[PostGIS] #5498: ERROR: function st_approxquantile(raster, double precision) is not unique
trac at osgeo.org
Fri Aug 15 07:26:46 PDT 2025
Reporter: strk | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 3.6.0
Component: raster | Version: master
Resolution: | Keywords:
Changes (by robe):
* resolution: fixed =>
* status: closed => reopened
Comment:
Looks like dronie and woodie are failing with this error upgrading from
3.1
Loading PostGIS in 'postgis_reg using scripts from
/usr/share/postgresql/14/contrib/postgis-3.1'
Loading Raster into 'postgis_reg'
Restoring database 'postgis_reg' using postgis_restore.pl
Done.
Died at /drone/src/regress/run_test.pl line 454.
gmake: *** [/drone/src/regress/runtest.mk:24: check-regress] Error 3
failed (Could not restore postgis_reg: /tmp/pgis_reg/regress_log)
NOTICE: schema "public" already exists, skipping
SET
ALTER TABLE
ALTER TABLE
SELECT 8500
DELETE 8500
SET
SET
SET
SET
SET
set_config
(1 row)
SET
SET
SET
SET
ERROR: function "st_approxquantile" already exists with same argument
types
gmake: Leaving directory '/tmp/postgis-build/14/raster/test/regress'
FAIL: postgis_raster script hard upgrade unpackaged3.1--:auto
Cleaning up so I must have missed something.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5498#comment:7>
