[PostGIS] #5953: Slow st_intersection with big input polygons
trac at osgeo.org
Thu Aug 7 15:37:56 PDT 2025
Reporter: Lars Aksel Opsahl | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by pramsey):
Yes, the pattern that maximizes the amount of caching, when you're doing
an intersection is something like
SELECT big.id AS big_id, small.id AS small_id,
CASE
WHEN ST_Contains(big.geom, small.geom)
THEN small
ELSE ST_Intersection(bit.geom, small.geom)
END AS geom
FROM big
JOIN small
ON ST_Intersects(big.geom, small.geom)
This gets you two levels of cached predicate logic protecting the
expensive intersection logic. The join condition ensures that no disjoint
pairs are considered, efficiently using intersects. The case condition
ensures that fully contained objects are not passed to intersection.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5953#comment:7>
