,40 +7,40 @@
SELECT 'postgis_sfcgal_version', count(*) FROM (SELECT postgis_sfcgal_version()) AS f;
SELECT 'postgis_sfcgal_noop', ST_NPoints(postgis_sfcgal_noop(ST_Buffer('POINT(0 0)', 5)));
-SELECT 'ST_Tesselate', ST_AsText(ST_Tesselate('GEOMETRYCOLLECTION(POINT(4 4),POLYGON((0 0,1 0,1 1,0 1,0 0)))'));
-SELECT 'ST_3DArea', ST_3DArea('POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))');
-SELECT 'ST_Extrude_point', ST_AsText(ST_Extrude('POINT(0 0)', 1, 0, 0));
-SELECT 'ST_Extrude_line', ST_AsText(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0));
+SELECT 'CG_Tesselate', ST_AsText(CG_Tesselate('GEOMETRYCOLLECTION(POINT(4 4),POLYGON((0 0,1 0,1 1,0 1,0 0)))'));
+SELECT 'CG_3DArea', CG_3DArea('POLYGON((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0))');
+SELECT 'CG_Extrude_point', ST_AsText(CG_Extrude('POINT(0 0)', 1, 0, 0));
+SELECT 'CG_Extrude_line', ST_AsText(CG_Extrude(CG_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0));
-- In the first SFCGAL versions, the extruded face was wrongly oriented
-- we change the extrusion result to match the original
-SELECT 'ST_Extrude_surface',
+SELECT 'CG_Extrude_surface',
CASE WHEN postgis_sfcgal_version() = '1.0'
THEN
- ST_AsText(ST_Extrude(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1))
+ ST_AsText(CG_Extrude(CG_Extrude(CG_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1))
ELSE
regexp_replace(
regexp_replace(
- ST_AsText(ST_Extrude(ST_Extrude(ST_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1)) ,
+ ST_AsText(CG_Extrude(CG_Extrude(CG_Extrude('POINT(0 0)', 1, 0, 0), 0, 1, 0), 0, 0, 1)) ,
E'\\(\\(0 1 0,1 1 0,1 0 0,0 1 0\\)\\)', '((1 1 0,1 0 0,0 1 0,1 1 0))'),
E'\\(\\(0 1 0,1 0 0,0 0 0,0 1 0\\)\\)', '((1 0 0,0 0 0,0 1 0,1 0 0))')
END;
-SELECT 'ST_ForceLHR', ST_AsText(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'ST_Orientation_1', ST_Orientation(ST_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'ST_Orientation_2', ST_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'ST_MinkowskiSum', ST_AsText(ST_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
-SELECT 'ST_ConstrainedDelaunayTriangles', ST_AsText(ST_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
-SELECT 'ST_3DConvexHull', ST_3DArea(ST_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'))::numeric(10,4);
--- Result of ST_3DUnion is not deterministic and cannot be checked by
+SELECT 'CG_ForceLHR', ST_AsText(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_Orientation_1', CG_Orientation(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_Orientation_2', CG_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_MinkowskiSum', ST_AsText(CG_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
+SELECT 'CG_ConstrainedDelaunayTriangles', ST_AsText(CG_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
+SELECT 'CG_3DConvexHull', CG_3DArea(CG_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'))::numeric(10,4);
+-- Result of CG_3DUnion is not deterministic and cannot be checked by
-- simple string comparison
-SELECT 'ST_3DUnion', ABS(ST_Volume(ST_3DUnion(g1, g2)) - 40) < 1e-12 FROM (
- SELECT ST_Extrude(ST_GeomFromText('POLYGON((-2 -2 -1, 2 -2 -1, 2 2 -1, -2 2 -1, -2 -2 -1))'), 0, 0, 2) AS g1,
- ST_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g2
+SELECT 'CG_3DUnion', ABS(CG_Volume(CG_3DUnion(g1, g2)) - 40) < 1e-12 FROM (
+ SELECT CG_Extrude(ST_GeomFromText('POLYGON((-2 -2 -1, 2 -2 -1, 2 2 -1, -2 2 -1, -2 -2 -1))'), 0, 0, 2) AS g1,
+ CG_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g2
) AS f;
-SELECT 'ST_3DUnion (aggregate)', ABS(ST_Volume(ST_3DUnion(g))) - 40 < 1e-12 FROM (
+SELECT 'CG_3DUnion (aggregate)', ABS(CG_Volume(CG_3DUnion(g))) - 40 < 1e-12 FROM (
UNION
- SELECT ST_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g
+ SELECT CG_Extrude(ST_GeomFromText('POLYGON((-1 -1 -2, 1 -1 -2, 1 1 -2, -1 1 -2, -1 -1 -2))'), 0, 0, 4) AS g
) AS f;
diff --git a/sfcgal/regress/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
index 772eeb04f..7f18a4088 100644
--- a/sfcgal/regress/regress_sfcgal_expected
+++ b/sfcgal/regress/regress_sfcgal_expected
@@ -1,18 +1,18 @@
postgis_sfcgal_version|1
postgis_sfcgal_noop|33
-ST_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0 1,0 0,1 0,0 1))))
-ST_3DArea|1
-ST_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
-ST_Extrude_line|POLYHEDRALSURFACE Z (((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0)))
-ST_Extrude_surface|POLYHEDRALSURFACE Z (((1 1 0,1 0 0,0 1 0,1 1 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((1 0 0,0 0 0,0 1 0,1 0 0)),((0 1 1,0 0 1,1 0 1,0 1 1)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((1 1 0,0 1 0,0 1 1,1 1 1,1 1 0)),((0 1 0,0 0 0,0 0 1,0 1 1,0 1 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)))
-ST_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
-ST_Orientation_1|-1
-ST_Orientation_2|1
-ST_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
-ST_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
-ST_3DConvexHull|80.9227
-ST_3DUnion|t
-ST_3DUnion (aggregate)|t
+CG_Tesselate|GEOMETRYCOLLECTION(POINT(4 4),TIN(((0 1,1 0,1 1,0 1)),((0 1,0 0,1 0,0 1))))
+CG_3DArea|1
+CG_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
+CG_Extrude_line|POLYHEDRALSURFACE Z (((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0)))
+CG_Extrude_surface|POLYHEDRALSURFACE Z (((1 1 0,1 0 0,0 1 0,1 1 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((1 0 0,0 0 0,0 1 0,1 0 0)),((0 1 1,0 0 1,1 0 1,0 1 1)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((1 1 0,0 1 0,0 1 1,1 1 1,1 1 0)),((0 1 0,0 0 0,0 0 1,0 1 1,0 1 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)))
+CG_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
+CG_Orientation_1|-1
+CG_Orientation_2|1
+CG_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
+CG_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
+CG_3DConvexHull|80.9227
+CG_3DUnion|t
+CG_3DUnion (aggregate)|t
CG_3DArea|1
Summary of changes:
sfcgal/regress/alphashape.sql | 16 ++++++-------
sfcgal/regress/alphashape_expected | 8 +++----
sfcgal/regress/approximatemedialaxis.sql | 4 ++--
sfcgal/regress/regress_sfcgal.sql | 40 ++++++++++++++++----------------
sfcgal/regress/regress_sfcgal_expected | 26 ++++++++++-----------
5 files changed, 47 insertions(+), 47 deletions(-)
hooks/post-receive
