[SCM] PostGIS branch master updated. 3.6.0beta1-15-gbc0854651
git at osgeo.org
git at osgeo.org
Mon Aug 4 16:13:35 PDT 2025
the project "PostGIS".
via bc08546510ebfbd458c42f22dd696f50bd81ac95 (commit)
from 8ec61f3b879a64cda6f2b1f82cca0acaf316cd87 (commit)
revisions in full, below.
commit bc08546510ebfbd458c42f22dd696f50bd81ac95
Author: Regina Obe <lr at pcorp.us>
Date: Tue Aug 13 19:09:48 2024 -0400
SCHEMA qualify extension dependencies
for PG16 and above for postgis_tiger_geocoder
- schema qualify in scripts dependent extensions postgis, fuzzystrmatch
- add a no_relocate clause to the .control file to prevent relocation
of these for PG16 and above
- Use for new installs typmod for geometry instead of constraints
- Ignore regression.out files generated by installcheck
Closes #5359
Closes #5897
Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/260
diff --git a/.gitignore b/.gitignore
index 1349b5322..e9e76c0a9 100644
--- a/.gitignore
+++ b/.gitignore
@@ -27,6 +27,7 @@ doc/html/postgis-*
doc/images
doc/html/images/generator
doc/html/images/Makefile
+regression.out
# PNG images under doc/html/images
# should be either symlinks or generated
diff --git a/NEWS b/NEWS
index 895ca9083..b9105175a 100644
--- a/NEWS
+++ b/NEWS
@@ -19,6 +19,9 @@ Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)
- GT-252, ST_NumGeometries/ST_GeometryN treat TIN and PolyhedralSurface as unitary geometries,
use ST_NumPatches/ST_PatchN for patch access (Loïc Bartoletti)
- #3110, GT-242 [topology] Support for bigint (Ayo Adesugba, U.S. Census Bureau)
+ - #5359, #5897, GT-260 [tiger_geocoder] Use @extschema:extension@ for PG >= 16
+ to schema qualify dependent extensions, switch to use typmod for tiger tables
+ (Regina Obe)
* Deprecated / Removed signatures *
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index 37193e0ae..2d8e80259 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -1,5 +1,6 @@
include @srcdir@/../upgradeable_versions.mk
+POSTGIS_PGSQL_VERSION=@POSTGIS_PGSQL_VERSION@
EXTENSION = postgis_tiger_geocoder
EXTVERSION = @POSTGIS_LIB_VERSION@
MINORVERSION = 2011. at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@
@@ -50,8 +51,15 @@ expected:
sql:
mkdir -p $@
+## PostgreSQL < 16 doesn't understand new @extschema:extname@ syntax, so strip it
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" "<" 160),1)
sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
+ $(PERL) -lpe "s/\@extschema:[a-z]+\@\./ /g" < $< > $@
+else
+ sql/$(EXTENSION)--$(EXTVERSION).sql: sql/$(EXTENSION).sql | sql
cp $< $@
+endif
expected/test-normalize_address.out: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/normalize_address_regress | expected
cat $^ > $@
@@ -66,10 +74,15 @@ sql/test-normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../..
sql/test-upgrade.sql: | sql
echo 'ALTER EXTENSION ${EXTENSION} UPDATE TO "ANY"; ALTER EXTENSION ${EXTENSION} UPDATE TO "$(EXTVERSION)"' > $@
+## no_relocate clause is only availabe in PostgreSQL 16 and above, so strip it for lower
%.control: %.control.in Makefile
- cat $< \
- | $(PERL) -lpe "s'@EXTVERSION@'$(EXTVERSION)'g" \
+ $(PERL) -lpe 's/^no_relocate.*//g; s/\@EXTVERSION\@/$(EXTVERSION)/g' < "$<" > "$@"
+else
+%.control: %.control.in Makefile
+ $(PERL) -lpe "s'@EXTVERSION@'$(EXTVERSION)'g" \
+endif
expected/test-upgrade.out: sql/test-upgrade.sql | expected
cp $< $@
diff --git a/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in b/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in
index 25a963e47..647cba6b8 100644
--- a/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in
+++ b/extensions/postgis_tiger_geocoder/postgis_tiger_geocoder.control.in
@@ -5,3 +5,4 @@ relocatable = false
schema = tiger
requires = 'postgis,fuzzystrmatch'
superuser= false
+no_relocate = 'postgis,fuzzystrmatch'
\ No newline at end of file
diff --git a/extras/tiger_geocoder/geocode/geocode_intersection.sql b/extras/tiger_geocoder/geocode/geocode_intersection.sql
index 12db663aa..3029e23c1 100644
--- a/extras/tiger_geocoder/geocode/geocode_intersection.sql
+++ b/extras/tiger_geocoder/geocode/geocode_intersection.sql
@@ -100,10 +100,10 @@ BEGIN
ST_StartPoint(ST_GeometryN(ST_Multi(e1.the_geom),1))
ELSE ST_EndPoint(ST_GeometryN(ST_Multi(e1.the_geom),1)) END AS geom ,
CASE WHEN lower(p.name) = $3 THEN 0 ELSE 1 END
- + levenshtein_ignore_case(p.name, $3)
- + levenshtein_ignore_case(e1.name || COALESCE('' '' || e1.sufqualabr, ''''),$2) +
- CASE WHEN e1.fullname = $6 THEN 0 ELSE levenshtein_ignore_case(e1.fullname, $6) END +
- + levenshtein_ignore_case(e2.name || COALESCE('' '' || e2.sufqualabr, ''''),$4)
+ + tiger.levenshtein_ignore_case(p.name, $3)
+ + tiger.levenshtein_ignore_case(e1.name || COALESCE('' '' || e1.sufqualabr, ''''),$2) +
+ CASE WHEN e1.fullname = $6 THEN 0 ELSE tiger.levenshtein_ignore_case(e1.fullname, $6) END +
+ + tiger.levenshtein_ignore_case(e2.name || COALESCE('' '' || e2.sufqualabr, ''''),$4)
AS a_rating
FROM e1
INNER JOIN e2 ON (
diff --git a/extras/tiger_geocoder/geocode/geocode_location.sql b/extras/tiger_geocoder/geocode/geocode_location.sql
index c99ee3d44..af062fcbf 100644
--- a/extras/tiger_geocoder/geocode/geocode_location.sql
+++ b/extras/tiger_geocoder/geocode/geocode_location.sql
@@ -24,7 +24,7 @@ BEGIN
zip.zip as zip,
ST_Centroid(zcta5.the_geom) as address_geom,
stusps as state,
- 100::integer + coalesce(levenshtein_ignore_case(coalesce(zip.city), parsed.location),0) as in_rating
+ 100::integer + coalesce( tiger.levenshtein_ignore_case(coalesce(zip.city), parsed.location),0) as in_rating
FROM
zip_lookup_base zip
JOIN zcta5 ON (zip.zip = zcta5.zcta5ce AND zip.statefp = zcta5.statefp)
@@ -32,7 +32,7 @@ BEGIN
WHERE
parsed.zip = zip.zip OR
(soundex(zip.city) = soundex(parsed.location) and zip.statefp = in_statefp)
- ORDER BY levenshtein_ignore_case(coalesce(zip.city), parsed.location), zip.zip
+ ORDER BY tiger.levenshtein_ignore_case(coalesce(zip.city), parsed.location), zip.zip
LOOP
ADDY.location := result.place;
ADDY.stateAbbrev := result.state;
@@ -58,11 +58,11 @@ BEGIN
|| ' pl.name as place, '
|| ' state.stusps as stateAbbrev, '
|| ' ST_Centroid(pl.the_geom) as address_geom, '
- || ' 100::integer + levenshtein_ignore_case(coalesce(pl.name), ' || quote_literal(coalesce(parsed.location,'')) || ') as in_rating '
+ || ' 100::integer + tiger.levenshtein_ignore_case(coalesce(pl.name), ' || quote_literal(coalesce(parsed.location,'')) || ') as in_rating '
|| ' FROM (SELECT * FROM place WHERE statefp = ' || quote_literal(coalesce(in_statefp,'')) || ' ' || COALESCE(' AND ST_Intersects(' || quote_literal(restrict_geom::text) || '::geometry, the_geom)', '') || ') AS pl '
|| ' INNER JOIN state ON(pl.statefp = state.statefp)'
|| ' WHERE soundex(pl.name) = soundex(' || quote_literal(coalesce(parsed.location,'')) || ') and pl.statefp = ' || quote_literal(COALESCE(in_statefp,''))
- || ' ORDER BY levenshtein_ignore_case(coalesce(pl.name), ' || quote_literal(coalesce(parsed.location,'')) || ');'
+ || ' ORDER BY tiger.levenshtein_ignore_case(coalesce(pl.name), ' || quote_literal(coalesce(parsed.location,'')) || ');'
IF var_debug THEN
diff --git a/extras/tiger_geocoder/geocode/rate_attributes.sql b/extras/tiger_geocoder/geocode/rate_attributes.sql
index 17b44216e..1949dcbde 100644
--- a/extras/tiger_geocoder/geocode/rate_attributes.sql
+++ b/extras/tiger_geocoder/geocode/rate_attributes.sql
@@ -14,7 +14,7 @@ DECLARE
var_verbose BOOLEAN := FALSE;
BEGIN
IF locationA IS NOT NULL AND locationB IS NOT NULL THEN
- result := levenshtein_ignore_case(locationA, locationB);
+ result := tiger.levenshtein_ignore_case(locationA, locationB);
ELSE
IF var_verbose THEN
RAISE NOTICE 'rate_attributes() - Location names cannot be null!';
@@ -41,7 +41,7 @@ DECLARE
typeWeight INTEGER := 5;
var_verbose BOOLEAN := false;
BEGIN
- result := result + levenshtein_ignore_case(cull_null($1), cull_null($2)) * directionWeight;
+ result := result + tiger.levenshtein_ignore_case(cull_null($1), cull_null($2)) * directionWeight;
IF var_verbose THEN
RAISE NOTICE 'streetNameA: %, streetNameB: %', streetNameA, streetNameB;
END IF;
@@ -52,15 +52,15 @@ BEGIN
IF prequalabr IS NOT NULL THEN
-- If the reference address (streetNameB) has a prequalabr streetNameA (prequalabr) - note: streetNameB usually comes thru without prequalabr
-- and the input street (streetNameA) is lacking the prequal -- only penalize a little
- result := (result + levenshtein_ignore_case( trim( trim( lower(streetNameA),lower(prequalabr) ) ), trim( trim( lower(streetNameB),lower(prequalabr) ) ) )*nameWeight*0.75 + levenshtein_ignore_case(trim(streetNameA),prequalabr || ' ' || streetNameB) * nameWeight*0.25)::integer;
+ result := (result + tiger.levenshtein_ignore_case( trim( trim( lower(streetNameA),lower(prequalabr) ) ), trim( trim( lower(streetNameB),lower(prequalabr) ) ) )*nameWeight*0.75 + tiger.levenshtein_ignore_case(trim(streetNameA),prequalabr || ' ' || streetNameB) * nameWeight*0.25)::integer;
ELSE
- result := result + levenshtein_ignore_case(streetNameA, streetNameB) * nameWeight;
+ result := result + tiger.levenshtein_ignore_case(streetNameA, streetNameB) * nameWeight;
END IF;
ELSE
-- Penalize for numeric streets if one is completely numeric and the other is not
-- This is to minimize on highways like 3A being matched with numbered streets since streets are usually number followed by 2 characters e.g nth ave and highways are just number with optional letter for name
IF (streetNameB ~ E'[a-zA-Z]{2,10}' AND NOT (streetNameA ~ E'[a-zA-Z]{2,10}') ) OR (streetNameA ~ E'[a-zA-Z]{2,10}' AND NOT (streetNameB ~ E'[a-zA-Z]{2,10}') ) THEN
END IF;
END IF;
ELSE
@@ -69,9 +69,9 @@ BEGIN
END IF;
RETURN NULL;
END IF;
- result := result + levenshtein_ignore_case(cull_null(streetTypeA), cull_null(streetTypeB)) *
+ result := result + tiger.levenshtein_ignore_case(cull_null(streetTypeA), cull_null(streetTypeB)) *
typeWeight;
- result := result + levenshtein_ignore_case(cull_null(dirsA), cull_null(dirsB)) *
+ result := result + tiger.levenshtein_ignore_case(cull_null(dirsA), cull_null(dirsB)) *
directionWeight;
return result;
END;
diff --git a/extras/tiger_geocoder/normalize/end_soundex.sql b/extras/tiger_geocoder/normalize/end_soundex.sql
index 7b0163502..36a8bda56 100644
--- a/extras/tiger_geocoder/normalize/end_soundex.sql
+++ b/extras/tiger_geocoder/normalize/end_soundex.sql
@@ -8,9 +8,9 @@ DECLARE
BEGIN
tempString := substring($1, E'[ ,.\n\t\f]([a-zA-Z0-9]*)$');
IF tempString IS NOT NULL THEN
- tempString := soundex(tempString);
+ tempString := @extschema:fuzzystrmatch at .soundex(tempString);
ELSE
- tempString := soundex($1);
+ tempString := @extschema:fuzzystrmatch at .soundex($1);
END IF;
return tempString;
END;
diff --git a/extras/tiger_geocoder/normalize/location_extract.sql b/extras/tiger_geocoder/normalize/location_extract.sql
index be891e2bb..713a08030 100644
--- a/extras/tiger_geocoder/normalize/location_extract.sql
+++ b/extras/tiger_geocoder/normalize/location_extract.sql
@@ -47,21 +47,21 @@ BEGIN
stmt := ' SELECT'
|| ' 1,'
|| ' name,'
- || ' levenshtein_ignore_case(' || quote_literal(tempString) || ',name) as rating,'
+ || ' tiger.levenshtein_ignore_case(' || quote_literal(tempString) || ',name) as rating,'
|| ' length(name) as len'
|| ' FROM place'
|| ' WHERE ' || CASE WHEN stateAbbrev IS NOT NULL THEN 'statefp = ' || quote_literal(lstate) || ' AND ' ELSE '' END
- || ' soundex(' || quote_literal(tempString) || ') = soundex(name)'
- || ' AND levenshtein_ignore_case(' || quote_literal(tempString) || ',name) <= 2 '
+ || ' @extschema:fuzzystrmatch at .soundex(' || quote_literal(tempString) || ') = @extschema:fuzzystrmatch at .soundex(name)'
+ || ' AND tiger.levenshtein_ignore_case(' || quote_literal(tempString) || ',name) <= 2 '
|| ' UNION ALL SELECT'
|| ' 2,'
|| ' name,'
|| ' FROM cousub'
|| ' ORDER BY '
|| ' 3 ASC, 1 ASC, 4 DESC'
|| ' LIMIT 1;'
diff --git a/extras/tiger_geocoder/normalize/location_extract_countysub_fuzzy.sql b/extras/tiger_geocoder/normalize/location_extract_countysub_fuzzy.sql
index a7c642a34..bf9bcc207 100644
--- a/extras/tiger_geocoder/normalize/location_extract_countysub_fuzzy.sql
+++ b/extras/tiger_geocoder/normalize/location_extract_countysub_fuzzy.sql
@@ -31,10 +31,10 @@ BEGIN
lstate := statefp FROM state WHERE stusps = stateAbbrev;
SELECT INTO tempInt count(*) FROM cousub
WHERE cousub.statefp = lstate
- AND soundex(tempString) = end_soundex(name);
+ AND @extschema:fuzzystrmatch at .soundex(tempString) = end_soundex(name);
ELSE
- WHERE soundex(tempString) = end_soundex(name);
+ WHERE @extschema:fuzzystrmatch at .soundex(tempString) = end_soundex(name);
END IF;
IF tempInt > 0 THEN
@@ -43,41 +43,41 @@ BEGIN
IF stateAbbrev IS NOT NULL THEN
FOR rec IN SELECT name FROM cousub
- AND soundex(tempString) = end_soundex(name) LOOP
+ AND @extschema:fuzzystrmatch at .soundex(tempString) = end_soundex(name) LOOP
word_count := count_words(rec.name);
test := TRUE;
tempString := get_last_words(fullStreet, word_count);
FOR i IN 1..word_count LOOP
- IF soundex(split_part(tempString, ' ', i)) !=
- soundex(split_part(rec.name, ' ', i)) THEN
+ IF @extschema:fuzzystrmatch at .soundex(split_part(tempString, ' ', i)) !=
+ @extschema:fuzzystrmatch at .soundex(split_part(rec.name, ' ', i)) THEN
test := FALSE;
END IF;
END LOOP;
IF test THEN
-- The soundex matched, determine if the distance is better.
- IF levenshtein_ignore_case(rec.name, tempString) < tempInt THEN
+ IF @extschema:fuzzystrmatch at .levenshtein_ignore_case(rec.name, tempString) < tempInt THEN
- tempInt := levenshtein_ignore_case(rec.name, tempString);
+ tempInt := @extschema:fuzzystrmatch at .levenshtein_ignore_case(rec.name, tempString);
END IF;
END IF;
END LOOP;
ELSE
- WHERE soundex(tempString) = end_soundex(name) LOOP
+ WHERE @extschema:fuzzystrmatch at .soundex(tempString) = end_soundex(name) LOOP
test := TRUE;
test := FALSE;
END IF;
END LOOP;
IF test THEN
END IF;
END IF;
END LOOP;
diff --git a/extras/tiger_geocoder/normalize/location_extract_place_fuzzy.sql b/extras/tiger_geocoder/normalize/location_extract_place_fuzzy.sql
index 30451b0da..fa8f4977b 100644
--- a/extras/tiger_geocoder/normalize/location_extract_place_fuzzy.sql
+++ b/extras/tiger_geocoder/normalize/location_extract_place_fuzzy.sql
@@ -54,9 +54,9 @@ BEGIN
END LOOP;
IF test THEN
+ IF tiger.levenshtein_ignore_case(rec.name, tempString) < tempInt THEN
+ tempInt := tiger.levenshtein_ignore_case(rec.name, tempString);
END IF;
END IF;
END LOOP;
@@ -74,9 +74,9 @@ BEGIN
END LOOP;
IF test THEN
END IF;
END IF;
END LOOP;
diff --git a/extras/tiger_geocoder/tables/lookup_tables_2011.sql b/extras/tiger_geocoder/tables/lookup_tables_2011.sql
index 947993298..40ba3f57e 100644
--- a/extras/tiger_geocoder/tables/lookup_tables_2011.sql
+++ b/extras/tiger_geocoder/tables/lookup_tables_2011.sql
@@ -802,7 +802,7 @@ INSERT INTO place_lookup
JOIN state_lookup sl ON (pl.state = lpad(sl.st_code,2,'0'))
GROUP BY pl.state, sl.abbrev, pl.placefp, pl.name;
-CREATE INDEX place_lookup_name_idx ON place_lookup (soundex(name));
+CREATE INDEX place_lookup_name_idx ON place_lookup ( @extschema:fuzzystrmatch at .soundex(name) );
CREATE INDEX place_lookup_state_idx ON place_lookup (state);
DROP TABLE IF EXISTS tiger.county_lookup;
@@ -826,7 +826,7 @@ INSERT INTO county_lookup
JOIN state_lookup sl ON (co.state = lpad(sl.st_code,2,'0'))
GROUP BY co.state, sl.abbrev, co.county, co.name;
-CREATE INDEX county_lookup_name_idx ON county_lookup (soundex(name));
+CREATE INDEX county_lookup_name_idx ON county_lookup ( @extschema:fuzzystrmatch at .soundex(name) );
CREATE INDEX county_lookup_state_idx ON county_lookup (state);
DROP TABLE IF EXISTS tiger.countysub_lookup;
@@ -855,7 +855,7 @@ INSERT INTO countysub_lookup
JOIN county_lookup cl ON (cs.state = lpad(cl.st_code,2,'0') AND cs.county = cl.co_code)
GROUP BY cs.state, sl.abbrev, cs.county, cl.name, cs.cousubfp, cs.name;
-CREATE INDEX countysub_lookup_name_idx ON countysub_lookup (soundex(name));
+CREATE INDEX countysub_lookup_name_idx ON countysub_lookup ( @extschema:fuzzystrmatch at .soundex(name) );
CREATE INDEX countysub_lookup_state_idx ON countysub_lookup (state);
DROP TABLE IF EXISTS tiger.zip_lookup_all;
@@ -982,12 +982,9 @@ CREATE TABLE county
awater double precision,
intptlat character varying(11),
intptlon character varying(12),
- the_geom geometry,
+ the_geom @extschema:postgis at .geometry(MULTIPOLYGON,4269),
CONSTRAINT uidx_county_gid UNIQUE (gid),
- CONSTRAINT pk_tiger_county PRIMARY KEY (cntyidfp),
- CONSTRAINT enforce_dims_geom CHECK (st_ndims(the_geom) = 2),
- CONSTRAINT enforce_geotype_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL),
- CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 4269)
+ CONSTRAINT pk_tiger_county PRIMARY KEY (cntyidfp)
CREATE INDEX idx_tiger_county ON county USING btree (countyfp);
@@ -1008,13 +1005,10 @@ CREATE TABLE state
awater bigint,
CONSTRAINT uidx_tiger_state_stusps UNIQUE (stusps),
CONSTRAINT uidx_tiger_state_gid UNIQUE (gid),
- CONSTRAINT pk_tiger_state PRIMARY KEY (statefp),
- CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
- CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS NULL),
- CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 4269)
+ CONSTRAINT pk_tiger_state PRIMARY KEY (statefp)
CREATE INDEX idx_tiger_state_the_geom_gist ON state USING gist(the_geom);
@@ -1039,11 +1033,8 @@ CREATE TABLE place
awater bigint,
- CONSTRAINT uidx_tiger_place_gid UNIQUE (gid),
+ CONSTRAINT uidx_tiger_place_gid UNIQUE (gid)
CREATE INDEX tiger_place_the_geom_gist ON place USING gist(the_geom);
@@ -1088,11 +1079,8 @@ CREATE TABLE cousub
awater numeric(14),
- CONSTRAINT uidx_cousub_gid UNIQUE (gid),
+ CONSTRAINT uidx_cousub_gid UNIQUE (gid)
CREATE INDEX tige_cousub_the_geom_gist ON cousub USING gist(the_geom);
@@ -1132,10 +1120,7 @@ CREATE TABLE edges
offsetr character varying(1),
tnidf numeric(10),
tnidt numeric(10),
- CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'MULTILINESTRING'::text OR the_geom IS NULL),
+ the_geom @extschema:postgis at .geometry(MULTILINESTRING,4269)
CREATE INDEX idx_edges_tlid ON edges USING btree(tlid);
CREATE INDEX idx_tiger_edges_countyfp ON edges USING btree(countyfp);
@@ -1168,10 +1153,7 @@ CREATE TABLE addrfeat
rtotyp character varying(1),
offsetl character varying(1),
- CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'LINESTRING'::text OR the_geom IS NULL),
+ the_geom @extschema:postgis at .geometry(LINESTRING,4329)
CREATE INDEX idx_addrfeat_geom_gist ON addrfeat USING gist(the_geom );
CREATE INDEX idx_addrfeat_tlid ON addrfeat USING btree(tlid);
@@ -1250,10 +1232,7 @@ gid serial NOT NULL PRIMARY KEY,
atotal double precision,
intptlat varchar(11),
intptlon varchar(12),
CREATE INDEX idx_tiger_faces_tfid ON faces USING btree (tfid);
CREATE INDEX idx_tiger_faces_countyfp ON faces USING btree(countyfp);
@@ -1284,7 +1263,7 @@ CREATE TABLE featnames
CONSTRAINT featnames_pkey PRIMARY KEY (gid)
ALTER TABLE featnames ADD COLUMN statefp character varying(2);
-CREATE INDEX idx_tiger_featnames_snd_name ON featnames USING btree (soundex(name));
+CREATE INDEX idx_tiger_featnames_snd_name ON featnames USING btree ( @extschema:fuzzystrmatch at .soundex(name) );
CREATE INDEX idx_tiger_featnames_lname ON featnames USING btree (lower(name));
CREATE INDEX idx_tiger_featnames_tlid_statefp ON featnames USING btree (tlid,statefp);
@@ -1324,10 +1303,6 @@ CREATE TABLE zcta5
partflg character varying(1),
- CONSTRAINT uidx_tiger_zcta5_gid UNIQUE (gid),
- CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 4269),
+ the_geom @extschema:postgis at .geometry(MULTIPOLYGON, 4269),
CONSTRAINT pk_tiger_zcta5_zcta5ce PRIMARY KEY (zcta5ce,statefp)
diff --git a/extras/tiger_geocoder/tiger_loader_2024.sql b/extras/tiger_geocoder/tiger_loader_2024.sql
index a2cf0178a..f6d7f0b85 100644
--- a/extras/tiger_geocoder/tiger_loader_2024.sql
+++ b/extras/tiger_geocoder/tiger_loader_2024.sql
@@ -22,7 +22,7 @@ var_temp := tiger.SetSearchPathForInstall('tiger');
IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_schema = 'tiger' AND column_name = 'tract_id' AND table_name = 'tract') THEN
-- census block group/tracts parent tables not created yet or an older version -- drop old if not in use, create new structure
DROP TABLE IF EXISTS tiger.tract;
- CREATE TABLE tract
+ CREATE TABLE tiger.tract
gid serial NOT NULL,
statefp varchar(2),
@@ -44,7 +44,7 @@ IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_sche
DROP TABLE IF EXISTS tiger.tabblock;
- CREATE TABLE tabblock
+ CREATE TABLE tiger.tabblock
statefp varchar(2),
@@ -68,7 +68,7 @@ IF NOT EXISTS(SELECT table_name FROM information_schema.columns WHERE table_sche
DROP TABLE IF EXISTS tiger.bg;
- CREATE TABLE bg
+ CREATE TABLE tiger.bg
statefp varchar(2),
diff --git a/extras/tiger_geocoder/utility/levenshtein_ignore_case.sql b/extras/tiger_geocoder/utility/levenshtein_ignore_case.sql
index d0e832295..d7ab846e7 100644
--- a/extras/tiger_geocoder/utility/levenshtein_ignore_case.sql
+++ b/extras/tiger_geocoder/utility/levenshtein_ignore_case.sql
@@ -1,5 +1,5 @@
--- This function determines the levenshtein distance irespective of case.
+-- This function determines the levenshtein distance irrespective of case.
CREATE OR REPLACE FUNCTION levenshtein_ignore_case(VARCHAR, VARCHAR) RETURNS INTEGER
AS $_$
- SELECT levenshtein(COALESCE(upper($1),''), COALESCE(upper($2),''));
+ SELECT @extschema:fuzzystrmatch at .levenshtein(COALESCE(upper($1),''), COALESCE(upper($2),''));
$_$ LANGUAGE sql IMMUTABLE;
diff --git a/extras/tiger_geocoder/utility/nullable_levenshtein.sql b/extras/tiger_geocoder/utility/nullable_levenshtein.sql
index eab8ca7e7..e0ee3beca 100644
--- a/extras/tiger_geocoder/utility/nullable_levenshtein.sql
+++ b/extras/tiger_geocoder/utility/nullable_levenshtein.sql
@@ -20,7 +20,7 @@ BEGIN
END IF;
IF $2 IS NOT NULL AND $2 != '' THEN
- result := levenshtein_ignore_case(given_string, $2);
+ result := @extschema:fuzzystrmatch at .levenshtein_ignore_case_ignore_case(given_string, $2);
END IF;
RETURN result;
Summary of changes:
.gitignore | 1 +
NEWS | 3 ++
extensions/postgis_tiger_geocoder/Makefile.in | 19 ++++++--
.../postgis_tiger_geocoder.control.in | 1 +
.../geocode/geocode_intersection.sql | 8 +--
extras/tiger_geocoder/geocode/geocode_location.sql | 8 +--
extras/tiger_geocoder/geocode/rate_attributes.sql | 14 +++---
extras/tiger_geocoder/normalize/end_soundex.sql | 4 +-
.../tiger_geocoder/normalize/location_extract.sql | 12 ++---
.../normalize/location_extract_countysub_fuzzy.sql | 24 ++++-----
.../normalize/location_extract_place_fuzzy.sql | 8 +--
.../tiger_geocoder/tables/lookup_tables_2011.sql | 57 ++++++----------------
extras/tiger_geocoder/tiger_loader_2024.sql | 6 +--
.../utility/levenshtein_ignore_case.sql | 4 +-
.../utility/nullable_levenshtein.sql | 2 +-
15 files changed, 82 insertions(+), 89 deletions(-)
hooks/post-receive
