[PostGIS] #5827: ST_3DDFullyWithin gives wrong result
trac at osgeo.org
Fri Aug 8 14:11:09 PDT 2025
Reporter: nbvfgh | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 3.6.0
Component: postgis | Version: 3.5.x
Resolution: wontfix | Keywords:
Changes (by robe):
* resolution: => wontfix
* status: new => closed
Comment:
You should be using ST_3DDWithin with distance = 0
https://postgis.net/docs/ST_3DDWithin.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5827#comment:6>
