[SCM] PostGIS branch master updated. 3.6.0beta1-32-gd70143462
Fri Aug 15 11:06:06 PDT 2025
the project "PostGIS".
       via  d70143462d8905b2e7460b6647f475aa5895a39f (commit)
      from  d0ea36670bd84f5e38a5e1a568b23ba0c55bb713 (commit)
revisions in full, below.
commit d70143462d8905b2e7460b6647f475aa5895a39f
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Aug 15 10:38:09 2025 -0400
    Use signature instead of identity and put in
    rtpostgis_upgrade_cleanup.sql.in instead of rtpostgis_drop.sql.in
    Closes #5498 for PostGIS 3.6.0
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index 156f085df..284281cf0 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -140,5 +140,4 @@ SELECT _postgis_drop_function_by_identity('st_value','rast raster, band integer,
 SELECT _postgis_drop_function_by_signature('st_gdalopenoptions(text[])');
 SELECT _postgis_drop_function_by_identity('st_clip','rast raster, geom geometry, nodataval float8[], crop boolean', '3.5');
-SELECT _postgis_drop_function_by_identity('st_approxquantile', 'rast raster, quantile double precision','3.6');
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index 3d75f71c0..654729567 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -586,3 +586,7 @@ $$;
 -- 2.5.0 signature changed
 SELECT _postgis_drop_function_by_signature('st_bandmetadata(raster, int[])', '2.5.0');
 SELECT _postgis_drop_function_by_signature('st_bandmetadata(raster, int)', '2.5.0');
+-- removed 3.6.0, but was broken in prior versions
+SELECT _postgis_drop_function_by_signature('st_approxquantile(raster, double precision)');
Summary of changes:
 raster/rt_pg/rtpostgis_drop.sql.in            | 1 -
 raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in | 4 ++++
 2 files changed, 4 insertions(+), 1 deletion(-)
hooks/post-receive
