[SCM] PostGIS branch master updated. 3.6.0beta1-42-g136e4f62c
Sun Aug 17 19:47:04 PDT 2025
the project "PostGIS".
       via  136e4f62cb0d4e3400ac2a97b903bdf1ecc5f075 (commit)
      from  3b7600f8ab8edc415bbae951c4958acf03cf4909 (commit)
revisions in full, below.
commit 136e4f62cb0d4e3400ac2a97b903bdf1ecc5f075
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Aug 17 22:46:49 2025 -0400
    Revert 3b7600f8a References #5965
diff --git a/libpgcommon/lwgeom_pg.h b/libpgcommon/lwgeom_pg.h
index 2cb698faf..102d84f35 100644
--- a/libpgcommon/lwgeom_pg.h
+++ b/libpgcommon/lwgeom_pg.h
@@ -89,18 +89,8 @@ void pg_install_lwgeom_handlers(void);
 /* Argument handling macros */
 #define PG_GETARG_GSERIALIZED_P(varno) ((GSERIALIZED *)PG_DETOAST_DATUM(PG_GETARG_DATUM(varno)))
 #define PG_GETARG_GSERIALIZED_P_COPY(varno) ((GSERIALIZED *)PG_DETOAST_DATUM_COPY(PG_GETARG_DATUM(varno)))
 #define PG_GSERIALIZED_DATUM_NEEDS_DETOAST(datum) \
-	(VARATT_IS_EXTENDED(DatumGetPointer(datum)) || \
-	 VARATT_IS_EXTERNAL(DatumGetPointer(datum)) || \
-	 VARATT_IS_COMPRESSED(DatumGetPointer(datum)))
-// #define PG_GSERIALIZED_DATUM_NEEDS_DETOAST(datum) \
-// 	(VARATT_IS_EXTENDED((datum)) || \
-// 	 VARATT_IS_EXTERNAL((datum)) || \
-// 	 VARATT_IS_COMPRESSED((datum)))
+	(VARATT_IS_EXTENDED((datum)) || VARATT_IS_EXTERNAL((datum)) || VARATT_IS_COMPRESSED((datum)))
 #define PG_GETARG_GSERIALIZED_HEADER(varno) \
 	PG_GSERIALIZED_DATUM_NEEDS_DETOAST(PG_GETARG_DATUM(varno)) \
 	? ((GSERIALIZED *)PG_DETOAST_DATUM_SLICE(PG_GETARG_DATUM(varno), 0, gserialized_max_header_size())) \
diff --git a/postgis/gserialized_gist_2d.c b/postgis/gserialized_gist_2d.c
index 2b33a7e4b..6e2c28e5e 100644
--- a/postgis/gserialized_gist_2d.c
+++ b/postgis/gserialized_gist_2d.c
@@ -476,7 +476,7 @@ gserialized_datum_get_internals_p(Datum gsdatum, GBOX *gbox, lwflags_t *flags, u
 	int result = LW_SUCCESS;
 	GSERIALIZED *gpart = NULL;
-	int need_detoast = PG_GSERIALIZED_DATUM_NEEDS_DETOAST(gsdatum);
+	int need_detoast = PG_GSERIALIZED_DATUM_NEEDS_DETOAST((struct varlena *)gsdatum);
 	if (need_detoast)
 		gpart = (GSERIALIZED *)PG_DETOAST_DATUM_SLICE(gsdatum, 0, gserialized_max_header_size());
@@ -528,7 +528,7 @@ gserialized_datum_get_box2df_p(Datum gsdatum, BOX2DF *box2df)
 	if (need_detoast)
Summary of changes:
 libpgcommon/lwgeom_pg.h       | 12 +-----------
 postgis/gserialized_gist_2d.c |  4 ++--
 2 files changed, 3 insertions(+), 13 deletions(-)
hooks/post-receive
