[SCM] PostGIS branch stable-3.5 updated. 3.5.3-42-gcf7d4f492
git at osgeo.org
git at osgeo.org
Fri Aug 8 13:43:49 PDT 2025
the project "PostGIS".
The branch, stable-3.5 has been updated
via cf7d4f492d3201fe546d27a3b1d79664002d35d4 (commit)
from 30a45040a71a57d972c7be70365462374010c2f0 (commit)
revisions in full, below.
commit cf7d4f492d3201fe546d27a3b1d79664002d35d4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Aug 8 13:43:31 2025 -0700
Use memset rather than bzero, closes #5407
diff --git a/NEWS b/NEWS
index b59b6f5a9..77c600826 100644
--- a/NEWS
+++ b/NEWS
@@ -25,6 +25,7 @@ PostgreSQL 12-18 required. GEOS 3.8+ required. Proj 6.1+ required.
- #5927, ST_IsCollection throwing exception (Paul Ramsey)
- #5902, ST_PointFromText cannot create geometries with M (Paul Ramsey)
- #5943, Memory leak in handling GEOS GeometryFactory (Megan Ma)
+- #5407, Use memset in place of bzero (Paul Ramsey)
PostGIS 3.5.3
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index f229d42de..7d17775cf 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -2227,7 +2227,7 @@ ptarray_scroll_in_place(POINTARRAY *pa, const POINT4D *pt)
/* TODO: reduce allocations */
tmp = ptarray_construct(FLAGS_GET_Z(pa->flags), FLAGS_GET_M(pa->flags), pa->npoints);
- bzero(getPoint_internal(tmp, 0), (size_t)ptsize * pa->npoints);
+ memset(getPoint_internal(tmp, 0), 0, (size_t)ptsize * pa->npoints);
/* Copy the block from found point to last point into the output array */
memcpy(
Summary of changes:
NEWS | 1 +
liblwgeom/ptarray.c | 2 +-
2 files changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
