[PostGIS] #5655: make check fails when you do not have docs building/testing requirements (build works)
trac at osgeo.org
Fri Aug 8 14:59:50 PDT 2025
(build works)
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.4
Component: build | Version: 3.4.x
Resolution: | Keywords: documentation, testsuite
Changes (by robe):
* milestone: PostGIS 3.6.0 => PostGIS 3.5.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5655#comment:5>
