[PostGIS] #5897: change postgis_tiger_geocoder to use typmod
trac at osgeo.org
Mon Aug 4 16:13:39 PDT 2025
Reporter: robe | Owner: robe
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.6.0
Component: tiger geocoder | Version: master
Resolution: fixed | Keywords:
Changes (by Regina Obe <lr@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"bc08546510ebfbd458c42f22dd696f50bd81ac95/git" bc08546/git]:
{{{#!CommitTicketReference repository="git"
revision="bc08546510ebfbd458c42f22dd696f50bd81ac95"
SCHEMA qualify extension dependencies
for PG16 and above for postgis_tiger_geocoder
- schema qualify in scripts dependent extensions postgis, fuzzystrmatch
- add a no_relocate clause to the .control file to prevent relocation
of these for PG16 and above
- Use for new installs typmod for geometry instead of constraints
- Ignore regression.out files generated by installcheck
Closes #5359
Closes #5897
Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/260
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5897#comment:2>
