[SCM] PostGIS branch stable-3.3 updated. 3.3.7-2-gfbc9c5bb9
git at osgeo.org
git at osgeo.org
Sun Sep 29 11:51:26 PDT 2024
the project "PostGIS".
The branch, stable-3.3 has been updated
via fbc9c5bb9bc6f8dbc3a4a732e8bedcfd06d49868 (commit)
from e035797e5ee5e940477b7480afa999d9ba11f9b1 (commit)
revisions in full, below.
commit fbc9c5bb9bc6f8dbc3a4a732e8bedcfd06d49868
Author: Regina Obe <lr at pcorp.us>
Date: Sun Sep 29 14:50:34 2024 -0400
FIX for segfault in ST_MapAlgebra
References #5785 for PostGIS 3.3.8
Author: Dian M Fay
diff --git a/NEWS b/NEWS
index 99d994e78..dacc57dec 100644
--- a/NEWS
+++ b/NEWS
@@ -3,7 +3,8 @@ PostGIS 3.3.8
* Bug Fixes and Enhancements *
+ - #5785, [raster] ST_MapAlgebra segfaults when expression references
+ a supernumerary rast argument (Dian M Fay)
PostGIS 3.3.7
diff --git a/doc/introduction.xml b/doc/introduction.xml
index c6171e3ad..4358895a0 100644
--- a/doc/introduction.xml
+++ b/doc/introduction.xml
@@ -248,6 +248,7 @@
<member>David Garnier</member>
<member>David Skea</member>
<member>David Techer</member>
+ <member>Dian M Fay</member>
<member>Dmitry Vasilyev</member>
<member>Eduin Carrillo</member>
<member>Eugene Antimirov</member>
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index 8af585978..87df4c9dd 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -1220,6 +1220,11 @@ static int rtpg_nmapalgebraexpr_callback(
if (idx < 1) continue;
idx--; /* 1-based now 0-based */
+ if (arg->rasters == 1 && i > 7) {
+ elog(ERROR, "rtpg_nmapalgebraexpr_callback: rast2 argument specified in single-raster invocation");
+ return 0;
switch (i) {
/* [rast.x] */
case 0:
diff --git a/raster/test/regress/rt_mapalgebra_expr.sql b/raster/test/regress/rt_mapalgebra_expr.sql
index 240deb85c..78f90bb21 100644
--- a/raster/test/regress/rt_mapalgebra_expr.sql
+++ b/raster/test/regress/rt_mapalgebra_expr.sql
@@ -128,6 +128,11 @@ SELECT ST_Value(rast, 1, 1),
ST_Value(ST_MapAlgebra(rast, 1, NULL, '[rast]/0'), 1, 1)
FROM ST_TestRaster(0, 0, 10) rast;
+-- Test being cheeky with rast2 in a single-rast invocation
+SELECT ST_Value(rast, 1, 1),
+ ST_Value(ST_MapAlgebra(rast, 1, NULL, '[rast2.val]+1'), 1, 1)
+FROM ST_TestRaster(0, 0, 10) rast;
-- Test evaluations to null (see #1523)
WITH op AS ( select rast AS rin,
ST_MapAlgebra(rast, 1, NULL, 'SELECT g from (SELECT NULL::double precision as g) as foo', 2)
diff --git a/raster/test/regress/rt_mapalgebra_expr_expected b/raster/test/regress/rt_mapalgebra_expr_expected
index ac33621e0..dccd7fc46 100644
--- a/raster/test/regress/rt_mapalgebra_expr_expected
+++ b/raster/test/regress/rt_mapalgebra_expr_expected
@@ -18,6 +18,7 @@ T10.8.2|10|50
T10.8.3|10|37
T10.8.4|10|30
ERROR: division by zero
+ERROR: rtpg_nmapalgebraexpr_callback: rast2 argument specified in single-raster invocation
T11.1|10|2
T11.2|10|2
T12|t|t|t|t
Summary of changes:
NEWS | 3 ++-
doc/introduction.xml | 1 +
raster/rt_pg/rtpg_mapalgebra.c | 5 +++++
raster/test/regress/rt_mapalgebra_expr.sql | 5 +++++
raster/test/regress/rt_mapalgebra_expr_expected | 1 +
5 files changed, 14 insertions(+), 1 deletion(-)
hooks/post-receive
