[PostGIS] #5958: Importing tiles with raster2pgsql
PostGIS trac at osgeo.org
Fri Aug 1 02:41:58 PDT 2025
 Reporter:  panden               |      Owner:  robe
     Type:  defect               |     Status:  new
 Priority:  medium               |  Milestone:  PostGIS 3.5.4
Component:  raster               |    Version:  3.5.x
 Keywords:  raster2pgsql raster  |
 Also sent to the mailing list:
 * 2024-12-12: https://lists.osgeo.org/pipermail/postgis-
 users/2024-December/046620.html
 * 2025-07-24: https://lists.osgeo.org/pipermail/postgis-
 users/2025-July/046819.html
 == Description
 **NB**: Screenshots, tif-files and script in zip-file attached to ticket.
 I have a dataset with several hundred tiles (GeoTIFFs) that make up a
 digital terrain model.
 Each tile is 0.5d x 0.5d.
 I tried to load these GeoTIFFs to PostGIS with:
 $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 tif/*.tif
 (1)
 The data was loaded, but when viewing in QGIS, it looked like jagged lines
 with areas of white overlain by pieces of neighboring tiles, etc.
 This didn't look right.
 I also noticed that for each tif, the constraints were printed.
 I expected this to be done once, after the last tile was loaded.
 I then created a virtual raster with gdalbuildvrt:
 $ gdalbuildvrt merge.vrt tif/*.tif (2)
 And then used raster2pgsql to load in the vrt:
 $ raster2pgsql -s 32631 -I -M -F -C -t auto -d -l 2,4,8,16,32 merge.vrt |
 psql (3)
 The data was loaded, and looked good in QGIS.
 == Expectation
 I expected commands (1) and (3) to give the same results.
 This was confirmed by one of the replies on the mailing list
 (https://lists.osgeo.org/pipermail/postgis-
 users/2024-December/046621.html).
 I checked the extent of the tiles, and 'NHS-D0309_50M_E25833.tif' has a
 different extent that is incompatible with the other tiles.
 All the other tifs are lined up with coordinates ending in 00, 25, 50 and
 75; 'NHS-D0309_50M_E25833.tif' does not.
 This explains the not aligned-stuff, and if I remove that tile, no
 misalignment notices are given.
 This does not solve my problem regarding the data looking strange in QGIS,
 unfortunately. I still get an image like the one in
 merge_raster2pgsql.png.
 Forcing the size in raster2pgsql to 128x128 does not help.
 == System details
 anbj=# SELECT version();
                                         version
  PostgreSQL 17.5 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 15.1.1
 20250425, 64-bit
 (1 row)
 anbj=# SELECT PostGIS_Full_Version();
 postgis_full_version
  POSTGIS="3.5.2 POSTGIS_REVISION" [EXTENSION] PGSQL="170"
 GEOS="3.13.1-CAPI-1.19.2" PROJ="9.6.0 NETWORK_ENABLED=OFF URL_ENDPOINT=
 https://cdn.proj.org USER_WRITABLE_DIRECTORY
 =/var/lib/postgres/.local/share/proj
 DATABASE_PATH=/usr/share/proj/proj.db"
 (compiled against PROJ 9.6.0) GDAL="GDAL 3.11.3 "Eganville", released
 2025/07/12" LIBXML="2.14.3"
  LIBJSON="0.18" LIBPROTOBUF="1.5.2" WAGYU="0.5.0 (Internal)" (core procs
 from "3.5.2 dea6d0a" need upgrade) RASTER (raster procs from "3.5.2
 (1 row)
 $ raster2pgsql
 RELEASE: 3.5.2 GDAL_VERSION=311 (POSTGIS_REVISION)
 $ gdalinfo --version
 GDAL 3.11.3 "Eganville", released 2025/07/12
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5958>
